[BETA v0515] Hampton Bay Zigbee Ceiling Fan/Light Controller
Yes your on the wrong page. On the prior page befor you got to that one you would have seen “preferences” choose edit under preferences
I can’t find preferences anywhere. This is the page prior to my screenshot earlier.
So what it looks like you did is just changed the DTH to the new DTH so you are stuck with the prior DTH options. Try deleting the device and then add it back with the new DTH.
First off i want to say thank you mikesbau for taking the time to help me troubleshoot but still nothing. I removed the fan thru IDE, added it back in then used raphaelborja’s DTH and still no preference option.
Delete it in smartthings app. Dont just remove the DTH remove the device. The telling sign is that you still have the old virtual devices which were part of the KOF device handler under child devices
I deleted the fan thru the app, then I deleted all 3 of the previous DTH, added the fan back in via smartthings app, then i applied raphaelborja’s DTH, and still…the same thing. No preferences option for me.
What do you have under child devices? You should have a single child device.
If you have this you still have the older device handler options
I just have one child device
hmmm…I dont know that is odd I dont know why you dont have it. Could it be your signed into smartthings classic?
In your smartthings app can you get to settings under the device?
mikesbau, first off i really want to thank you for taking your time to help me out here. I really appreciate it. I have solved my problem, apparently when i installed the DTH, i copied the code from raphaelborja’s source as in, i went to his github, looked at his releases, saw his one release titled First Functional version, downloaded the source code (zip) then took the code and pasted it into IDE. I then decided to see if i were to add his repo to my IDE if anything would change. Well, after i did that, i noticed the fan controller could be updated. After i did that, i had the “preference” option in IDE and option appeared in smartthings app under the 3 dot menu. Again, i really appreciate your help and i couldn’t believe that was the issue.
No problem glad you got it figured out.
I’ve been trying to understand how to integrate my Wink-enabled Garnier fan but the more I read the most confused I become.
I already have two Garnier fans and their controllers - do I still need to purchase the Zigbee controller?
How did you publish rafaelborja’s DTH to your smartthings app? I tried following the integration instructions and appeared to publish it but it’s not showing up on my smartthings app. Were there custom instructions included in the code? If so, I didn’t understand them at all.
Is it possible for someone to post an ELI5 version of what I’m supposed to do?
Thank you!
First off do you have the Hampton bay zigbee controller in your fan already?
I would expect that to be the same as the add-on module and able to use the same DTH; there’s probably a post saying so a few hundred back…
Have any of you folks noticed stability issues with these fans? I see a huge number of messages back and forth and sometimes failures. I am using a GE 45856 as a repeater. All 3 fans hop through this switch before making it back to the hub. This switch is centrally located between all 3 and no more then 15 feet away from any one fan max.
This is just one of the fans. I have seen a couple transmit failures The quantity of messages is odd to me.
  • Last Hop LQI: 255
  • Last Hop RSSI: -53
  • Received Messages From Device: 1757
  • Received Messages From Device (Duplicates): 2
  • Messages Transmitted to Device: 3155
  • Messages Transmitted to Device (Failures): 0
  • Updated Time: 2020-05-27 12:13 PM PDT
All 3 Fans hop through this GE switch before reaching the hub
  • Last Hop LQI: 255
  • Received Messages From Device: 305
  • Received Messages From Device (Duplicates): 0
  • Messages Transmitted to Device: 302
  • Updated Time: 2020-05-27 11:39 AM PDT
Well for me this new DTH has made my fans more responsive and I haven’t noticed any issues TBH but here is some info from one of my fans. I have 3 aswell I can’t really tell if this is good or bad. Maybe you can tell me? The fan hops thru 2 zigbee outlets that serve as repeaters.
Metrics * Last Hop LQI: 140
  • Last Hop RSSI: -65
  • Received Messages From Device: 15102
  • Received Messages From Device (Duplicates): 14
  • Messages Transmitted to Device: 13833
  • Messages Transmitted to Device (Failures): 1
  • Updated Time: 2020-05-27 7:12 PM EDT
I can provide info for my other fans if you need data to compare with.
I’m not an expert here was hoping one of the forum members is. But from yours post to me it looks like its polling the crap out of the fan. I do see 1 transmit failures in yours as well. I have had 2 transmit failures which I then had to remove the device and replace it to get it working again.
From my naive look at the data the number of packets from the hub to my switch should be around the same as the number of packets from the switch to the fan. For me I see an order of magnitude more going from the switch to the fan. Just seems off to me but I’m not a zigbee guy so could be talking out my behind.
If it’s not the one that comes pre-installed in the fan already then no, I’d have to purchase it and install it. That was one of the sources of my confusion - I wasn’t sure if I needed to purchase the controller or not since I already had a wink-enabled fan. I assumed the controller would be the same.
Ok, i’m gonna assume you have the correct fan controller. Basically you need to install the DTH for the fan controller so it works in SmartThings. Think of a DTH as a driver for a video card or computer mouse. If you watch this video it should basically guide you thru all the steps. He’ll do a better job than i ever can. Go to 11:50 in the video, this is where the guy starts setup. https://youtu.be/lK_c4hXpQBs?t=691
However i want say that this video is old and is based on the first DTH but it will guide you on what you need to do. However, you should watch this other video on how to link Github to your SmartThings IDE
The DTH you need is here https://github.com/rafaelborja/SmartthingsKingOfFansZigbee
Just watch those videos, put all that information together and grab the files from that github page.
Posts still seem active, but I don’t see anything about getting this to be compatible with the new app. Primary question to that is I’d like to import into google home, but its only importing the devices that are in the new app. Is there a way to get devices from classic app or is anyone working to develop integration with the new app?
