Mind blown
Okay, this right here is reason enough to switch back to ST. So youβre saying ST will load an edge driver automatically with a newly paired device, if the driver exists?
Or does it only happen with an existing device using a DTH, once the switch over to Edge is complete?
Correct, it loads automatically. I was working on getting a device added to my hub the other day that has both a zigbee switch and zwave repeater built in (an Iris 3210 plug). I never used the zwave repeater, and when joining the device to my hub ST added the Zwave Repeater driver for me because of a fingerprint match by either manufacturer or generic capabilities.
Hi @3asmarthome
Added to this driver version
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Multi Switch Mc β
β Version β 2022-09-17T11:10:12.016101676 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "3A Smart/LXN-4S27LX1.0"
deviceLabel: 3A Smart 4 Switch
manufacturer: 3A Smart Home DE
model: LXN-4S27LX1.0
deviceProfileName: four-switch
I have that Iris plug with a Z wave repeater youβre referring to.
I was going to take a passive approach and let smart things change it over to an edge driver.
Hi everyone,
There is some Garage Door Driver for opener?
@Mariano_Colmenarejo if note, have you any plan to develop this ?
Thanks in advance.
I did the same. As part of the beta program mine were migrated, and that part went fine. It was when one of mine went offline and wouldnβt return that I removed it and had problems.
Hi @mob422
I added the same fingerprints model and manufacturer and works fine.
Is diferent brand, Australian versiΓ³n.
I think there is for other countries too
This is the device that I hadβ¦
But I returned as it wasnβt functional as you know!
Thanks anyway Mariano
If you buy a similar one from another brand you can try it with the driver that has the fingerprints
Hi @Mariano_Colmenarejo, can you please add these devices below in the driver Zigbee Contact Mc?
Device: Tuya Door & Window Sensor
Hi @Mariano_Colmenarejo, can you please add these devices below in the driver Zigbee Temperature & humidity sensor
β Name β Zigbee Contact Mc β
β Version β 2022-09-19T18:21:03.010612896 β
- id: "_TZ3000_f1hmoyj4/Close Sensor"
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_f1hmoyj4
model: TS0203
deviceProfileName: contact-battery-profile
β Name β Zigbee Temp Humidity Sensor Mc β
β Version β 2022-09-19T18:24:40.914818433 β
- id: "_TZ3000_dowj6gyi/TS0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ3000_dowj6gyi
model: TS0201
deviceProfileName: temp-humid-battery
Hi @Mariano_Colmenarejo youβve been a life saver. Iβm megrating my devices to edge drivers and your drivers have helped me a lot.
I have 3 gang zemismart switch and its not been assigned to your zigbee multi switch mc, its only recognized as thing. Could you add its fingerprint into your driver
Data * application: 84
- endpointId: 01
- manufacturer: _TZ3000_wqfdvxen
- model: TS0003
- zigbeeNodeType: ROUTER
Raw Description 01 0104 0100 01 04 0000 0004 0005 0006 02 0019 000A
Added to these driver version
β Name β Zigbee Multi Switch and Childs Mc β
β Version β 2022-09-22T21:18:45.20235081 β
β Version β 2022-09-22T21:18:52.375553118 β
- id: "TS0003/_TZ3000_wqfdvxen"
deviceLabel: TS0003 Switch
model: TS0003
deviceProfileName: three-switch
Hi @Bnigro
This device use Tuya cluster EF00 and not works with my driver.
I do no known if @ygerlovin has a compatible driver
I have added a SmartThings v4 MultiSensor using the st-multipurpose-sensor-v2 driver. Contact sensor and temperature are working fine but 3 axis and vibration are blank and report βthere was a problem connectingβ on refresh. Live logging via the CLI reacts to temperature and battery events but nothing when I move or tap the sensor.
The same sensor reports axis and vibration OK with the old DTH. Iβve tried removing and re-adding the sensor, removing the battery, leaving it for 15 mins, restarting the app but nothing has helped.
Any ideas?
