@Mariano_Colmenarejo @dotan_shai
thanks for both of you!
its recognized your driver!!!
thank you very much!!
now I have another problem with the same module
when I turn on switch 1 its automatically turn on switch 2 together.
maybe you know why its like this?
if I turn on switch 2 its turn on automatically switch 1 too
I made a log when I tried to turn on only 1 button.
8 540ae948-6fcc-4137-809c-875c3e186071 Zigbee Multi Switch and Child Mc
9 91a22a50-31a2-4177-9999-8ed3770bfee6 Zigbee Multi Switch Mc-(OLD)
10 5ab64dc7-5d08-44a4-9806-5a5b823a18d2 Zigbee Sensors Edge Driver [YG] 1.8.14
11 bc53adfe-d18f-4ea4-9610-6aade6696b7a Zigbee Switch Mc
12 7fee6e41-26cc-49ef-b1f4-b30a43e02fe6 Zigbee Switch Power Mc
13 2198462e-a429-4d4c-8973-991a9ed1b9c8 Zigbee Temp Sensor with Thermostat Mc
14 3724840a-2b1d-4f6b-9683-e8e0155445ee Zigbee Thing [YG] v1.0.2
? Select a driver. 8
connecting... connected
2022-10-03T19:08:22.396873587+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2022-10-03T19:08:22.447514920+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> received command: {"args":{},"capability":"switch","command":"off","component":"main","positional_args":{}}
2022-10-03T19:08:22.498399254+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:22.535345920+00:00 PRINT Zigbee Multi Switch and Child Mc device.parent_device_id >>> baaa6494-1fa6-4eeb-b592-498bc41585cc
2022-10-03T19:08:22.542509587+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2022-10-03T19:08:22.633344587+00:00 DEBUG Zigbee Multi Switch and Child Mc switch2 device thread event handled
2022-10-03T19:08:22.766261587+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:22.791986921+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x3F, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-10-03T19:08:22.818284921+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:22.861342254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xC8, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-10-03T19:08:22.909077254+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:22.915565587+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-10-03T19:08:22.940025587+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"switch2","state":{"value":"off"}}
2022-10-03T19:08:22.979669254+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.016761921+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:23.032900254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCA, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-10-03T19:08:23.055992921+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:23.066714254+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:23.072766587+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:23.078980587+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 124, rssi: -69dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:23.098359254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2022-10-03T19:08:23.119716254+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 1 value = false
2022-10-03T19:08:23.130302921+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.137172921+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:23.148520587+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCB, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-10-03T19:08:23.183702921+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:23.191074921+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:23.196857254+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:23.203060587+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 124, rssi: -69dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:23.219165587+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2022-10-03T19:08:23.235107921+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 1 value = false
2022-10-03T19:08:23.245400254+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.252115921+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:23.260411254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x30, rssi: -88, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xC9, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2022-10-03T19:08:23.278999254+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.286842254+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:23.292148921+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:23.297807254+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:23.303879921+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 124, rssi: -69dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:23.322283588+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"switch2","state":{"value":"off"}}
2022-10-03T19:08:23.336732588+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 2 value = false
2022-10-03T19:08:23.342710254+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2022-10-03T19:08:23.362034254+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.370148254+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.378439254+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:23.383767921+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:23.389426588+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:23.395695254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 48, rssi: -88dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:23.414781254+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"switch2","state":{"value":"off"}}
2022-10-03T19:08:23.431590588+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 2 value = false
2022-10-03T19:08:23.437570254+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2022-10-03T19:08:23.457311921+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.465069921+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:23.473310921+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.137403588+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:25.144007255+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All Off"}}
2022-10-03T19:08:25.161475588+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.249754588+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:25.255897255+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All Off"}}
2022-10-03T19:08:25.271564255+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.373006588+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:25.379223255+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All Off"}}
2022-10-03T19:08:25.394557922+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.468977922+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:25.475432589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All Off"}}
2022-10-03T19:08:25.490882589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.583740255+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2022-10-03T19:08:25.601078922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received command: {"args":{},"capability":"switch","command":"on","component":"main","positional_args":{}}
2022-10-03T19:08:25.607128589+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:25.613969255+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xFDDF, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x01 >, < On || > > >
2022-10-03T19:08:25.635727255+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:25.668104589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.676155922+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.741671589+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:25.749784589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x30, rssi: -88, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x40, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2022-10-03T19:08:25.772820922+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:25.784328589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x38, rssi: -86, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCC, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-10-03T19:08:25.803194589+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:25.808419922+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2022-10-03T19:08:25.814947589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:25.829980589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.837038255+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:25.846064922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x30, rssi: -88, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCE, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-10-03T19:08:25.862856922+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:25.868038922+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:25.873985922+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:25.880027922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 56, rssi: -86dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:25.898283922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:25.917514922+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 1 value = true
2022-10-03T19:08:25.928009589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:25.934924589+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:25.947774589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x34, rssi: -87, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCF, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-10-03T19:08:25.965324922+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:25.970951589+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:25.976647255+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:25.983251922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 48, rssi: -88dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:26.005815922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:26.021781922+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 1 value = true
2022-10-03T19:08:26.031803589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.038619922+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2022-10-03T19:08:26.046791922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xFDDF, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x7C, rssi: -69, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xCD, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-10-03T19:08:26.063827255+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.071869922+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:26.077335589+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:26.083237589+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:26.090885922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 52, rssi: -87dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:26.109737589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"switch2","state":{"value":"on"}}
2022-10-03T19:08:26.130226589+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 2 value = true
2022-10-03T19:08:26.136114256+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:26.160380256+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.167549589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.175895922+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-10-03T19:08:26.181087589+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-10-03T19:08:26.187083256+00:00 PRINT Zigbee Multi Switch and Child Mc function: on_off_attr_handler
2022-10-03T19:08:26.194461922+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"signalMetrics","capability_id":"legendabsolute60149.signalMetrics","component_id":"main","state":{"value":"dni: 0xFDDF, lqi: 124, rssi: -69dBm"},"visibility":{"displayed":false}}
2022-10-03T19:08:26.217183589+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"switch2","state":{"value":"on"}}
2022-10-03T19:08:26.231736589+00:00 PRINT Zigbee Multi Switch and Child Mc src_endpoint = 2 value = true
2022-10-03T19:08:26.237617922+00:00 INFO Zigbee Multi Switch and Child Mc <Device: a0697f0a-0b7b-424b-a280-06c939cb5e18 (switch2)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2022-10-03T19:08:26.257473589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.264605256+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:26.271755589+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:27.672359590+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:27.688026923+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All On"}}
2022-10-03T19:08:27.722948923+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:27.946529256+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:27.953210923+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All On"}}
2022-10-03T19:08:27.968424590+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:28.042192923+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:28.048754590+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All On"}}
2022-10-03T19:08:28.064535256+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:28.166593256+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:28.175867923+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All On"}}
2022-10-03T19:08:28.210684257+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
2022-10-03T19:08:28.268545257+00:00 PRINT Zigbee Multi Switch and Child Mc all_switches_status >>>>>
2022-10-03T19:08:28.275168257+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: baaa6494-1fa6-4eeb-b592-498bc41585cc [0xFDDF] (אמבטיה)> emitting event: {"attribute_id":"switchAllOnOff","capability_id":"legendabsolute60149.switchAllOnOff1","component_id":"main","state":{"value":"All On"}}
2022-10-03T19:08:28.290665923+00:00 DEBUG Zigbee Multi Switch and Child Mc TS0002 Switch device thread event handled
