is loading the old dht. but i can’t delete it because i have about 20 of them and i want to change them little by little. is that why?
Yes this is the reason.
Enter in IDE DTH and put // prior of the fingerprint of the switch, save and publish for you.
// fingerprint endpointId: "01", profileId: "C05E", inClusters: "0000, 0004, 0003, 0006, 0005, 1000, 0008", outClusters: "0019", manufacturer: "FeiBit", model: "FNB56-ZSW03LX2.0", deviceJoinName: "Zemi ZigBee Switch 1"
The others paired switches will continue to work.
This will make the new switch not recognize the DTH
Multiple switch drivers have several drawbacks with DTHs:
- You only see a mosaic with the status of switch 1 (main)
- Only switch 1 (main) can be renamed
It has the advantage of working locally.
You could use virtual edge switches to mimic the state of switches 2 and 3
is this predicted to be corrected? be able to rename them and all appear in alexa?
how to create a virtual switch driver?
I don’t have much hope, to say the least.
In Tuya app they also work like this too.
If you have many multi switch it is a major problem.
Virtual switches can be created by installing one of two drivers
https://community.smartthings.com/t/st-edge-vedge-creator-a-virtual-device-generator-for-end-users/231786?u=mariano_colmenarejo
https://community.smartthings.com/t/st-edge-virtual-things-edge-driver/232875?u=mariano_colmenarejo
Then you have to do routines so that the virtual switch turns on and off when the real one does.
I leave it for today
Good evening.
I can no longer pair this device:
- id: “Innr SP 120”
deviceLabel: Innr Plug
manufacturer: innr
model: SP 120
with your driver:
Zigbee Switch Power Mc
Did you remove it?
I don’t remember removing any.
this innr exists in zigbee switch Mc
- id: "innr/Plug"
deviceLabel: innr Plug
manufacturer: innr
model: SP 222
deviceProfileName: single-switch-plug
If you want I add it
Added to Zigbee Switch Power Mc
│ Name │ Zigbee Switch Power Mc │
│ Version │ 2021-12-19T22:08:20.399646 │
- id: "Innr SP 120"
manufacturer: innr
model: SP 120
deviceProfileName: switch-power-energy-plug
before with the dth I read both power and energy
For smartthings water leak sensor not yet created, correct?
- application: 14
- endpointId: 01
- manufacturer: Samjin
- model: water
- zigbeeNodeType: SLEEPY_END_DEVICE
01 0104 0402 00 07 0000 0001 0003 0020 0402 0500 0B05 02 0003 0019
Correct.
If it’s smartthings, they will, I hope
Perfect.
on this one too I read both power and energy
It does not work?
Work well.
also on this one
- id: “SmartTings/outletv4”
deviceLabel: SmartTings outletv4
manufacturer: SmartTings
model: outletv4
J read energy and power in old dth
the correct id is this
- id: "SmartThings/outletv4"
deviceLabel: SmartThings outletv4
manufacturer: SmartThings
model: outletv4
and this driver version
│ Version │ 2021-12-19T23:01:46.974176 │
Grazie (Tanks)
Try this new version of zigbee switch power Mc to chek issue of 10x power meter
@Mariano_Colmenarejo when you create a device with more than one gang from the second onwards, switch2, switch3, etc. appears. Exiate some way to add something in that name to differentiate a switch2 from another switch2? I was following your advice to create virtuals but when mirroring the behavior appears more switch2, etc and I don’t know which is which.
