SmartThings Community
[BETA] Hue (Re)Connect - with scene handling
hue
smartapp_lighting
(www.smartukhome.co.uk) #296
Will do, I’m interested in what a Philips living white apdator is I’ve never heard of it.
I added four scenes two days ago. I only use the old app don’t have the new one installed as it breaks my Philips dimmers after a few days though they might of fixed that by now. I just created them, used them a few times then went to hue reconnect and added them.
There’s a hue addon app called “all 4 hue” lets you delete scenes and rename dimmer groups on the hub itself and not in the app
I have been working on adding that over the last few days and fixing the transition time problem.
(Marcus) #297
Cool, ill try out the all 4 hue app :slight_smile:
The LivingWhites Adapter basically is a zigbee plug with an included dimmer
(Dean) #298
I keep getting the below error when trying to get setup.
21:42:49: error physicalgraph.app.exception.UnknownDeviceTypeException: Device type ‘Hue Bridge’ in namespace ‘smartthings’ not found. @ line 598
(Dean) #299
Urmm forgot the device handlers lol :grinning:
Got it working, but odd thing is if you don’t select device or hub quick it drops out of the list within 3 seconds if you don’t hit the done confirmation. Scenes are not being detected for me are they working for others?
#300
Do you plan to support the new Hue app or is it not possible?
(www.smartukhome.co.uk) #301
Its not my code originally, I have done my best to improve this app I have tried to do more but I end up breaking things. Last week while modifying I broke the app and I had to remove all of my lights and have moved to Hue & Improved as it supports multiple bridges.
I would recommend waiting for a new version of Hue Lights & Groups & Scenes (OH MY!) to be released it can create scenes and groups etc though I havent tried it my self
(Tony - SmartThings Unpublished Contributor ) #302
Here is the Beta version of the Hue B Smart service manager and
version 1 of the DTHs. This replaces my older HLGS service manager app (which will not be updated).
(Mike Whitaker) #303
Does it handle Hue Beyond and the lights that come with the Dimmer Switch?
(Tony - SmartThings Unpublished Contributor ) #304
It has been tested on the dimmer switch lights. Haven’t tested it with hue beyond.
(Mike Whitaker) #305
I’ll volunteer for the latter sometime this week when I get a spare hour or so.
(“Yes dear, you’re not going to be able to control the living room lights via Alexa for about half an hour. Sorry.”)
(Kolosy) #306
Has anyone had issues importing scenes? I installed this app, and it’s able to see the bridge, bulbs and groups, but isn’t able to see any scenes. I created two custom ones, and it keeps saying 0 scenes on the smartapp config screen. Any ideas?
Here’s a relevant section of the logfile
4605071e-0a53-427a-942e-d4f45a8257e2  5:33:08 PM: debug parse() - [name:saturation, value:79,     isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) saturation is 79]
416d0290-e9f8-4eb0-8f75-c79591bf890e  5:33:08 PM: debug Its a scene
4605071e-0a53-427a-942e-d4f45a8257e2  5:33:08 PM: debug parse() - [name:alert, value:select, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) alert is select]
e4be3c27-7de1-4cbd-b233-d7de4c6f03e5  5:33:08 PM: debug parse() - [name:effect, value:none, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) effect is none]
f7a9e72e-bee8-4d05-90d9-35a5420cd719  5:33:08 PM: trace Get state for [QO0Nd6BbTr0mbhd, LlmyaiW8EblzFOb, ZABK2GQoEOLmISR, x5t9c8p1rpGJKKf, 1sxNEF0V7KghpNI, F7n9YQxLttVO2mG, xhsmphYH2eMMVwC, oiyeVVxtYmS5Ox6, i8GYnoka9NDXIBI, eHpctNCGjQ8B0Mb, qVJnm5z68zYgJJD, vYpABTxIuTZY08V]
e4be3c27-7de1-4cbd-b233-d7de4c6f03e5  5:33:08 PM: debug parse() - [name:alert, value:select, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) alert is select]
4605071e-0a53-427a-942e-d4f45a8257e2  5:33:08 PM: debug parse() - [name:color, value:#E4571A, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) color is #E4571A]
416d0290-e9f8-4eb0-8f75-c79591bf890e  5:33:08 PM: trace Adding items to state...
e4be3c27-7de1-4cbd-b233-d7de4c6f03e5  5:33:08 PM: debug parse() - [name:color, value:#FD013D, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) color is #FD013D]
e4be3c27-7de1-4cbd-b233-d7de4c6f03e5  5:33:08 PM: debug parse() - [name:level, value:76, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) level is 76]
e4be3c27-7de1-4cbd-b233-d7de4c6f03e5  5:33:08 PM: debug parse() - [name:switch, value:on, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) switch is on]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:08 PM: debug parse() - [name:alert, value:select, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) alert is select]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:08 PM: debug parse() - [name:effect, value:none, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) effect is none]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:08 PM: debug parse() - [name:saturation, value:99, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) saturation is 99]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:08 PM: debug parse() - [name:hue, value:100, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) hue is 100]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:08 PM: debug parse() - [name:color, value:#FD0101, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) color is #FD0101]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:07 PM: debug parse() - [name:level, value:76, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) level is 76]
7c66d160-33b0-473e-a122-0d35bc00da11  5:33:07 PM: debug parse() - [name:switch, value:on, isStateChange:true, displayed:true, linkText:Hue (ReConnect), descriptionText:Hue (ReConnect) switch is on]
416d0290-e9f8-4eb0-8f75-c79591bf890e  5:33:07 PM: trace Bridge: 00178846337E - Host: 192.168.1.11:80
416d0290-e9f8-4eb0-8f75-c79591bf890e  5:33:07 PM: debug Discovering New Groups
(Kolosy) #307
Figured it out. It looks like the Hue API response may have changed. The logic that filtered out ‘default’ scenes relied on the scene name containing a timestamp in it, but that isn’t the case anymore (or at least on my bridge). If you run into the same issue, you just need to comment out 3 lines in the sceneDiscovered function (around line 300)
if (it.value.id == sceneTime?."${it.value.name.minus(~/ on \d+/)}"?.id && it.value.name ==~ /.* on \d+$/)
This if as well as the following else and associated brackets need to be commented out. Then it works. You do end up with the default scenes, but that’s not a huge deal. It’s also possible to filter them out by name if it bothers you too much. That would be done in the same spot, just a simple name check there.
(Mark Whelan) #308
I just installed and everything was going perfect until no scenes appeared, i have pasted a bit of the log file not sure what part would help. Plus i’m not sure what the funny groups names are.
80f27002-a68e-4271-b4ff-a8692e14813d 11:46:50 PM: debug Its a scene
80f27002-a68e-4271-b4ff-a8692e14813d 11:46:50 PM: debug getChildDevices(false), children=10
80f27002-a68e-4271-b4ff-a8692e14813d 11:46:50 PM: debug Response Body: {“ULikZHX-vKJptLN”:{“name”:“Relax”,“lights”:[“1”,“2”,“3”],“owner”:“Q8p9DQBV0jzI33UMrwhuu7WBaawbx8LzFtRh47a6”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“VPv0B_r01_d01”},“picture”:"",“lastupdated”:“2016-11-17T13:55:16”,“version”:2},“atmPem7BMOiChCq”:{“name”:“Read”,“lights”:[“1”,“2”,“3”],“owner”:“Q8p9DQBV0jzI33UMrwhuu7WBaawbx8LzFtRh47a6”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“UnTWS_r01_d02”},“picture”:"",“lastupdated”:“2016-11-17T13:55:16”,“version”:2},“a1wyxSk2h2CSWf3”:{“name”:“Concentrate”,“lights”:[“1”,“2”,“3”],“owner”:“Q8p9DQBV0jzI33UMrwhuu7WBaawbx8LzFtRh47a6”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“wmoNk_r01_d03”},“picture”:"",“lastupdated”:“2016-11-17T13:55:16”,“version”:2},“eor9jfu0O3SFIjZ”:{“name”:“Energize”,“lights”:[“1”,“2”,“3”],“owner”:“Q8p9DQBV0jzI33UMrwhuu7WBaawbx8LzFtRh47a6”,“recycle”:false,“locked”:false,“appdata”:{“version”:1,“data”:“7DOHW_r01_d04”},“picture”:"",“lastupdated”:“2016-11-17T13:55:16”,“version”:2},"bDSSKcVqZLf1n6p…[TRUNCATED]
(Kolosy) #309
Uh… literally the two posts above yours.
(Mark Whelan) #310
lol, it was getting very late last night.
I will give that a go now, i wonder if that’s the same reason my Logitech Harmony cannot see scenes?
(Mark Whelan) #311
Worked a treat thanks kolosy
(Kolosy) #312
Glad to hear it.
Logitech scenes - you mean an integration between the Harmony home and Hue? Or something through ST? I have both of those, but haven’t looked to hook them together yet…
(Dasoslukos) #313
Question: Is there a way to install this without removing the original connect and or a way to remove the original connect without loosing the current lights in the database? I have lots of things setup using the original connect so it would basically require me to completely overhaul the entire system. Thx.
(Mark) #314
Any help with this error will be greatly appreciated.
I received this error after installing ReConnect, connecting to the Hue bridge, selecting the Hue bulbs and selecting the Hue Groups. It happens when click Done with a red “An unexpected error occurred.” message
BTW it happens when if I don’t select any of the bulbs or Groups.
Line 598 is d = addChildDevice(“smartthings”, “Hue Bridge”, selectedHue, vbridge.value.hub)
(Arnoud) #315
You get this error if you didn’t install the DeviceTypes that are needed.
