Here’s the driver change log…
2022-09-09T15:54:16.848423644+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Multi_Switch
default_handlers:
infoChanged:
init:
driverSwitched:
doConfigure:
child_dispatchers:
2022-09-09T15:54:16.852379269+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Multi_Switch
default_handlers:
switch:
on
off
legendabsolute60149.switchAllOnOff1:
setSwitchAllOnOff
refresh:
refresh
child_dispatchers:
2022-09-09T15:54:16.857685019+00:00 TRACE Zigbee Multi Switch Test Setup driver Zigbee_Multi_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Multi_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
zdo:
child_dispatchers:
2022-09-09T15:54:16.882748894+00:00 TRACE Zigbee Multi Switch Test Zigbee Device: 9fea3863-e328-4bbd-b29f-d58be9bf3999
Manufacturer: _TZ3000_cfnprab5 Model: TS011F
[1]: Identify, Groups, Scenes, OnOff, 0xE000, 0xE001, Basic [2]: Groups, Scenes, OnOff, 0xE001 [3]: Groups, Scenes, OnOff, 0xE001 [4]: Groups, Scenes, OnOff, 0xE001 [5]: Groups, Scenes, OnOff, 0xE001 [242]:
2022-09-09T15:54:16.887130810+00:00 DEBUG Zigbee Multi Switch Test driver device thread event handled
2022-09-09T15:54:16.890409144+00:00 TRACE Zigbee Multi Switch Test Received event with handler _resync
2022-09-09T15:54:16.893315060+00:00 TRACE Zigbee Multi Switch Test Received event with handler environment_info
2022-09-09T15:54:16.900691310+00:00 TRACE Zigbee Multi Switch Test Received event with handler environment_info
2022-09-09T15:54:16.903775935+00:00 DEBUG Zigbee Multi Switch Test Z-Wave hub node ID environment changed.
2022-09-09T15:54:16.907094060+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:16.916211685+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-09-09T15:54:16.923029727+00:00 PRINT Zigbee Multi Switch Test << Preference name: >> changeProfileFourPlug Preference value: Multi
2022-09-09T15:54:16.940447727+00:00 PRINT Zigbee Multi Switch Test << Preference name: >> signalMetricsVisibles Preference value: Yes
2022-09-09T15:54:16.943252935+00:00 PRINT Zigbee Multi Switch Test << Preference name: >> version Preference value:
2022-09-09T15:54:16.946173227+00:00 PRINT Zigbee Multi Switch Test << Preference name: >> restoreState Preference value: 255
2022-09-09T15:54:16.949162977+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:16.956325144+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-09-09T15:54:16.959688060+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received lifecycle event: added
2022-09-09T15:54:16.968254185+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-09-09T15:54:16.971257352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received lifecycle event: driverSwitched
2022-09-09T15:54:16.974858102+00:00 TRACE Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received unhandled lifecycle event: added
2022-09-09T15:54:16.977886644+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:16.982542935+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:16.988304227+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-09-09T15:54:16.996440894+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-09-09T15:54:17.023676560+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-09-09T15:54:17.032162019+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x04, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-09-09T15:54:17.050380394+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x05, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-09-09T15:54:17.067865019+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13864D68BF3AF, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A362490001, dest_endpoint: 0x01 > > >
2022-09-09T15:54:17.077233352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-09-09T15:54:17.093729519+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x02, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13864D68BF3AF, src_endpoint: 0x02, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A362490001, dest_endpoint: 0x01 > > >
2022-09-09T15:54:17.103450352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x02, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-09-09T15:54:17.116548269+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x03, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13864D68BF3AF, src_endpoint: 0x03, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A362490001, dest_endpoint: 0x01 > > >
2022-09-09T15:54:17.132183352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x03, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-09-09T15:54:17.161323977+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x04, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13864D68BF3AF, src_endpoint: 0x04, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A362490001, dest_endpoint: 0x01 > > >
2022-09-09T15:54:17.178239352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x04, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-09-09T15:54:17.188754935+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x05, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C13864D68BF3AF, src_endpoint: 0x05, cluster: OnOff, dest_addr_mode: 0x03, dest_address: D052A8A362490001, dest_endpoint: 0x01 > > >
2022-09-09T15:54:17.208521769+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xD8A1, dest_endpoint: 0x05, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-09-09T15:54:17.215094102+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.218807102+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.230233810+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -35, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x5E, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x20, group_list_length: 0x00 > > >
2022-09-09T15:54:17.246954435+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.253475519+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xFF, rssi: -35, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5E, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x02, ZclStatus: SUCCESS > > >
2022-09-09T15:54:17.261409269+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.265394644+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.271861185+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x5F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-09-09T15:54:17.279981144+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.283758144+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.290848894+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x60, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-09-09T15:54:17.304316144+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.314071769+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-09-09T15:54:17.317282477+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-09-09T15:54:17.320660352+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“dni: 0xD8A1, lqi: 255, rssi: -35dBm”},“visibility”:{“displayed”:true}}
2022-09-09T15:54:17.334054769+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-09-09T15:54:17.354137227+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 1 value = true
2022-09-09T15:54:17.361007352+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.365934227+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.370991894+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x61, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-09-09T15:54:17.378587977+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.381479144+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-09-09T15:54:17.384625560+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-09-09T15:54:17.388056727+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“dni: 0xD8A1, lqi: 255, rssi: -35dBm”},“visibility”:{“displayed”:true}}
2022-09-09T15:54:17.397755602+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch2”,“state”:{“value”:“on”}}
2022-09-09T15:54:17.417627769+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 2 value = true
2022-09-09T15:54:17.431757894+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.435825477+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.440750102+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x04, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x62, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-09-09T15:54:17.459428977+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.463718685+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.474771602+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x63, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-09-09T15:54:17.494480144+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.504322477+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-09-09T15:54:17.514631060+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-09-09T15:54:17.554864185+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“dni: 0xD8A1, lqi: 255, rssi: -35dBm”},“visibility”:{“displayed”:true}}
2022-09-09T15:54:17.570587269+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch3”,“state”:{“value”:“on”}}
2022-09-09T15:54:17.607797352+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 3 value = true
2022-09-09T15:54:17.615286227+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.634838102+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.639235227+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -35, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x07 >, < BindRequestResponse || status: 0x00 > > >
2022-09-09T15:54:17.688588519+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.692892519+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.699145060+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x64, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-09-09T15:54:17.714303519+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.717472019+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-09-09T15:54:17.723033185+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-09-09T15:54:17.726796185+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“dni: 0xD8A1, lqi: 255, rssi: -35dBm”},“visibility”:{“displayed”:true}}
2022-09-09T15:54:17.743307185+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“switch4”,“state”:{“value”:“on”}}
2022-09-09T15:54:17.753786144+00:00 PRINT Zigbee Multi Switch Test src_endpoint = 4 value = true
2022-09-09T15:54:17.760880810+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.765025602+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.769510894+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -35, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x08 >, < BindRequestResponse || status: 0x00 > > >
2022-09-09T15:54:17.776958977+00:00 TRACE Zigbee Multi Switch Test Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.780053227+00:00 INFO Zigbee Multi Switch Test Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-09-09T15:54:17.783551894+00:00 PRINT Zigbee Multi Switch Test function: on_off_attr_handler
2022-09-09T15:54:17.786978935+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“dni: 0xD8A1, lqi: 255, rssi: -35dBm”},“visibility”:{“displayed”:true}}
2022-09-09T15:54:17.797464060+00:00 ERROR Zigbee Multi Switch Test AaaTS0004 Switch thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)>:
arg1: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x63, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
[string “st/device.lua”]:118: attempt to index a nil value (local ‘component’)
2022-09-09T15:54:17.803624602+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.814090435+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x65, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-09-09T15:54:17.827489852+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.831686644+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.837537769+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -35, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x09 >, < BindRequestResponse || status: 0x00 > > >
2022-09-09T15:54:17.844800644+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.848871019+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.854736894+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x03, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x66, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-09-09T15:54:17.862093560+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.866527935+00:00 TRACE Zigbee Multi Switch Test Received event with handler device_lifecycle
2022-09-09T15:54:17.877160185+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received lifecycle event: infoChanged
2022-09-09T15:54:17.880913894+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.885313894+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.890175435+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xFF, rssi: -35, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x0A >, < BindRequestResponse || status: 0x00 > > >
2022-09-09T15:54:17.898387310+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.902663894+00:00 TRACE Zigbee Multi Switch Test Received event with handler zigbee
2022-09-09T15:54:17.917359310+00:00 INFO Zigbee Multi Switch Test <ZigbeeDevice: 9fea3863-e328-4bbd-b29f-d58be9bf3999 [0xD8A1] (AaaTS0004 Switch)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xD8A1, src_endpoint: 0x04, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xFF, rssi: -35, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x67, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-09-09T15:54:17.925634894+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.948305602+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.954124894+00:00 DEBUG Zigbee Multi Switch Test AaaTS0004 Switch device thread event handled
2022-09-09T15:54:17.959746435+00:00 TRACE Zigbee Multi Switch Test Found DeviceLifecycleDispatcher handler in Zigbee_Multi_Switch
2022-09-09T15:54:17.962907644+00:00 PRINT Zigbee Multi Switch Test device.preferences[infoChanged]= Multi
2022-09-09T15:54:17.968042644+00:00 PRINT Zigbee Multi Switch Test << Preference changed name: changeProfileFourPlug oldPreferenceValue: nil newParameterValue: >> Multi
2022-09-09T15:54:17.975154144+00:00 PRINT Zigbee Multi Switch Test device.preferences[infoChanged]= Yes
2022-09-09T15:54:17.978292310+00:00 PRINT Zigbee Multi Switch Test << Preference changed name: signalMetricsVisibles oldPreferenceValue: nil newParameterValue: >> Yes
2022-09-09T15:54:17.981431810+00:00 PRINT Zigbee Multi Switch Test device.preferences[infoChanged]=
