Do not change the 5 GHz connection of the hub with the router, that does not affect anything.
If you have devices that use wifi instead of zigbee or zwave, they will probably use 2.4 GHz wifi. That is the one you have to check that it is not on a channel that can interfere with the zigbee network channel.
Extract the driver folders to a directory on your PC
Copy the full path to the driver folder you extracted:
run in the CLI this command with your path to the driver folder: (example) smartthings edge:drivers:package C:\Users\Documents\Zigbee-Blind-Switch-TS130F
Once you have the packaged driver you have to publish it on your channel: smartthings edge:drivers:publish (follow the on-screen instructions)
Install your driver in the hub from the app or from the CLI: smartthings edge:drivers:install (follow the on-screen instructions)
Note:
All the commands you type in the cli stay in the terminal’s memory and you don’t have to type them again.
you can retrieve them with the up and down arrow keys, it shows them from most recent to oldest
They works perfectly in local now!! Thanks for your support!
But i thinks that could be useful for others users… I hope that alex permits to us to use your works…
Hi @Filippo_Mori,
This sensor is in the smartthings beta stocks driver Zigbee Motion Sensor
The only thing my driver provides is configurable temperature report intervals, I will also add it in case it is needed
│ Name │ Zigbee Motion Sensor Mc │
│ Version │ 2022-05-16T16:44:51.30959 │
Released a new update of the SmartThings Multipurpose Sensor Mc driver, which will be updated automatically.
Improvements:
Detected that the Three axis and acceleration cluster 0xFC02 only accepts the Attributtes report interval configuration during pairing from reboot. I do not know why!
The configuration of the first stock driver beta had these intervals at 300 sec and changes of 1 mG.
This configuration causes the battery life to be substantially reduced.
The latest version of the stock Beta Zigbee Contact driver has a new report interval setting of 3600 sec, which is much better.
I have updated my driver to these 3600 sec report intervals, but it only configures correctly with these new values if the sensor is uninstalled and re-paired.
In this way it only sends the open/closed status every 5 minutes, according to the default configuration.
│ Name │ SmartThings Multipurpose Sensor Mc │
│ Version │ 2022-05-17T16:08:14.145516 │
The smartthings beta stock zigbee contact driver also works with this sensor
The detection will have to do with the orientation of the sensor, only the z axis is used for the garage door function.
In my driver there is a preference that allows you to choose which axis the function uses.
You can change the preference until one of the three will work
