[Beta] Zigbee Edge Driver compatible with Lidl, Ecosmart, Osram, SmartThings & Others
@Joao_Santos,
I needed to see the logs of the pairing with the CLI to analyze what is happening.
Is this the right logs? Im sorry im not sure how to get them
In IDE events I see something strange, there is an event with an energy value and there is no power event, which I have also seen on a device installed yesterday by @norberto_bcn
You need install CLI un your computer yo see driver logs
Install CLI on your computer:
• You have to download from this link release 34 or greater of the compressed file smartthings-win.zip, if you use windows or the one necessary for your operating system
• In that link you also have installation help, use and all the commands you can use
smartthings-cli/packages/cli at master · SmartThingsCommunity/smartthings-cli - smartthings edge:channels:update [ID]
• Unzip it and move the smartthings.exe file to a folder on your computer from where it will be used. for example to a new folder in documents/CLI
• You have to open the windows powerShell terminal window and you have to go to the directory (folder) where the smarttings.exe file is.
• Use the DOS commands “cd…” to move down directory and “cd directory name” to move to that directory. This is an example of my folder for CLI or VSC folder
• the first time you type a CLI command it will take you to the smartthing page to authorize your account.
• type .\smartthings edge:drivers:logcat
• enter the IP of your HUB, you can see it in IDE
• It will show you the list of drivers installed on your HUB
• type the number corresponding to the driver you want to see
• It will show you the activity of the device connected to that driver
I cannot pass the step of authorize your account because everytime it gives me a " Failure trying to authenticate." message. And i’m sure i have the right IP. Am i doing something wrong?
What error does it give you?
Can you post a screenshot?
5 posts were split to a new topic: [SmartThings CLI] Issue with the authentication
Xiaomi power is reported in the AnalogInput (0x0C) cluster
Hi @veonua,
Thanh you for the Xiaomi info!
According to the fingerprint this device does not have the 0C cluster, it seems that it uses the standard 0702 and 0B04 clusters.
Until @Joao_Santos can sent the logs, I will not be able to see what the device is reporting.
In any case, something may be happening with the power and energy capabilities in the new app version, they do not report units until the value is greater than 0.
This device and another tuya TS011F are giving the same problem, they report total energy without reporting instantaneous power, it sounds strange to me!, especially the TS011F that had worked well for many users.
I think i finally got it.
Were these the logs you wanted?
Hi @Joao_Santos,
Yes, but i need see the pairing logs.
  • uninstall device with app.
  • start logcat cli
  • Add device with search nerby un app
  • you Will see the pairing logs in about 30 sec.
  • select the logs, copy and paste in the post
It creates a huge amount of logs. These were the first to appear.
Please, could you copy logs and paste as text?
It is difficult to see it on the mobile as a photo
Need more logs to see the device response
You’re right.
It has an endpoint 0x15, not shown in the IDE and driver endpoints, which is the analog input and sends the power through the 0x55 attribute.(present value)
I don’t know if it will also send it by 0x0702, when I see the response to the configuration
Sure, i didnt knew what logs to send because they are so many.
? Select a driver. 10
connecting… connected
2022-06-29T20:05:37.470448018+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Switch
default_handlers:
init:
removed:
doConfigure:
infoChanged:
driverSwitched:
child_dispatchers:
2022-06-29T20:05:37.479560351+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Switch
default_handlers:
energyMeter:
resetEnergyMeter
switch:
on
off
refresh:
refresh
legendabsolute60149.getGroups:
setGetGroups
legendabsolute60149.randomOnOff2:
setRandomOnOff
switchLevel:
setLevel
child_dispatchers:
2022-06-29T20:05:37.488540351+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: InstantaneousDemand
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
zdo:
child_dispatchers:
2022-06-29T20:05:37.566739685+00:00 TRACE Zigbee Switch Power Mc Zigbee Device: 5fb367cf-489d-4fcd-af04-8457cce912b1
Manufacturer: LUMI Model: lumi.plug.mmeu01
[1]: Basic, DeviceTemperatureConfiguration, Identify, Groups, Scenes, OnOff, Alarms, SimpleMetering, ElectricalM
easurement [242]:
2022-06-29T20:05:37.574388351+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-06-29T20:05:37.580297685+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-06-29T20:05:37.739958685+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:05:37.795042685+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Swit
ch
2022-06-29T20:05:37.822663351+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src
_endpoint: 0x01, dest_addr: 0x10D6, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHe
ader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E5037, src_endpoint: 0x01, cluster: ElectricalMeasuremen
t, dest_addr_mode: 0x03, dest_address: 286D97000207E580, dest_endpoint: 0x01 > > >
2022-06-29T20:05:37.946494018+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
_endpoint: 0x01, dest_addr: 0x10D6, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessage
Body || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReporting
Configuration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reportin
g_interval: 0x0E10, reportable_change: 1 > > > >
2022-06-29T20:05:38.053516352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E5037, src_endpoint: 0x01, cluster: OnOff, dest_addr_mod
2022-06-29T20:05:38.119437352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
_endpoint: 0x01, dest_addr: 0x10D6, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHea
der || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration ||
direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x
012C > > > >
2022-06-29T20:05:38.238817685+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ader || seqno: 0x00 >, < BindRequest || src_address: 04CF8CDF3C7E5037, src_endpoint: 0x01, cluster: SimpleMetering, dest
2022-06-29T20:05:38.355022018+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
_endpoint: 0x01, dest_addr: 0x10D6, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody ||
< ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfigu
ration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_inte
rval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-06-29T20:05:38.470559352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_inter
2022-06-29T20:05:38.556126352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
Body || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0605 > > >
2022-06-29T20:05:38.580768018+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
Body || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0604 > > >
2022-06-29T20:05:38.615429018+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
< ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0302 > > >
2022-06-29T20:05:38.674559352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
< ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0301 > > >
2022-06-29T20:05:38.704339685+00:00 PRINT Zigbee Switch Power Mc <<<< random_state >>>>
2022-06-29T20:05:38.724391019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“randomOnOff”,“capability_id”:“legendabsolute60149.randomOnOff2”,“com
ponent_id”:“main”,“state”:{“value”:“Inactive”}}
2022-06-29T20:05:38.785169019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“randomNext”,“capability_id”:“legendabsolute60149.randomNextStep2”,“c
omponent_id”:“main”,“state”:{“value”:“Inactive”}}
2022-06-29T20:05:38.834322685+00:00 PRINT Zigbee Switch Power Mc device_running[id]= <ZigbeeDevice: 5fb367cf-489d-4fc
d-af04-8457cce912b1 [0x10D6] (Lumi Plug)>
2022-06-29T20:05:38.848296352+00:00 PRINT Zigbee Switch Power Mc device_running, random_Step= <ZigbeeDevice: 5fb367cf-
489d-4fcd-af04-8457cce912b1 [0x10D6] (Lumi Plug)> 1
2022-06-29T20:05:38.869504352+00:00 PRINT Zigbee Switch Power Mc device_running, random_totalStep= <ZigbeeDevice: 5
fb367cf-489d-4fcd-af04-8457cce912b1 [0x10D6] (Lumi Plug)> 2
2022-06-29T20:05:38.880527685+00:00 PRINT Zigbee Switch Power Mc device_running, random_timer= <ZigbeeDevice: 5fb367cf-
489d-4fcd-af04-8457cce912b1 [0x10D6] (Lumi Plug)> 18
2022-06-29T20:05:38.889242685+00:00 PRINT Zigbee Switch Power Mc random_state >>>>> Inactive
2022-06-29T20:05:38.903031352+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:38.917948352+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-06-29T20:05:38.934907352+00:00 DEBUG Zigbee Switch Power Mc Z-Wave hub node ID environment changed.
2022-06-29T20:05:38.974408019+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-06-29T20:05:38.985575019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> received lifecycle event: added
2022-06-29T20:05:38.999133019+00:00 TRACE Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0
x10D6] (Lumi Plug)> received unhandled lifecycle event: added
2022-06-29T20:05:39.010505019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.021033352+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-06-29T20:05:39.030458019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> received lifecycle event: doConfigure
2022-06-29T20:05:39.041058019+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Swit
ch
2022-06-29T20:05:39.051720352+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Sw
itch
2022-06-29T20:05:39.058713685+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
Body || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-06-29T20:05:39.095629019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
der || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-06-29T20:05:39.128336685+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
< ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-06-29T20:05:39.154400685+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
< ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-06-29T20:05:39.190590352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:39.230742019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:39.272343352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:39.303131352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
012C > > > >
2022-06-29T20:05:39.345101685+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:39.371006686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:39.400939686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
Thanks,
Could you send the logs after 20:05:39, must be the configuración response
@Joao_Santos,
And later, when the configuration logs stop, press On and get the logs to see what value of power it sends and how it sends it
2022-06-29T20:05:39.425894019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.432042352+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.471904686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x10D6, src_en
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0x98, rssi: -62, body_len
gth: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x03, ZCLCommandId: 0x0A >, <
ReportAttribute || < AttributeRecord || AttributeId: 0x00F7, DataType: OctetString, OctetString: “\x64\x10\x00\x03\x28
x1A\x98\x39\x00\x00\x00\x00\x95\x39\x2F\x27\xAF\x40\x96\x39\x00\x20\x14\x45\x97\x39\x00\x00\x00\x00\x05\x21\x01\x00\x9A
x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x00\x07\x0B\x20\x00\x9B\x10\x00” > > > >
2022-06-29T20:05:39.533588352+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.542119019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.551890686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x9C, rssi: -61, body_len
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6C >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:39.611235352+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.620837019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.633347019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0x98, rssi
: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0D, ZCLCommandId: 0x07 >, < Co
nfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNREPORTABLE_ATTRIBUTE, direction: 0x00, at
tr_id: 0x050B > > > >
2022-06-29T20:05:39.701661019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.707994019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.722574352+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6D >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:39.750434019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.756393352+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.796957686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xA8, rssi: -58, body_leng
th: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0E, ZCLCommandId: 0x07 >, < ConfigureReporting
Response || ZclStatus: SUCCESS > > >
2022-06-29T20:05:39.861560019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.915683352+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.926473019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0x98, rssi: -62, body_len
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6E >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:39.954027019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:39.960059352+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:39.970409686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0x90, rssi: -64,
body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0F, ZCLCommandId: 0x07 >, < Configure
ReportingResponse || ZclStatus: SUCCESS > > >
2022-06-29T20:05:39.997856352+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.003727686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.012307019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xA4, rssi: -59,
body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x10, ZCLCommandId: 0x07 >, < Configure
ReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0
x0400 > > > >
2022-06-29T20:05:40.040468352+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.046617019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.057814686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
: -62, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x11, ZCLCommandId: 0x01 >, < Re
adAttributeResponse || < AttributeRecord || AttributeId: 0x0605, ZclStatus: SUCCESS, DataType: Uint16, ACPowerDivisor: 0
x000A > > > >
2022-06-29T20:05:40.085869686+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.091766353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.105046686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0x94, rssi
: -63, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x12, ZCLCommandId: 0x01 >, < Re
adAttributeResponse || < AttributeRecord || AttributeId: 0x0604, ZclStatus: SUCCESS, DataType: Uint16, ACPowerMultiplier
: 0x0001 > > > >
2022-06-29T20:05:40.137233019+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.143423686+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Ele
2022-06-29T20:05:40.149904353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.156015686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.167726353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0x98, rssi: -62,
body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x13, ZCLCommandId: 0x01 >, < ReadAttri
buteResponse || < AttributeRecord || AttributeId: 0x0302, ZclStatus: SUCCESS, DataType: Uint24, Divisor: 1000 > > > >
2022-06-29T20:05:40.197199019+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.202832019+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Ele
2022-06-29T20:05:40.209209019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.215174019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.224304353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
body_length: 0x000A, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x14, ZCLCommandId: 0x01 >, < ReadAttri
buteResponse || < AttributeRecord || AttributeId: 0x0301, ZclStatus: SUCCESS, DataType: Uint24, Multiplier: 1 > > > >
2022-06-29T20:05:40.253895019+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.259602686+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Sim
2022-06-29T20:05:40.265859686+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.271929019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.282558019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xA0, rssi: -60, body_leng
th: 0x000E, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x0A >, < ReportAttribute ||
< AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false >, < AttributeRecord || AttributeId: 0x00F5,
DataType: Uint32, Uint32: 0x02FFFF00 > > > >
2022-06-29T20:05:40.310433353+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.316434019+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Sim
2022-06-29T20:05:40.322662686+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.328672353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.339117686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0x9C, rssi
: -61, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x15, ZCLCommandId: 0x01 >, < Re
adAttributeResponse || < AttributeRecord || AttributeId: 0x050B, ZclStatus: SUCCESS, DataType: Int16, ActivePower: 0 > >
2022-06-29T20:05:40.367683019+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.373618686+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnO
2022-06-29T20:05:40.380649019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,"
component_id":“main”,“state”:{“value”:“LQI: 160 … RSSI: -60 dBm”},“visibility”:{“displayed”:false}}
2022-06-29T20:05:40.399693686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“val
ue”:“off”}}
2022-06-29T20:05:40.419763353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.427529686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.437960353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x98, rssi: -62, body_leng
th: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x16, ZCLCommandId: 0x01 >, < ReadAttributeRespo
nse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: false > > > >
2022-06-29T20:05:40.468365019+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.474522353+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Ele
2022-06-29T20:05:40.481794686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{"
unit":“W”,“value”:0.0}}
2022-06-29T20:05:40.500911686+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.508701686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.518570686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xAC, rssi: -57,
body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x17, ZCLCommandId: 0x01 >, < ReadAttri
buteResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint48, CurrentSummationDelivere
d: 0x000000001561 > > > >
2022-06-29T20:05:40.548365353+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.554094353+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnO
2022-06-29T20:05:40.561114353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
component_id":“main”,“state”:{“value”:“LQI: 152 … RSSI: -62 dBm”},“visibility”:{“displayed”:false}}
2022-06-29T20:05:40.582985353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ue”:“off”}}
2022-06-29T20:05:40.601294353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.608020019+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.618350019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x18, ZCLCommandId: 0x01 >, < ReadAttri
buteResponse || < AttributeRecord || AttributeId: 0x0400, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-06-29T20:05:40.658148353+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:40.663980019+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: Sim
2022-06-29T20:05:40.673355019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:
{“unit”:“kWh”,“value”:5.473}}
2022-06-29T20:05:40.703419019+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.710568686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.723271019+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x6F >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:40.761060353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.767356686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.777719686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xA0, rssi
: -60, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x19, ZCLCommandId: 0x07 >, < Co
2022-06-29T20:05:40.805770353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.811764686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.819832020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x70 >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:40.854094020+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.860329353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.870109020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
th: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x07 >, < ConfigureReporting
2022-06-29T20:05:40.901682020+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.907700020+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.916635353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x71 >, < BindRequestResponse || status: 0x00 > > >
2022-06-29T20:05:40.944791353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.950868020+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:40.960402686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1B, ZCLCommandId: 0x07 >, < Configure
2022-06-29T20:05:40.988225686+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:40.994302353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.003117686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x07 >, < Configure
x0400 > > > >
2022-06-29T20:05:41.031163353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.037132020+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-06-29T20:05:41.051726353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> received lifecycle event: infoChanged
2022-06-29T20:05:41.059572020+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.065693686+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.075955353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xFCC0 >, lqi: 0x94, rssi: -63, body_len
gth: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x05, ZCLCommandId: 0x0A >, <
ReportAttribute || < AttributeRecord || AttributeId: 0x0207, DataType: Boolean, Boolean: false > > > >
2022-06-29T20:05:41.104544353+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Swit
ch
2022-06-29T20:05:41.110294353+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-06-29T20:05:41.116320686+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> onTime
nil 10
2022-06-29T20:05:41.122144353+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10.0
2022-06-29T20:05:41.128153353+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMa
x nil 10.0
2022-06-29T20:05:41.133772353+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= No
2022-06-29T20:05:41.139543020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> signalMe
tricsVisibles nil No
2022-06-29T20:05:41.145737686+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= Plug
2022-06-29T20:05:41.156881353+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> changePr
ofileEner nil Plug
2022-06-29T20:05:41.173406020+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 255
2022-06-29T20:05:41.179293020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> restoreS
tate nil 255
2022-06-29T20:05:41.316805686+00:00 PRINT Zigbee Switch Power Mc <<< Write restore state >>>
2022-06-29T20:05:41.326258686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
der || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, Da
taType: Enum8, data: 0xFF > > > >
2022-06-29T20:05:41.350198353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
der || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, Da
taType: Enum8, data: 0x02 > > > >
2022-06-29T20:05:41.372587353+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-06-29T20:05:41.378653020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupRem
ove nil 1.0
2022-06-29T20:05:41.384147686+00:00 PRINT Zigbee Switch Power Mc Remove Groups >>>>>>>>>>>>>>>>>
2022-06-29T20:05:41.410201020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
_endpoint: 0x01, dest_addr: 0x10D6, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHe
ader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2022-06-29T20:05:41.427212686+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-06-29T20:05:41.445710686+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]=
2022-06-29T20:05:41.469114687+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> version
nil
2022-06-29T20:05:41.475223687+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2022-06-29T20:05:41.481417020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupAdd
nil 0.0
2022-06-29T20:05:41.523459353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:41.537024353+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-06-29T20:05:41.542546020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> offTime
nil 10
2022-06-29T20:05:41.548424687+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-06-29T20:05:41.559865020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMi
n nil 1.0
2022-06-29T20:05:41.567940687+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0
2022-06-29T20:05:41.581634020+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> localTim
eOffset nil 0
2022-06-29T20:05:41.589280687+00:00 PRINT Zigbee Switch Power Mc Device ID <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8
2022-06-29T20:05:41.627545353+00:00 PRINT Zigbee Switch Power Mc Manufacturer >>> LUMI Manufacturer_Len >>>
4
2022-06-29T20:05:41.633161353+00:00 PRINT Zigbee Switch Power Mc Model >>> lumi.plug.mmeu01 Model_len >>>
16
2022-06-29T20:05:41.651655020+00:00 PRINT Zigbee Switch Power Mc Memory >>>>>>> 1664.0703125 Kbytes
2022-06-29T20:05:41.657377020+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.674841020+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.684602020+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.741687687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x9C, rssi: -61, body_leng
th: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x04 >, < WriteAttributeRepo
nse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x4003 > > > >
2022-06-29T20:05:41.771277353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.777140353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.790564020+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
th: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1E, ZCLCommandId: 0x04 >, < WriteAttributeRepo
nse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x8002 > > > >
2022-06-29T20:05:41.818087687+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.824054687+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.837486687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0x94, rssi: -63, body_len
gth: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x1F, ZCLCommandId: 0x03 >, < RemoveGroupRespon
se || status: 0x8B, group_id: 0x0001 > > >
2022-06-29T20:05:41.869704687+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.875555687+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:41.884124353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x20, ZCLCommandId: 0x02 >, < GetGroupMembershi
pResponse || capacity: 0x10, group_list_length: 0x00 > > >
2022-06-29T20:05:41.911733020+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:41.917380687+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, co
2022-06-29T20:05:41.923342687+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-06-29T20:05:41.928627687+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-06-29T20:05:41.944470353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
10D6] (Lumi Plug)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“componen
t_id”:“main”,“state”:{“value”:“All Deleted”}}
2022-06-29T20:05:41.987566353+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:05:41.993717353+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:05:42.002351353+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0x98, rssi: -62, body_len
gth: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x21, ZCLCommandId: 0x02 >, < GetGroupMembershi
2022-06-29T20:05:42.032771353+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:05:42.038472020+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, co
2022-06-29T20:05:42.044796687+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-06-29T20:05:42.050689687+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-06-29T20:05:42.056990687+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:05:42.074322687+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:06:07.502084032+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:06:37.514561713+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:07:07.524592394+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:07:37.524579409+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:08:07.534566423+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:08:37.534551770+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:09:07.544422785+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:09:37.544560545+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:10:06.385095226+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:10:06.397122559+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8001 >, lqi: 0xA0, rssi: -60, body_len
gth: 0x000C, < ZDOMessageBody || < ZDOHeader || seqno: 0x79 >, GenericBody: 00 37 50 7E 3C DF 8C CF 04 D6 10 > >
2022-06-29T20:10:06.426494892+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:10:07.551675560+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:10:37.554561241+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:10:54.984766916+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:10:54.994431916+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x06, ZCLCommandId: 0x0A >, <
x1A\x98\x39\x00\x00\x00\x00\x95\x39\x2F\x27\xAF\x40\x96\x39\x00\x40\x12\x45\x97\x39\x00\x00\x00\x00\x05\x21\x01\x00\x9A
x20\x00\x08\x21\x16\x01\x07\x27\x00\x00\x00\x00\x00\x00\x00\x00\x09\x21\x00\x08\x0B\x20\x00\x9B\x10\x00” > > > >
2022-06-29T20:10:55.025637916+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:11:07.564607255+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:11:37.564601603+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:12:07.564543950+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:12:37.575055298+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:13:07.574534979+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:13:37.574503554+00:00 INFO Zigbee Switch Power Mc Doing health check read for [10D6]:0006:0000
2022-06-29T20:13:37.584438888+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:13:37.604410888+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:13:37.691597221+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:13:37.700436888+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
th: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2F, ZCLCommandId: 0x01 >, < ReadAttributeRespo
2022-06-29T20:13:37.728887554+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-06-29T20:13:37.734405554+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnO
2022-06-29T20:13:37.741462221+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
2022-06-29T20:13:37.762464888+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
ue”:“off”}}
2022-06-29T20:13:37.785660554+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:14:07.584419235+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:14:37.584517583+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:15:07.204759264+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:15:07.214823264+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
dpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8001 >, lqi: 0x98, rssi: -62, body_len
gth: 0x000C, < ZDOMessageBody || < ZDOHeader || seqno: 0x7A >, GenericBody: 00 37 50 7E 3C DF 8C CF 04 D6 10 > >
2022-06-29T20:15:07.247042264+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
2022-06-29T20:15:07.593442931+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:15:37.604570278+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:16:07.615026626+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:16:37.614529973+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:17:07.625038321+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-06-29T20:17:17.724863326+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-06-29T20:17:17.734453659+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: 5fb367cf-489d-4fcd-af04-8457cce912b1 [0x
gth: 0x0046, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x1C, mfg_code: 0x115F, seqno: 0x07, ZCLCommandId: 0x0A >, <
2022-06-29T20:17:17.764423993+00:00 DEBUG Zigbee Switch Power Mc Lumi Plug device thread event handled
With something on the plug to comsume power?
Yes, put a load.
I see the device use sending now 0w power
and energy 5.473kwh
