There is a limit of 50 drivers (not devices). I would not load up on drivers because if itβs not there when adding a device, ST will add the driver unless the device isnt known to ST via its fingerprint.
Mind blown
Okay, this right here is reason enough to switch back to ST. So youβre saying ST will load an edge driver automatically with a newly paired device, if the driver exists?
Or does it only happen with an existing device using a DTH, once the switch over to Edge is complete?
Correct, it loads automatically. I was working on getting a device added to my hub the other day that has both a zigbee switch and zwave repeater built in (an Iris 3210 plug). I never used the zwave repeater, and when joining the device to my hub ST added the Zwave Repeater driver for me because of a fingerprint match by either manufacturer or generic capabilities.
Hi @3asmarthome
Added to this driver version
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Zigbee Multi Switch Mc β
β Version β 2022-09-17T11:10:12.016101676 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
- id: "3A Smart/LXN-4S27LX1.0"
deviceLabel: 3A Smart 4 Switch
manufacturer: 3A Smart Home DE
model: LXN-4S27LX1.0
deviceProfileName: four-switch
I have that Iris plug with a Z wave repeater youβre referring to.
I was going to take a passive approach and let smart things change it over to an edge driver.
Hi everyone,
There is some Garage Door Driver for opener?
@Mariano_Colmenarejo if note, have you any plan to develop this ?
Thanks in advance.
I did the same. As part of the beta program mine were migrated, and that part went fine. It was when one of mine went offline and wouldnβt return that I removed it and had problems.
Hi @mob422
I added the same fingerprints model and manufacturer and works fine.
Is diferent brand, Australian versiΓ³n.
I think there is for other countries too
This is the device that I hadβ¦
But I returned as it wasnβt functional as you know!
Thanks anyway Mariano
If you buy a similar one from another brand you can try it with the driver that has the fingerprints
Hi @Mariano_Colmenarejo, can you please add these devices below in the driver Zigbee Contact Mc?
Device: Tuya Door & Window Sensor
Hi @Mariano_Colmenarejo, can you please add these devices below in the driver Zigbee Temperature & humidity sensor
β Name β Zigbee Contact Mc β
β Version β 2022-09-19T18:21:03.010612896 β
- id: "_TZ3000_f1hmoyj4/Close Sensor"
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_f1hmoyj4
model: TS0203
deviceProfileName: contact-battery-profile
β Name β Zigbee Temp Humidity Sensor Mc β
β Version β 2022-09-19T18:24:40.914818433 β
- id: "_TZ3000_dowj6gyi/TS0201"
deviceLabel: Tuya TS0201
manufacturer: _TZ3000_dowj6gyi
model: TS0201
deviceProfileName: temp-humid-battery
Hi @Mariano_Colmenarejo youβve been a life saver. Iβm megrating my devices to edge drivers and your drivers have helped me a lot.
I have 3 gang zemismart switch and its not been assigned to your zigbee multi switch mc, its only recognized as thing. Could you add its fingerprint into your driver
Data * application: 84
- endpointId: 01
- manufacturer: _TZ3000_wqfdvxen
- model: TS0003
- zigbeeNodeType: ROUTER
Raw Description 01 0104 0100 01 04 0000 0004 0005 0006 02 0019 000A
Added to these driver version
β Name β Zigbee Multi Switch and Childs Mc β
β Version β 2022-09-22T21:18:45.20235081 β
β Version β 2022-09-22T21:18:52.375553118 β
- id: "TS0003/_TZ3000_wqfdvxen"
deviceLabel: TS0003 Switch
model: TS0003
deviceProfileName: three-switch
Hi @Bnigro
This device use Tuya cluster EF00 and not works with my driver.
I do no known if @ygerlovin has a compatible driver
