Try this - it is a replacement for the included Routines helper app, that adds the support you ask for as the 3rd option (Mode controls Program, Routine Controls Program, Program controls Mode or Routine). You should be able to just save this over your current smartthings: ecobee Routines in the IDE and publish it…
WARNING I threw this together quickly, without much more than cursory testing, so I may have broken something. Let me know if it does what you want!
* ecobee Routines
* Copyright 2015 Sean Kendall Schneyer
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
def getVersionNum() { return "0.1.7a" }
private def getVersionLabel() { return "ecobee Routines Version ${getVersionNum()}" }
* 0.1.4 - Fix Custom Mode Handling
* 0.1.5 - SendNotificationMessage so that the action shows up in Notification log after the mode/routine notices
* 0.1.6 - Logic tweaks, fixed bad state.variableNames
* 0.1.7 - Extended to support the inverse: Ecobee Program change (including Vacation) can change ST Mode or run Routine
* 0.1.7a- Fixed typo
definition(
name: "ecobee Routines",
namespace: "smartthings",
author: "Sean Kendall Schneyer (smartthings at linuxbox dot org)",
description: "Change ecobee Programs based on SmartThings Routine execution or Mode changes, OR change Mode/run Routine based on Ecobee Program/Vacation changes",
category: "Convenience",
parent: "smartthings:Ecobee (Connect)",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/ecobee.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/ecobee@2x.png",
singleInstance: false
preferences {
page(name: "mainPage")
// Preferences Pages
def mainPage() {
dynamicPage(name: "mainPage", title: "Setup Routines", uninstall: true, install: true) {
section(title: "Name for Routine Handler") {
label title: "Name this Routine Handler", required: true
section(title: "Select Thermostats") {
if(settings.tempDisable == true) {
paragraph "WARNING: Temporarily Disabled as requested. Turn back on to activate handler."
} else {
input ("myThermostats", "capability.Thermostat", title: "Pick Ecobee Thermostat(s)", required: true, multiple: true, submitOnChange: true)
section(title: "Select ST Mode or Routine, or Ecobee Program") {
// Settings option for using Mode or Routine
input(name: "modeOrRoutine", title: "Use Mode Change, Routine Execution or Ecobee Program: ", type: "enum", required: true, multiple: false, description: "Tap to choose...", metadata:[values:["Mode", "Routine", "Ecobee Program"]], submitOnChange: true)
if (myThermostats?.size() > 0) {
if(settings.modeOrRoutine == "Mode") {
// Start defining which Modes(s) to allow the SmartApp to execute in
// TODO: Need to run in all modes now and then filter on which modes were selected!!!
//mode(title: "When Hello Mode(s) changes to: ", required: true)
section(title: "Modes") {
input(name: "modes", type: "mode", title: "When Hello Mode(s) change to: ", description: "Tap to choose Modes...", required: true, multiple: true)
} else if(settings.modeOrRoutine == "Routine") {
// Routine based inputs
def actions = location.helloHome?.getPhrases()*.label
if (actions) {
// sort them alphabetically
actions.sort()
LOG("Actions found: ${actions}", 4)
// use the actions as the options for an enum input
section(title: "Routines") {
input(name:"action", type:"enum", title: "When these Routines execute: ", description: "Tap to choose Routines...", options: actions, required: true, multiple: true)
} // End if (actions)
} else if(settings.modeOrRoutine == "Ecobee Program") {
def programs = getEcobeePrograms()
programs = programs + ["Vacation"]
LOG("Found the following programs: ${programs}", 4)
section(title: "Programs") {
def n = myThermostats?.size()
if (n > 1) paragraph("NOTE: It is recommended (but not required) to select only one thermostat when using Ecobee Programs to control SmartThings Modes or Routines")
input(name: "ctrlProgram", title: "When Ecobee${n>1?'s':''} switch to Program: ", type: "enum", description: "Tap to choose Programs...", options: programs, required: true, multiple: true)
section(title: "Actions") {
if (settings.modeOrRoutine != "Ecobee Program") {
programs = programs + ["Resume Program"]
input(name: "whichProgram", title: "Switch to this Ecobee Program: ", type: "enum", required: true, multiple:false, description: "Tap to choose...", options: programs, submitOnChange: true)
input(name: "fanMode", title: "Select a Fan Mode to use\n(Optional) ", type: "enum", required: false, multiple: false, description: "Tap to choose...", metadata:[values:["On", "Auto", "default"]], submitOnChange: true)
if(settings.whichProgram != "Resume Program") input(name: "holdType", title: "Select the Hold Type to use\n(Optional) ", type: "enum", required: false, multiple: false, description: "Tap to choose...", metadata:[values:["Until I Change", "Until Next Program", "default"]], submitOnChange: true)
input(name: "useSunriseSunset", title: "Also at Sunrise or Sunset?\n(Optional) ", type: "enum", required: false, multiple: true, description: "Tap to choose...", metadata:[values:["Sunrise", "Sunset"]], submitOnChange: true)
} else {
input(name: "runModeOrRoutine", title: "Change Mode or Execute Routine: ", type: "enum", required: true, multiple: false, description: "Tap to choose...", metadata:[values:["Mode", "Routine"]], submitOnChange: true)
if (settings.runModeOrRoutine == "Mode") {
input(name: "runMode", type: "mode", title: "Change Hello Mode to: ", required: true, multiple: false)
} else if (settings.runModeOrRoutine == "Routine") {
if (actions) {
actions.sort()
input(name:"runAction", type:"enum", title: "Execute this Routine: ", options: actions, required: true, multiple: false)
} // End if (Routine)
} // End else Program --> Mode/Routine
} // End of "Actions" section
} // End if myThermostats size
section(title: "Temporarily Disable?") {
input(name: "tempDisable", title: "Temporarily Disable Handler? ", type: "bool", required: false, description: "", submitOnChange: true)
section (getVersionLabel())
// Main functions
def installed() {
LOG("installed() entered", 5)
initialize()
def updated() {
LOG("updated() entered", 5)
unsubscribe()
initialize()
def initialize() {
LOG("initialize() entered")
if(tempDisable == true) {
LOG("Temporarily Disabled as per request.", 2, null, "warn")
return true
if (settings.modeOrRoutine == "Routine") {
subscribe(location, "routineExecuted", changeProgramHandler)
} else if (settings.modeOrRoutine == "Mode") {
subscribe(location, "mode", changeProgramHandler)
} else {
subscribe(myThermostats, "currentProgramName", changeSTHandler)
if(useSunriseSunset?.size() > 0) {
// Setup subscriptions for sunrise and/or sunset as well
if( useSunriseSunset.contains("Sunrise") ) subscribe(location, "sunrise", changeProgramHandler)
if( useSunriseSunset.contains("Sunset") ) subscribe(location, "sunset", changeProgramHandler)
// Normalize settings data
normalizeSettings()
LOG("initialize() exiting")
// get the combined set of Ecobee Programs applicable for these thermostats
private def getEcobeePrograms() {
def programs
myThermostats.each { stat ->
def DNI = stat.device.deviceNetworkId
LOG("Getting list of programs for stat (${stat}) with DNI (${DNI})", 4)
if (!programs) {
LOG("No programs yet, adding to the list", 5)
programs = parent.getAvailablePrograms(stat)
} else {
LOG("Already have some programs, need to create the set of overlapping", 5)
programs = programs.intersect(parent.getAvailablePrograms(stat))
LOG("getEcobeePrograms: returning ${programs}", 4)
return programs
private def normalizeSettings() {
if (settings.modeOrRoutine == "Ecobee Program") return
// whichProgram
state.programParam = ""
if (whichProgram != null && whichProgram != "") {
if (whichProgram == "Resume Program") {
state.doResumeProgram = true
} else {
state.programParam = whichProgram
// fanMode
state.fanCommand = ""
if (fanMode != null && fanMode != "") {
if (fanMode == "On") {
state.fanCommand = "fanOn"
} else if (fanMode == "Auto") {
state.fanCommand = "fanAuto"
} else {
// holdType
state.holdTypeParam = null
if (holdType != null && holdType != "") {
if (holdType == "Until I Change") {
state.holdTypeParam = "indefinite"
} else if (holdType == "Until Next Program") {
state.holdTypeParam = "nextTransition"
} else {
state.expectedEvent = settings.action
} else {
state.expectedEvent = settings.modes
LOG("state.expectedEvent set to ${state.expectedEvent}", 4)
def changeSTHandler(evt) {
LOG("changeSTHandler() entered with evt: ${evt.name}: ${evt.value}", 5)
// adjust because currentProgramName carries some informational baggage
String newProgram = evt.value
if (newProgram.startsWith("Hold: ")) {
newProgram = newProgram.drop(6)
} else if (newProgram.startsWith("Away ")) {
newProgram = newProgram.drop(5)
if (settings.ctrlProgram.contains(newProgram)) {
if (!state.ecobeeThatChanged) {
state.ecobeeThatChanged = evt.displayName
state.ecobeeNewProgram = evt.value
if (settings.myThermostats.size() == 1) {
changeMode()
} else {
// trick to avoid multiple calls if more than 1 thermostat - they could change simultaneously or within the next pollCycle
// to avoid this delayed response, assign to only one thermostat
runIn((parent.getPollingInterval()*66), changeMode, [overwrite: true])
} else {
if (settings.myThermostats.size() == 1) { runRoutine() } else { runIn((parent.getPollingInterval()*66), runRoutine, [overwrite: true]) } // trick to avoid multiple calls if more than 1 thermostat
def changeMode() {
if (!settings.runMode.contains(location.mode)) {
if (state.ecobeeThatChanged) sendNotificationEvent("Changing Mode to ${settings.runMode} because ${state.ecobeeThatChanged} changed to ${state.ecobeeNewProgram}")
location.mode(settings.runMode)
state.ecobeeThatChanged = null
def runRoutine() {
if (state.ecobeeThatChanged) sendNotificationEvent("Executing Routine ${settings.runAction} because ${state.ecobeeThatChanged} changed to ${state.ecobeeNewProgram}")
location.helloHome?.execute(settings.runAction)
def changeProgramHandler(evt) {
LOG("changeProgramHander() entered with evt: ${evt.name}: ${evt.value}", 5)
def gotEvent
gotEvent = evt.displayName?.toLowerCase()
} else {
gotEvent = evt.value?.toLowerCase()
LOG("Event name received (in lowercase): ${gotEvent} and current expected: ${state.expectedEvent}", 5)
if ( !state.expectedEvent*.toLowerCase().contains(gotEvent) ) {
LOG("Received an mode/routine that we aren't watching. Nothing to do.", 4)
return true
settings.myThermostats.each { stat ->
LOG("In each loop: Working on stat: ${stat}", 4, null, 'trace')
// First let's change the Thermostat Program
if(state.doResumeProgram == true) {
LOG("Resuming Program for ${stat}", 4, null, 'trace')
if (stat.currentValue("thermostatHold") == 'hold') {
def scheduledProgram = stat.currentValue("scheduledProgram")
stat.resumeProgram(true) // resumeAll to get back to the schedules program
sendNotificationEvent("And I resumed the scheduled ${scheduledProgram} program on ${stat}.")
} else {
LOG("Setting Thermostat Program to programParam: ${state.programParam} and holdType: ${state.holdTypeParam}", 4, null, 'trace')
boolean done = false
def thermostatHold = stat.currentValue('thermostatHold')
if (stat.currentValue('currentProgram') == state.programParam) {
if (thermostatHold == "") {
sendNotificationEvent("And I verified that ${stat} is already in the ${state.programParam} program.")
done = true
} else if (thermostatHold == 'hold') {
if (stat.currentValue('scheduledProgram') == state.programParam) {
if (state.programParam == 'nextTransition') {
stat.resumeProgram(true) // resumeAll to get back to the originally scheduled program
sendNotificationEvent("And I resumed the scheduled ${state.programParam} on ${stat}.")
done = true
if (!done) {
stat.setThermostatProgram(state.programParam, state.holdTypeParam)
sendNotificationEvent("And I set ${stat} to the ${state.programParam} program${(state.holdTypeParam!='nextTransition') ? ' indefinitely.' : '.'}")
if (state.fanCommand != "" && state.fanCommand != null) stat."${state.fanCommand}"()
return true
// Helper Functions
private def LOG(message, level=3, child=null, logType="debug", event=true, displayEvent=true) {
message = "${app.label} ${message}"
parent.LOG(message, level, null, logType, event, displayEvent)
log."${logType}" message
