I run a install update to driver but itβs in the last version.
published last version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Driver Id 3ecbe4bf-64d2-414a-9e05-3712097531cb
Name Zigbee Motion Sensor Test
Package Key zigbee-motion-sensor-v4.1
Version 2022-09-29T17:25:20.306917236
Here is it:
2022-09-29T17:49:21.013554131+00:00 DEBUG Zigbee Motion Sensor Test Sensor da Escada device thread event handled
2022-09-29T17:49:21.047282464+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T17:49:21.057383131+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-09-29T17:49:21.068244464+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 2108b038-3fd1-4c3a-b897-c08f490cf1bb [0x6743] (Sensor da Escada)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2022-09-29T17:49:21.102788798+00:00 DEBUG Zigbee Motion Sensor Test Sensor da Escada device thread event handled
2022-09-29T17:49:31.826801136+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T17:49:31.854131803+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 2108b038-3fd1-4c3a-b897-c08f490cf1bb [0x6743] (Sensor da Escada)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x94, rssi: -63, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x61, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0000, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2022-09-29T17:49:31.889223136+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T17:49:31.906789803+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-09-29T17:49:31.913940803+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 2108b038-3fd1-4c3a-b897-c08f490cf1bb [0x6743] (Sensor da Escada)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"inactive"}}
2022-09-29T17:49:31.944330469+00:00 DEBUG Zigbee Motion Sensor Test Sensor da Escada device thread event handled
2022-09-29T17:49:44.639766142+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T17:50:14.652034490+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T17:50:44.648220837+00:00 INFO Zigbee Motion Sensor Test Doing health check read for [6743]:0500:0002
2022-09-29T17:50:44.675338838+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 2108b038-3fd1-4c3a-b897-c08f490cf1bb [0x6743] (Sensor da Escada)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
@Dienzora
In this log does not show information about sensitivity levels
Please, need a device pairing log due to this devices sleep when are inactives and do not respond to attribute reads
last test version
Version 2022-09-29T18:48:49.333772276
Here is it:
2022-09-29T19:09:39.497750013+00:00 TRACE Zigbee Motion Sensor Test Zigbee Device: c725ee59-293f-4756-97bd-5a00a3c2a4ce
Manufacturer: _TZ3000_msl6wxk9 Model: TS0202
[1]: PowerConfiguration, IASZone, Identify, Basic
2022-09-29T19:09:39.505985679+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:09:39.512298013+00:00 TRACE Zigbee Motion Sensor Test Received event with handler _resync
2022-09-29T19:09:39.518598346+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-09-29T19:09:39.538694346+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:09:39.544549679+00:00 PRINT Zigbee Motion Sensor Test <<<<<< Read attributtes >>>>>>
2022-09-29T19:09:39.551446679+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"sensorSensitivity","capability_id":"legendabsolute60149.sensorSensitivity","component_id":"main","state":{"value":" "}}
2022-09-29T19:09:39.575351013+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:09:39.581484013+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-09-29T19:09:39.587556679+00:00 DEBUG Zigbee Motion Sensor Test Z-Wave hub node ID environment changed.
2022-09-29T19:09:39.601733679+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:09:44.616516347+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:10:02.499657243+00:00 TRACE Zigbee Motion Sensor Test Received event with handler capability
2022-09-29T19:10:02.508561359+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-09-29T19:10:02.520850834+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-09-29T19:10:02.528237192+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-09-29T19:10:02.565498814+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-29T19:10:02.589660889+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:10:09.465485105+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:10:39.475467786+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:10:51.553743458+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:10:51.665347791+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x73, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x82 > > > >
2022-09-29T19:10:52.282771792+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:10:52.370990125+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2022-09-29T19:10:52.427131458+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"battery","capability_id":"battery","component_id":"main","state":{"value":65}}
2022-09-29T19:10:52.512126792+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:10:57.157966127+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T19:10:57.209862461+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received lifecycle event: infoChanged
2022-09-29T19:10:57.270099127+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:10:57.279796794+00:00 PRINT Zigbee Motion Sensor Test ***** infoChanged *********
2022-09-29T19:10:57.287135127+00:00 PRINT Zigbee Motion Sensor Test Manufacturer, Model _TZ3000_msl6wxk9 TS0202
2022-09-29T19:10:57.307954794+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= 1 preferences: motionSensitivity
2022-09-29T19:10:57.319345461+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> motionSensitivity 2 1
2022-09-29T19:10:57.328045794+00:00 PRINT Zigbee Motion Sensor Test <<< Write restore state >>>
2022-09-29T19:10:57.349161461+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x01 > > > >
2022-09-29T19:10:57.367620127+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= preferences: version
2022-09-29T19:10:57.391991461+00:00 PRINT Zigbee Motion Sensor Test Device ID >>> <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)>
2022-09-29T19:10:57.409844794+00:00 PRINT Zigbee Motion Sensor Test Manufacturer >>> _TZ3000_msl6wxk9 Manufacturer_Len >>> 16
2022-09-29T19:10:57.415966794+00:00 PRINT Zigbee Motion Sensor Test Model >>> TS0202 Model_len >>> 6
2022-09-29T19:10:57.426299794+00:00 PRINT Zigbee Motion Sensor Test Memory >>>>>>> 1051.55859375 Kbytes
2022-09-29T19:10:57.445436794+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
here is it:
2022-09-29T19:19:39.583739082+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:19:56.593500424+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T19:19:56.606062424+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received lifecycle event: infoChanged
2022-09-29T19:19:56.619434090+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:19:56.626594424+00:00 PRINT Zigbee Motion Sensor Test ***** infoChanged *********
2022-09-29T19:19:56.633500090+00:00 PRINT Zigbee Motion Sensor Test Manufacturer, Model _TZ3000_msl6wxk9 TS0202
2022-09-29T19:19:56.640085424+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= 0 preferences: motionSensitivity
2022-09-29T19:19:56.646003757+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> motionSensitivity 20 0
2022-09-29T19:19:56.652058090+00:00 PRINT Zigbee Motion Sensor Test <<< Write restore state >>>
2022-09-29T19:19:56.661681757+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x00 > > > >
2022-09-29T19:19:56.675169424+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= preferences: version
2022-09-29T19:19:56.689912424+00:00 PRINT Zigbee Motion Sensor Test Device ID >>> <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)>
2022-09-29T19:19:56.699574090+00:00 PRINT Zigbee Motion Sensor Test Manufacturer >>> _TZ3000_msl6wxk9 Manufacturer_Len >>> 16
2022-09-29T19:19:56.709734424+00:00 PRINT Zigbee Motion Sensor Test Model >>> TS0202 Model_len >>> 6
2022-09-29T19:19:56.716464424+00:00 PRINT Zigbee Motion Sensor Test Memory >>>>>>> 1017.1455078125 Kbytes
2022-09-29T19:19:56.721656090+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:19:56.730839090+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:19:59.773184759+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:20:09.591922097+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:20:15.140061099+00:00 TRACE Zigbee Motion Sensor Test Received event with handler capability
2022-09-29T19:20:15.154831766+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received command: {"args":{"value":"Read"},"capability":"legendabsolute60149.sensorSensitivity","command":"setSensorSensitivity","component":"main","positional_args":["Read"]}
2022-09-29T19:20:15.165250433+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-09-29T19:20:15.171328766+00:00 PRINT Zigbee Motion Sensor Test command.args.value >>>>> Read
2022-09-29T19:20:15.179472766+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"sensorSensitivity","capability_id":"legendabsolute60149.sensorSensitivity","component_id":"main","state":{"value":"Read Attribute"}}
2022-09-29T19:20:15.242462766+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:20:31.996116441+00:00 TRACE Zigbee Motion Sensor Test Received event with handler capability
2022-09-29T19:20:32.033554441+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-09-29T19:20:32.042772441+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-09-29T19:20:32.052142774+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-09-29T19:20:32.082467107+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-29T19:20:32.127243107+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:20:39.591146778+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:21:09.606261125+00:00 INFO Zigbee Motion Sensor Test Doing health check read for [6743]:0500:0002
2022-09-29T19:21:09.616252792+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: c725ee59-293f-4756-97bd-5a00a3c2a4ce [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-29T19:21:09.647063125+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
As I was saying, it seems that he is asleep and does not respond to reading commands.
Yesterday he answered the first.
Try to do the following:
- Put the CLI to capture the logs
- Since the app remove the device, this will put it into pairing mode.
- In the App add device, search nearby
You need the log of paring, right ?
Here is the log:
2022-09-29T19:58:56.062955558+00:00 TRACE Zigbee Motion Sensor Test Zigbee Device: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b
2022-09-29T19:58:56.071033558+00:00 TRACE Zigbee Motion Sensor Test Received event with handler _resync
2022-09-29T19:58:56.076429892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-09-29T19:58:56.094617892+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T19:58:56.102108892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-09-29T19:58:56.107532558+00:00 DEBUG Zigbee Motion Sensor Test Z-Wave hub node ID environment changed.
2022-09-29T19:58:56.116472892+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:58:56.121894892+00:00 PRINT Zigbee Motion Sensor Test <<<<<< Read attributtes >>>>>>
2022-09-29T19:58:56.130619558+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"sensorSensitivity","capability_id":"legendabsolute60149.sensorSensitivity","component_id":"main","state":{"value":" "}}
2022-09-29T19:58:56.156065558+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.164154558+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T19:58:56.169862225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received lifecycle event: added
2022-09-29T19:58:56.183972892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.190683225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T19:58:56.197175558+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received lifecycle event: doConfigure
2022-09-29T19:58:56.205961225+00:00 TRACE Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received unhandled lifecycle event: added
2022-09-29T19:58:56.212238892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.223178892+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:58:56.231424892+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-09-29T19:58:56.241841892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-09-29T19:58:56.266600558+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-29T19:58:56.294511225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13887A1CC8BC4, src_endpoint: 0x01, cluster: PowerConfiguration, dest_addr_mode: 0x03, dest_address: 286D97000200A55F, dest_endpoint: 0x01 > > >
2022-09-29T19:58:56.327705892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0021, DataType: Uint8, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x5460, reportable_change: 0x01 > > > >
2022-09-29T19:58:56.353545225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13887A1CC8BC4, src_endpoint: 0x01, cluster: IASZone, dest_addr_mode: 0x03, dest_address: 286D97000200A55F, dest_endpoint: 0x01 > > >
2022-09-29T19:58:56.376398892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0002, DataType: Bitmap16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C > > > >
2022-09-29T19:58:56.394759225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0010, DataType: IEEEAddress, data: 286D97000200A55F > > > >
2022-09-29T19:58:56.427345558+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneEnrollResponse || EnrollResponseCode: SUCCESS, zone_id: 0x00 > > >
2022-09-29T19:58:56.439053225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.447274892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:56.475716225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0021, ZclStatus: SUCCESS, DataType: Uint8, BatteryPercentageRemaining: 0x82 > > > >
2022-09-29T19:58:56.498460892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.520150225+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:58:56.528456892+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2022-09-29T19:58:56.545662225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"battery","capability_id":"battery","component_id":"main","state":{"value":65}}
2022-09-29T19:58:56.574651558+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.593095225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:56.665864892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0002, ZclStatus: SUCCESS, DataType: Bitmap16, ZoneStatus: 0x0001 > > > >
2022-09-29T19:58:56.756851225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:56.859659559+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x90, rssi: -64, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x37 >, < BindRequestResponse || status: 0x00 > > >
2022-09-29T19:58:56.911708892+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:58:56.923076892+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-09-29T19:58:56.932259559+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2022-09-29T19:58:56.949359225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.958184225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:56.971657225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4D, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0021 > > > >
2022-09-29T19:58:56.987808559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:56.994597225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.011468892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x90, rssi: -64, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x38 >, < BindRequestResponse || status: 0x00 > > >
2022-09-29T19:58:57.038049559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.046588892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.062739225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4E, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0002 > > > >
2022-09-29T19:58:57.078360225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.121716892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.134922892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x94, rssi: -63, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x50, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2022-09-29T19:58:57.149348892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.158542225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.470927559+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T19:58:57.483141892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received lifecycle event: infoChanged
2022-09-29T19:58:57.494016225+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T19:58:57.502298892+00:00 PRINT Zigbee Motion Sensor Test ***** infoChanged *********
2022-09-29T19:58:57.508257892+00:00 PRINT Zigbee Motion Sensor Test Manufacturer, Model _TZ3000_msl6wxk9 TS0202
2022-09-29T19:58:57.513463892+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= 2 preferences: motionSensitivity
2022-09-29T19:58:57.518816559+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> motionSensitivity nil 2
2022-09-29T19:58:57.525474892+00:00 PRINT Zigbee Motion Sensor Test <<< Write restore state >>>
2022-09-29T19:58:57.533358892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x02 > > > >
2022-09-29T19:58:57.556374225+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= preferences: version
2022-09-29T19:58:57.562410225+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> version nil
2022-09-29T19:58:57.585533559+00:00 PRINT Zigbee Motion Sensor Test Device ID >>> <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)>
2022-09-29T19:58:57.595750559+00:00 PRINT Zigbee Motion Sensor Test Manufacturer >>> _TZ3000_msl6wxk9 Manufacturer_Len >>> 16
2022-09-29T19:58:57.614348225+00:00 PRINT Zigbee Motion Sensor Test Model >>> TS0202 Model_len >>> 6
2022-09-29T19:58:57.635656225+00:00 PRINT Zigbee Motion Sensor Test Memory >>>>>>> 1492.5673828125 Kbytes
2022-09-29T19:58:57.656569225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.664293559+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.680210559+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x8A, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0001, extended_status: 0x00, zone_id: 0xFF, delay: 0x0000 > > >
2022-09-29T19:58:57.719842559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.727834225+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.767701559+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x87, ZCLCommandId: 0x01 >, < ZoneEnrollRequest || IasZoneType: MOTION_SENSOR, manufacturer_code: 0x1002 > > >
2022-09-29T19:58:57.792966225+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:58:57.799195225+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-09-29T19:58:57.824444892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"active"}}
2022-09-29T19:58:57.862724225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.888926892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:57.901427892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x89, ZCLCommandId: 0x01 >, < ZoneEnrollRequest || IasZoneType: MOTION_SENSOR, manufacturer_code: 0x1002 > > >
2022-09-29T19:58:57.965732225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:57.996509559+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:58.035750225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x52, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-09-29T19:58:58.105060892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:58.146743892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:58.188246892+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x8B, ZCLCommandId: 0x01 >, < ZoneEnrollRequest || IasZoneType: MOTION_SENSOR, manufacturer_code: 0x1002 > > >
2022-09-29T19:58:58.239190892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:58.258606892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:58.304406225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x8C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0013, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-09-29T19:58:58.332340559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:58.370524225+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:59.650397226+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:59.670912559+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x8E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0xF001, DataType: Uint8, Uint8: 0x00 > > > >
2022-09-29T19:58:59.695275559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:58:59.835435559+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:58:59.851815226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x8F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0013, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-09-29T19:58:59.897740892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:00.628131226+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:00.993978226+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:01.003283226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0x94, rssi: -63, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x58, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0001, ZclStatus: SUCCESS, DataType: Uint8, ApplicationVersion: 0x46 > > > >
2022-09-29T19:59:01.051599226+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:59:01.065954892+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterAttributeValueHandler: cluster: Basic, attribute: ApplicationVersion
2022-09-29T19:59:01.071808559+00:00 PRINT Zigbee Motion Sensor Test Firmware >>>>>>>>> 70
2022-09-29T19:59:01.079290559+00:00 PRINT Zigbee Motion Sensor Test <<<<<< applicationVersion_handler Status >>>>>>> 0
2022-09-29T19:59:01.094787892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:01.102907892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:01.114001226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x59, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: SUCCESS, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-09-29T19:59:01.132747892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:01.141899226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5A, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-09-29T19:59:01.183103892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:01.191798559+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:01.235991226+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:01.351903892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:01.365317226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Basic >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5B, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0001, ZclStatus: SUCCESS, DataType: Uint8, ApplicationVersion: 0x46 > > > >
2022-09-29T19:59:01.381010892+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:01.390784226+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: SUCCESS, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-09-29T19:59:01.409305559+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:59:01.414805226+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterAttributeValueHandler: cluster: Basic, attribute: ApplicationVersion
2022-09-29T19:59:01.420460559+00:00 PRINT Zigbee Motion Sensor Test Firmware >>>>>>>>> 70
2022-09-29T19:59:01.425724226+00:00 PRINT Zigbee Motion Sensor Test <<<<<< applicationVersion_handler Status >>>>>>> 0
2022-09-29T19:59:01.431499226+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:01.450069892+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:08.021723227+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-09-29T19:59:08.031112560+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x09, seqno: 0x90, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0000, extended_status: 0x00, zone_id: 0x01, delay: 0x0000 > > >
2022-09-29T19:59:08.059071560+00:00 TRACE Zigbee Motion Sensor Test Found ZigbeeMessageDispatcher handler in zigbee-motion
2022-09-29T19:59:08.064467893+00:00 INFO Zigbee Motion Sensor Test Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2022-09-29T19:59:08.070876560+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"motion","capability_id":"motionSensor","component_id":"main","state":{"value":"inactive"}}
2022-09-29T19:59:08.089578893+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T19:59:26.025595562+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
Ok!
Sorry, Iβm with several things and I donβt do any!
Now you answered ok, this is the problem to change the settings on these devices when they are asleep
It has sensitivity level 2 and does not support the attribute that indicates how many levels it supports, so you have to go blind.
Did you show the value 2 in the custom capability?
Try putting in preferences a value < 2 to lower the sensitivity and >2 to increase it, according to the zigbee specification.
When you give it to save the new value, it activates the movement in the sensor at the same time so that it wakes up
Yeah!
Here is the log for lower:
2022-09-29T21:40:41.758363230+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> received command: {"args":{"value":"Read"},"capability":"legendabsolute60149.sensorSensitivity","command":"setSensorSensitivity","component":"main","positional_args":["Read"]}
2022-09-29T21:40:41.768219230+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-09-29T21:40:41.776183897+00:00 PRINT Zigbee Motion Sensor Test command.args.value >>>>> Read
2022-09-29T21:40:41.782436230+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> emitting event: {"attribute_id":"sensorSensitivity","capability_id":"legendabsolute60149.sensorSensitivity","component_id":"main","state":{"value":"Read Attribute"}}
2022-09-29T21:40:41.838110897+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T21:40:57.371948571+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-09-29T21:41:02.399450907+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T21:41:02.411715240+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> received lifecycle event: infoChanged
2022-09-29T21:41:02.423405907+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T21:41:02.428829240+00:00 PRINT Zigbee Motion Sensor Test ***** infoChanged *********
2022-09-29T21:41:02.434487907+00:00 PRINT Zigbee Motion Sensor Test Manufacturer, Model _TZ3000_msl6wxk9 TS0202
2022-09-29T21:41:02.439994573+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= 1 preferences: motionSensitivity
2022-09-29T21:41:02.445395573+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> motionSensitivity 2 1
2022-09-29T21:41:02.451513573+00:00 PRINT Zigbee Motion Sensor Test <<< Write restore state >>>
2022-09-29T21:41:02.458946907+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x01 > > > >
2022-09-29T21:41:02.495879240+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= preferences: version
2022-09-29T21:41:02.509499573+00:00 PRINT Zigbee Motion Sensor Test Device ID >>> <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)>
2022-09-29T21:41:02.521921907+00:00 PRINT Zigbee Motion Sensor Test Manufacturer >>> _TZ3000_msl6wxk9 Manufacturer_Len >>> 16
2022-09-29T21:41:02.531194573+00:00 PRINT Zigbee Motion Sensor Test Model >>> TS0202 Model_len >>> 6
2022-09-29T21:41:02.543064907+00:00 PRINT Zigbee Motion Sensor Test Memory >>>>>>> 1061.9619140625 Kbytes
2022-09-29T21:41:02.549288240+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
Here is the increase:
2022-09-29T21:42:13.869603607+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-09-29T21:42:13.882617941+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> received lifecycle event: infoChanged
2022-09-29T21:42:13.894240274+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-09-29T21:42:13.899860274+00:00 PRINT Zigbee Motion Sensor Test ***** infoChanged *********
2022-09-29T21:42:13.905453941+00:00 PRINT Zigbee Motion Sensor Test Manufacturer, Model _TZ3000_msl6wxk9 TS0202
2022-09-29T21:42:13.910746274+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= 20 preferences: motionSensitivity
2022-09-29T21:42:13.916337941+00:00 PRINT Zigbee Motion Sensor Test << Preference changed: name, old, new >> motionSensitivity 1 20
2022-09-29T21:42:13.922199274+00:00 PRINT Zigbee Motion Sensor Test <<< Write restore state >>>
2022-09-29T21:42:13.929420274+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x14 > > > >
2022-09-29T21:42:13.948180941+00:00 PRINT Zigbee Motion Sensor Test device.preferences[infoChanged]= preferences: version
2022-09-29T21:42:13.962040941+00:00 PRINT Zigbee Motion Sensor Test Device ID >>> <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)>
2022-09-29T21:42:13.969618941+00:00 PRINT Zigbee Motion Sensor Test Manufacturer >>> _TZ3000_msl6wxk9 Manufacturer_Len >>> 16
2022-09-29T21:42:13.975696607+00:00 PRINT Zigbee Motion Sensor Test Model >>> TS0202 Model_len >>> 6
2022-09-29T21:42:13.981532941+00:00 PRINT Zigbee Motion Sensor Test Memory >>>>>>> 1062.0205078125 Kbytes
2022-09-29T21:42:13.986774607+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T21:42:13.994213274+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T21:42:17.004553276+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-09-29T21:42:27.402573947+00:00 INFO Zigbee Motion Sensor Test Doing health check read for [6743]:0500:0002
2022-09-29T21:42:27.410595281+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: 7012f74e-1a2f-4a08-a41d-8d8e2d20277b [0x6743] (Sensor da Escada)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
It is not seen that the device has answered.
He may not have been awake
Now the one who is asleep is me , I think Iβm going to leave him.
If you want to keep playing see if you notice a change in sensitivity and Iβll see it tomorrow
If you want you can delete some log of those that have not served and are no longer valid
Hi @dotan_shai
Added to this driver version
From now on I will only update the driver Zigbee Multi Switch and Child Mc, it works fine
Name Zigbee Multi Switch and Child Mc
Version 2022-09-30T16:01:56.753434227
- id: "TS0002/_TYZB01_01gpyda5"
deviceLabel: TS0002 Switch
manufacturer: _TYZB01_01gpyda5
model: TS0002
deviceProfileName: two-switch
It seem that only when device is in pairing process or wake up then acept new values
Published a driver version that write the level sensitivity during pairing configuration
Then if you want to change the value:
- Write it in preferences
- And unpair and pair device again
- Check the new value appears in custom capability after paired
Version 2022-09-30T15:36:06.03917933
Hello,
Does anyone know how to add the Lidl Silvercrest smart button?
Sorry if question has been raised before, Iβve searched the forum and Iβve tried many drivers but the button shows up as zigbee switch.
- application: 47
- endpointId: 01
- manufacturer: _TZ3000_rco1yzb1
- model: TS004F
- zigbeeNodeType: SLEEPY_END_DEVICE
thanks in advance
Hi @Mariano_Colmenarejo, sorry for lateβ¦
I noticed that it shows me a behaviour like a range 0,01 to 0,02:
2022-10-02T14:13:12.485241080+00:00 TRACE Zigbee Motion Sensor Test Setup driver zigbee-motion with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee-motion
default_handlers:
driverSwitched:
doConfigure:
init:
infoChanged:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> Aurora Motion Sensor
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> ikea motion sensor
default_handlers:
doConfigure:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> Iris Motion Handler
default_handlers:
doConfigure:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> GatorSystem Handler
default_handlers:
doConfigure:
added:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> Motion Timeout Handler
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> NYCE Motion Handler
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> zigbee plugin motion sensor
default_handlers:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> SmartThings multi sensor
default_handlers:
init:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> MultiSensor
default_handlers:
doConfigure:
child_dispatchers:
DeviceLifecycleDispatcher: zigbee-motion -> FRIENT Motion Handler
default_handlers:
added:
child_dispatchers:
2022-10-02T14:13:12.521120132+00:00 TRACE Zigbee Motion Sensor Test Setup driver zigbee-motion with Capability handlers:
CapabilityCommandDispatcher: zigbee-motion
default_handlers:
refresh:
refresh
legendabsolute60149.sensorSensitivity:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> Aurora Motion Sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> ikea motion sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> Iris Motion Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> GatorSystem Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> Motion Timeout Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> NYCE Motion Handler
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> zigbee plugin motion sensor
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> SmartThings multi sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> MultiSensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: zigbee-motion -> FRIENT Motion Handler
default_handlers:
child_dispatchers:
2022-10-02T14:13:12.573708491+00:00 TRACE Zigbee Motion Sensor Test Setup driver zigbee-motion with Zigbee handlers:
ZigbeeMessageDispatcher: zigbee-motion
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
ZclClusterAttributeValueHandler: cluster: IlluminanceMeasurement, attribute: MeasuredValue
ZclClusterAttributeValueHandler: cluster: RelativeHumidity, attribute: MeasuredValue
ZclClusterAttributeValueHandler: cluster: OccupancySensing, attribute: Occupancy
ZclClusterAttributeValueHandler: cluster: IASZone, attribute: NumberOfZoneSensitivityLevelsSupported
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> Aurora Motion Sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> ikea motion sensor
default_handlers:
attr:
global:
cluster:
ZclClusterCommandHandler: cluster: OnOff, command: OnWithTimedOff
zdo:
ZdoHandler
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> Iris Motion Handler
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> GatorSystem Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> Motion Timeout Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> NYCE Motion Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> zigbee plugin motion sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> SmartThings multi sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> MultiSensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: zigbee-motion -> FRIENT Motion Handler
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
2022-10-02T14:13:12.756482392+00:00 TRACE Zigbee Motion Sensor Test Zigbee Device: dd2c2362-9ce2-4291-98f7-31549b9cbada
2022-10-02T14:13:12.814475381+00:00 TRACE Zigbee Motion Sensor Test Received event with handler _resync
2022-10-02T14:13:12.831505861+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-10-02T14:13:12.868394741+00:00 DEBUG Zigbee Motion Sensor Test driver device thread event handled
2022-10-02T14:13:13.047818651+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-10-02T14:13:13.062055196+00:00 PRINT Zigbee Motion Sensor Test <<<<<< write and Read sensibility attributtes >>>>>>
2022-10-02T14:13:13.080040865+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> emitting event: {"attribute_id":"sensorSensitivity","capability_id":"legendabsolute60149.sensorSensitivity","component_id":"main","state":{"value":" "}}
2022-10-02T14:13:13.113301893+00:00 PRINT Zigbee Motion Sensor Test <<< Write Sensitivity Level >>>
2022-10-02T14:13:13.137877266+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0013, DataType: Uint8, data: 0x02 > > > >
2022-10-02T14:13:13.197383165+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:13.212096804+00:00 TRACE Zigbee Motion Sensor Test Received event with handler environment_info
2022-10-02T14:13:13.226018840+00:00 DEBUG Zigbee Motion Sensor Test Z-Wave hub node ID environment changed.
2022-10-02T14:13:13.257994177+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:13.271848580+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-10-02T14:13:13.285741297+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received lifecycle event: added
2022-10-02T14:13:13.303239876+00:00 TRACE Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received unhandled lifecycle event: added
2022-10-02T14:13:13.317709305+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:13.331584697+00:00 TRACE Zigbee Motion Sensor Test Received event with handler device_lifecycle
2022-10-02T14:13:13.345468085+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received lifecycle event: doConfigure
2022-10-02T14:13:13.363281840+00:00 TRACE Zigbee Motion Sensor Test Found DeviceLifecycleDispatcher handler in zigbee-motion
2022-10-02T14:13:13.389875537+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-10-02T14:13:13.416454907+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-10-02T14:13:13.454433575+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-10-02T14:13:13.497479375+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13887A1CC8BC4, src_endpoint: 0x01, cluster: PowerConfiguration, dest_addr_mode: 0x03, dest_address: 286D97000200A55F, dest_endpoint: 0x01 > > >
2022-10-02T14:13:13.541048246+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0021, DataType: Uint8, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x5460, reportable_change: 0x01 > > > >
2022-10-02T14:13:13.595724894+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13887A1CC8BC4, src_endpoint: 0x01, cluster: IASZone, dest_addr_mode: 0x03, dest_address: 286D97000200A55F, dest_endpoint: 0x01 > > >
2022-10-02T14:13:13.644935610+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0002, DataType: Bitmap16, minimum_reporting_interval: 0x001E, maximum_reporting_interval: 0x012C > > > >
2022-10-02T14:13:13.681257107+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0010, DataType: IEEEAddress, data: 286D97000200A55F > > > >
2022-10-02T14:13:13.738523792+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < ZoneEnrollResponse || EnrollResponseCode: SUCCESS, zone_id: 0x00 > > >
2022-10-02T14:13:13.768687036+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:13.796721679+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-10-02T14:13:13.829311709+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x67, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0xF001, DataType: Uint8, Uint8: 0x00 > > > >
2022-10-02T14:13:13.908421801+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:13.922649350+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
> 2022-10-02T14:13:13.947536234+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x68, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0013, DataType: Uint8, CurrentZoneSensitivityLevel: 0x01 > > > >
2022-10-02T14:13:13.998958177+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:14.069947331+00:00 TRACE Zigbee Motion Sensor Test Received event with handler capability
2022-10-02T14:13:14.195446550+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:14.307755701+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
2022-10-02T14:13:14.465990544+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x90, rssi: -64, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x33, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-10-02T14:13:14.813121225+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-10-02T14:13:14.961019239+00:00 TRACE Zigbee Motion Sensor Test Found CapabilityCommandDispatcher handler in zigbee-motion
2022-10-02T14:13:15.025555621+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0021 > > >
2022-10-02T14:13:15.158148958+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6743, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-10-02T14:13:15.238124284+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:15.274869902+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
> 2022-10-02T14:13:15.306748955+00:00 INFO Zigbee Motion Sensor Test <ZigbeeDevice: dd2c2362-9ce2-4291-98f7-31549b9cbada [0x6743] (TS0202 Motion Sensor)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6743, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0x8C, rssi: -65, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x69, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0013, DataType: Uint8, CurrentZoneSensitivityLevel: 0x02 > > > >
2022-10-02T14:13:15.375455917+00:00 DEBUG Zigbee Motion Sensor Test TS0202 Motion Sensor device thread event handled
2022-10-02T14:13:15.405556193+00:00 TRACE Zigbee Motion Sensor Test Received event with handler zigbee
Hi @Dienzora
Please pierces the format </> to the logs, I see them much better with the format "that adjusts the lines to the screen.
It seems that the value 2 has written well.
Well now put the value 3 and meet again to see Silo writes well.
Are you Noted behavior difference of greater or lesser sensitivity in the sensor?
Hi mariano @Mariano_Colmenarejo
I got a new module today of 2CH zigbee switch
can you add to your drive my finger
- manufacturer: _TZ3000_zmy4lslw
- model: TS0002
Raw Description 01 0104 0100 01 09 0003 0004 0005 0006 0702 0B04 E000 E001 0000 02 0019 000A
appreciate your supporting!
thanks
