Mariano_Colmenarejo:
Hi @hellodave
Please Could you send me log with new version to confirm the issue is fixed?
I’m going to sleep, tomorrow more things
Log below:
2022-09-26T22:38:29.908654291+00:00 TRACE SmartThings Multipurpose Sensor Mc Setup driver smartthingsMultipurposeSensor with lifecycle handlers:
DeviceLifecycleDispatcher: smartthingsMultipurposeSensor
default_handlers:
infoChanged:
doConfigure:
init:
driverSwitched:
child_dispatchers:
DeviceLifecycleDispatcher: smartthingsMultipurposeSensor -> SmartThings multi sensor
default_handlers:
added:
child_dispatchers:
DeviceLifecycleDispatcher: smartthingsMultipurposeSensor -> MultiSensor
default_handlers:
doConfigure:
child_dispatchers:
2022-09-26T22:38:29.912888082+00:00 TRACE SmartThings Multipurpose Sensor Mc Setup driver smartthingsMultipurposeSensor with Capability handlers:
CapabilityCommandDispatcher: smartthingsMultipurposeSensor
default_handlers:
refresh:
refresh
child_dispatchers:
CapabilityCommandDispatcher: smartthingsMultipurposeSensor -> SmartThings multi sensor
default_handlers:
child_dispatchers:
CapabilityCommandDispatcher: smartthingsMultipurposeSensor -> MultiSensor
default_handlers:
child_dispatchers:
2022-09-26T22:38:29.919379374+00:00 TRACE SmartThings Multipurpose Sensor Mc Setup driver smartthingsMultipurposeSensor with Zigbee handlers:
ZigbeeMessageDispatcher: smartthingsMultipurposeSensor
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0010
ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0014
ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0012
ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0013
global:
cluster:
ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: smartthingsMultipurposeSensor -> SmartThings multi sensor
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
ZigbeeMessageDispatcher: smartthingsMultipurposeSensor -> MultiSensor
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: TemperatureMeasurement, attribute: MeasuredValue
global:
cluster:
zdo:
child_dispatchers:
2022-09-26T22:38:29.951772707+00:00 TRACE SmartThings Multipurpose Sensor Mc Zigbee Device: e954056f-af96-4640-9960-9506f233381a
Manufacturer: SmartThings Model: multiv4
[1]: Basic, PowerConfiguration, Identify, BasicInput, PollControl, TemperatureMeasurement, IASZone, 0xFC02
2022-09-26T22:38:29.955950916+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler _resync
2022-09-26T22:38:29.958892666+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler environment_info
2022-09-26T22:38:29.967303291+00:00 DEBUG SmartThings Multipurpose Sensor Mc driver device thread event handled
2022-09-26T22:38:29.971536916+00:00 TRACE SmartThings Multipurpose Sensor Mc Found DeviceLifecycleDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:29.979852791+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:29.983553999+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler environment_info
2022-09-26T22:38:29.986574499+00:00 DEBUG SmartThings Multipurpose Sensor Mc Z-Wave hub node ID environment changed.
2022-09-26T22:38:29.990525874+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:29.993659582+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler device_lifecycle
2022-09-26T22:38:29.996995707+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received lifecycle event: added
2022-09-26T22:38:30.001360957+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:30.004532624+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler device_lifecycle
2022-09-26T22:38:30.007643332+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received lifecycle event: driverSwitched
2022-09-26T22:38:30.013273124+00:00 TRACE SmartThings Multipurpose Sensor Mc Found DeviceLifecycleDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:30.016817291+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:30.021996582+00:00 TRACE SmartThings Multipurpose Sensor Mc Found DeviceLifecycleDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:30.025032332+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:30.034597166+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:30.119240374+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler capability
2022-09-26T22:38:30.128683707+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2022-09-26T22:38:30.132094832+00:00 TRACE SmartThings Multipurpose Sensor Mc Found CapabilityCommandDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:30.159280957+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0020 > > >
2022-09-26T22:38:30.166724082+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-26T22:38:30.177887249+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:30.246520457+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler device_lifecycle
2022-09-26T22:38:30.252799666+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received lifecycle event: infoChanged
2022-09-26T22:38:30.258968374+00:00 TRACE SmartThings Multipurpose Sensor Mc Found DeviceLifecycleDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:30.261989207+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 0.0 preferences: tempOffset
2022-09-26T22:38:30.265065374+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 630 preferences: accelThresholdST
2022-09-26T22:38:30.268334291+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 2 preferences: accelThresholdCentralite
2022-09-26T22:38:30.271341916+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= No preferences: garageSensor
2022-09-26T22:38:30.274263291+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= Multi preferences: changeProfile
2022-09-26T22:38:30.277230832+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 5 preferences: maxTime
2022-09-26T22:38:30.280053457+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 20 preferences: accelThreshold
2022-09-26T22:38:30.282851999+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= preferences: version
2022-09-26T22:38:30.285849541+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 3 preferences: garageSensorAxis
2022-09-26T22:38:30.288911582+00:00 PRINT SmartThings Multipurpose Sensor Mc device.preferences[infoChanged]= 10 preferences: changeRep
2022-09-26T22:38:30.291713124+00:00 PRINT SmartThings Multipurpose Sensor Mc <<<<< Firmware Version >>>>>
2022-09-26T22:38:30.294628957+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:32.988196333+00:00 PRINT SmartThings Multipurpose Sensor Mc <<<<< added >>>>>
2022-09-26T22:38:32.991302666+00:00 PRINT SmartThings Multipurpose Sensor Mc <<< Configure three axis >>>
2022-09-26T22:38:32.996494333+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 24FD5B000109C3C4, src_endpoint: 0x01, cluster: 0xFC02, dest_addr_mode: 0x03, dest_address: D052A8A1D98E0001, dest_endpoint: 0x01 > > >
2022-09-26T22:38:33.004052666+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: 24FD5B000109C3C4, src_endpoint: 0x01, cluster: 0xFC02, dest_addr_mode: 0x03, dest_address: D052A8A1D98E0001, dest_endpoint: 0x01 > > >
2022-09-26T22:38:33.019901916+00:00 PRINT SmartThings Multipurpose Sensor Mc <<<<< configure_accel_threshold >>>>>
2022-09-26T22:38:33.025709708+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0000, DataType: Uint8, data: 0x01 > > > >
2022-09-26T22:38:33.033968249+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x0002, DataType: Uint16, data: 0x0276 > > > >
2022-09-26T22:38:33.045463833+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.735242750+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.742924041+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xFF, rssi: -55, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0020, ZclStatus: SUCCESS, DataType: Uint8, BatteryVoltage: 0x1A > > > >
2022-09-26T22:38:34.758116208+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:34.763668291+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
2022-09-26T22:38:34.770195041+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"battery","capability_id":"battery","component_id":"main","state":{"value":100}}
2022-09-26T22:38:34.785737083+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.790133833+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.797118375+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -55, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0002, ZclStatus: SUCCESS, DataType: Bitmap16, ZoneStatus: 0x0020 > > > >
2022-09-26T22:38:34.815068041+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:34.822829125+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-09-26T22:38:34.826944958+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"closed"}}
2022-09-26T22:38:34.840516375+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.844551583+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.848760625+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -55, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x06 >, < BindRequestResponse || status: 0x00 > > >
2022-09-26T22:38:34.859400625+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.863239333+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.868955500+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -55, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x07 >, < BindRequestResponse || status: 0x00 > > >
2022-09-26T22:38:34.878956083+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.882080208+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.888167791+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x20, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-09-26T22:38:34.899351375+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:34.908886+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:34.913311375+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x21, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-09-26T22:38:34.924074+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:35.992727083+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0020 > > >
2022-09-26T22:38:36.005013958+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0002 > > >
2022-09-26T22:38:36.014964916+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0010 > > >
2022-09-26T22:38:36.025563458+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0014 > > >
2022-09-26T22:38:36.033310041+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0012 > > >
2022-09-26T22:38:36.041552750+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x6A86, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x04, mfg_code: 0x110A, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0013 > > >
2022-09-26T22:38:36.056749833+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.218972334+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.223737209+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xFF, rssi: -55, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x22, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0020, ZclStatus: SUCCESS, DataType: Uint8, BatteryVoltage: 0x1A > > > >
2022-09-26T22:38:42.238244292+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:42.241265+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
2022-09-26T22:38:42.244987+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"battery","capability_id":"battery","component_id":"main","state":{"value":100}}
2022-09-26T22:38:42.258044292+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.262933917+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.267760792+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xFF, rssi: -55, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x23, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0002, ZclStatus: SUCCESS, DataType: Bitmap16, ZoneStatus: 0x0020 > > > >
2022-09-26T22:38:42.277459042+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor
2022-09-26T22:38:42.282711042+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2022-09-26T22:38:42.287003125+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"closed"}}
2022-09-26T22:38:42.297914334+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.302588875+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.307376125+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x24, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0010, ZclStatus: SUCCESS, DataType: Bitmap8, Bitmap8: 0x00 > > > >
2022-09-26T22:38:42.319078167+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:42.322010209+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0010
2022-09-26T22:38:42.327583042+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"acceleration","capability_id":"accelerationSensor","component_id":"main","state":{"value":"inactive"}}
2022-09-26T22:38:42.338487167+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.346112250+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.351059667+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x25, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0014, ZclStatus: SUCCESS, DataType: Int16, Int16: -3 > > > >
2022-09-26T22:38:42.360073084+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:42.363231875+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0014
2022-09-26T22:38:42.366592209+00:00 TRACE SmartThings Multipurpose Sensor Mc current_value {1=-3, 2=13, 3=-1058}
2022-09-26T22:38:42.370111+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"threeAxis","capability_id":"threeAxis","component_id":"main","state":{"value":[-3,13,-1058]}}
2022-09-26T22:38:42.380933542+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.384676959+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.389315292+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x26, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0012, ZclStatus: SUCCESS, DataType: Int16, Int16: 1055 > > > >
2022-09-26T22:38:42.398404625+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:42.401312334+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0012
2022-09-26T22:38:42.405363250+00:00 TRACE SmartThings Multipurpose Sensor Mc current_value {1=-3, 2=13, 3=-1055}
2022-09-26T22:38:42.408797167+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"threeAxis","capability_id":"threeAxis","component_id":"main","state":{"value":[-3,13,-1055]}}
2022-09-26T22:38:42.420203750+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:42.423233+00:00 TRACE SmartThings Multipurpose Sensor Mc Received event with handler zigbee
2022-09-26T22:38:42.427831834+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x6A86, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFC02 >, lqi: 0xFF, rssi: -55, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x110A, seqno: 0x27, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0013, ZclStatus: SUCCESS, DataType: Int16, Int16: 12 > > > >
2022-09-26T22:38:42.438190125+00:00 TRACE SmartThings Multipurpose Sensor Mc Found ZigbeeMessageDispatcher handler in smartthingsMultipurposeSensor -> SmartThings multi sensor
2022-09-26T22:38:42.441411459+00:00 INFO SmartThings Multipurpose Sensor Mc Executing ZclClusterAttributeValueHandler: cluster: 0xFC02, attribute: 0x0013
2022-09-26T22:38:42.444833250+00:00 TRACE SmartThings Multipurpose Sensor Mc current_value {1=-3, 2=12, 3=-1055}
2022-09-26T22:38:42.448256625+00:00 INFO SmartThings Multipurpose Sensor Mc <ZigbeeDevice: e954056f-af96-4640-9960-9506f233381a [0x6A86] (Inner Front Door)> emitting event: {"attribute_id":"threeAxis","capability_id":"threeAxis","component_id":"main","state":{"value":[-3,12,-1055]}}
2022-09-26T22:38:42.458819125+00:00 DEBUG SmartThings Multipurpose Sensor Mc Inner Front Door device thread event handled
2022-09-26T22:38:59.930050378+00:00 DEBUG SmartThings Multipurpose Sensor Mc driver device thread event handled
