I purchased a ThirdReality light switch cover which allows for automating manual light switches.
I wouldn’t fill my rented house with these, but they are kind of fun.
They get installed using the default Zigbee Switch driver, but don’t report the battery level.
Here’s the info that is reported in the history tab.
I don’t have the CLI installed, but can install it if you need more details.
Yes, it must have been paired as a generic switch.
In the stock driver I have not seen any profile that has the battery capacity
Mine does not have any profile with battery either, I would have to create it and if it works with the battery percentage attribute, it would not be necessary to make a subdriver.
Hi @BlackRose67,
Added to this test version of the driver.
I did not add the change of icons because it would mean having to make 12 new profiles.
You can use the app edit and change icons tool
I also added the metrics of the last hop of the signal
If everything works fine I will merge it to the Mc driver
│ Name │ Zigbee Switch v6.5 │
│ Version │ 2022-06-01T15:41:42.506118264 │
- id: "Third Reality/3RSS009Z"
deviceLabel: Third Reality 3RSS009Z
manufacturer: Third Reality, Inc
model: 3RSS009Z
deviceProfileName: switch-battery-light
I installed the test driver and was able to assign it to the ThirdReality device without a problem.
The device only supports on and off for actions and is working great.
It’s also reporting battery percentage.
I also assigned the test driver to one of my Ikea Tradfri switches, and it’s also working fine for that.
I don’t have any switches that report energy monitoring, so couldn’t test that out.
The energy monitoring in this driver is virtual, that is, in preferences you enter the watts of the connected load and the driver makes a calculation of the power and energy consumed.
One more thing like to ask,
is there any way to make the card shows both Temp and Humidity, not only Temp data?
I am using ‘Zigbee Temp Humidity Sensor Mc’, shows only Temp data on the card.
I have a heavy duty innr plug with energy monitoring im trying to add via edge drive but it just keeps with the factory dth for an outlet. Any idea how to get it to add as a driver?
│ Name │ Zigbee Switch Power Mc │
│ Version │ 2022-06-21T12:10:43.15437696 │
