[BETA] Advanced Button Controller (ABC)
I was making some changes to the ABC SmartApp to make it working with the new Sonos DTH.
You need to change a few things in the child app.
I’ve made the volume and play/pause working for myself, but the next track shouldn’t be a big issue neither.
Let me get back to you later.
@hypyke, I’ve updated the code, but need to test first on my Sonos. I will post here after I’ve done that. (I’ve added the previous track option too, it might be useful.)
Rock!
I don’t mind testing as well.
@hypyke, here we go…
This is the Main SmartApp, this is to Save and Publish.
 *	Advanced Button Controller (Parent/Child Version)
 *	Author: Stephan Hackett, updated Gabor Szabados
 * 6/20/17 - fixed missing subs for notifications
 * 1/07/18 - split smartApp into Parent/Child (IOS hanging on intial startup) - requires complete uninstall and reinstall of Parent and child SmartApps
 * 1/14/18a - updated version check code
 * 9/19/19 - updated voluem control, play/pause, next/previous track and mute/unmute for the
 *			new capabilities of the Sonos speakers.
definition(
    name: "ABC Manager Sonos Update",
    namespace: "gszabados",
    singleInstance: true,
    author: "Stephan Hackett, updated Gabor Szabados",
    description: "Configure devices with buttons like the Aeon Labs Minimote and Lutron Pico Remotes.",
    category: "My Apps",
    iconUrl: "https://cdn.rawgit.com/stephack/ABC/master/resources/images/abcNew.png",
    iconX2Url: "https://cdn.rawgit.com/stephack/ABC/master/resources/images/abcNew.png",
    iconX3Url: "https://cdn.rawgit.com/stephack/ABC/master/resources/images/abcNew.png",
preferences {
	page(name: "mainPage")
    page(name: "aboutPage")
def mainPage() {
	return dynamicPage(name: "mainPage", title: "", install: true, uninstall: true) {
    	def childApps = getAllChildApps()
        def childVer = "InitialSetup"
        if(childApps.size() > 0) {
        	childVer = childApps.first().version()
        section("Create a new button device mapping.") {
            app(name: "childApps", appName: "ABC Child Creator Sonos Update", namespace: "gszabados", title: "New Button Device Mapping", multiple: true)
        section("Version Info, User's Guide") {
       	href (name: "aboutPage", title: "Advanced Button Controller \n"+childVer,
       		description: "Tap to get Smartapp Info and User's Guide.",
       		image: verImgCheck(childVer), required: false, // check repo for image that matches current version. Displays update icon if missing
       		page: "aboutPage"
        remove("Uninstall ABC App","WARNING!!","This will remove the ENTIRE SmartApp, including all configs listed above.")
def verImgCheck(childVer){
	def params = [
    	uri: "https://cdn.rawgit.com/stephack/ABC/master/resources/images/abc_${childVer}.png",
	try {
   		httpGet(params) { resp ->
        	resp.headers.each {
           	//log.debug "${it.name} : ${it.value}"
            log.debug "ABC appears to be running the latest Version"
        	return params.uri
	} catch (e) {
    	log.error "ABC does not appear to be the latest version: Please update from IDE"
    	return "https://cdn.rawgit.com/stephack/ABC/master/resources/images/update.png"
def installed() {
	initialize()
def updated() {
	unsubscribe()
	initialize()
def initialize() {
def aboutPage() {
	dynamicPage(name: "aboutPage", title: none){
        textHelp()
private def textHelp() {
	def text =
	section("User's Guide - Advanced Button Controller") {
    	paragraph "This smartapp allows you to use a device with buttons including, but not limited to:\n\n  Aeon Labs Minimotes\n"+
    	"  HomeSeer HS-WD100+ switches**\n  HomeSeer HS-WS100+ switches\n  Lutron Picos***\n\n"+
		"It is a heavily modified version of @dalec's 'Button Controller Plus' which is in turn"+
        " a version of @bravenel's 'Button Controller+'."
	section("Some of the included changes are:"){
        paragraph "A complete revamp of the configuration flow. You can now tell at a glance, what has been configured for each button."+
        "The button configuration page has been collapsed by default for easier navigation."
        paragraph "The original apps were hardcoded to allow configuring 4 or 6 button devices."+
        " This app will automatically detect the number of buttons on your device or allow you to manually"+
        " specify (only needed if device does not report on its own)."
		paragraph "Allows you to give your buton device full speaker control including: Play/Pause, NextTrack, Mute, VolumeUp/Down."+
    	"(***Standard Pico remotes can be converted to Audio Picos)\n\nThe additional control options have been highlighted below."
	section("Available Control Options are:"){
        paragraph "	Switches - Toggle \n"+
        "	Switches - Turn On \n"+
        "	Switches - Turn Off \n"+
        "	Dimmers - Toggle \n"+
        "	Dimmers - Set Level (Group 1) \n"+
        "	Dimmers - Set Level (Group 2) \n"+
        "	*Dimmers - Inc Level \n"+
        "	*Dimmers - Dec Level \n"+
        "	Fans - Low, Medium, High, Off \n"+
        "	Shades - Up, Down, or Stop \n"+
        "	Locks - Unlock Only \n"+
        "	Speaker - Play/Pause \n"+
        "	*Speaker - Next Track \n"+
        "	*Speaker - Previous Track \n"+
        "	*Speaker - Mute/Unmute \n"+
        "	*Speaker - Volume Up \n"+
        "	*Speaker - Volume Down \n"+
        "	Set Modes \n"+
        "	Run Routines \n"+
        "	Sirens - Toggle \n"+
        "	Push Notifications \n"+
        "	SMS Notifications"
	section ("** Quirk for HS-WD100+ on Button 5 & 6:"){
        paragraph "Because a dimmer switch already uses Press&Hold to manually set the dimming level"+
        " please be aware of this operational behavior. If you only want to manually change"+
        " the dim level to the lights that are wired to the switch, you will automatically"+
        " trigger the 5/6 button event as well. And the same is true in reverse. If you"+
        " only want to trigger a 5/6 button event action with Press&Hold, you will be manually"+
        " changing the dim level of the switch simultaneously as well.\n"+
        "This quirk doesn't exist of course with the HS-HS100+ since it is not a dimmer."
	section("*** Lutron Pico Requirements:"){
        paragraph "Lutron Picos are not natively supported by SmartThings. A Lutron SmartBridge Pro, a device running @njschwartz's python script (or node.js) and the Lutron Caseta Service Manager"+
    	" SmartApp are also required for this functionality!\nSearch the forums for details."
@hypyke, this is the second part…
This is the Child SmartApp to save ONLY.
DO NOT PUBLISH!
/*	DO NOT PUBLISH !!!!
 *	Child Creator - Advanced Button Controller
 *	Author: SmartThings, modified by Bruce Ravenel, Dale Coffing, Stephan Hackett, updated Gabor Szabados
 * 1/14/18 - updated Version check code
 * 1/15/18 - added icon support for Inovelli Switches (NZW30S and NZW31S)
 *		   - small adjustments to "Configure Button" page layout
 * 1/28/18 - Added Icons and details for Remotec ZRC-90US Button Controller.
 * 2/08/18 - reformatted Button Config Preview
 * 2/12/18 - re-did getDescription() to only diplay Pushed/Held preview if it exists
 *			restructured detailsMap and button config build for easy editting
 *			made subValue inputs "hidden" and "required" when appropriate
def version(){"v0.2.190919"}
definition(
    name: "ABC Child Creator Sonos Update",
    description: "SHOULD NOT BE PUBLISHED",
    parent: "gszabados:ABC Manager Sonos Update",
preferences {
	page(name: "chooseButton")
	page(name: "configButtonsPage")
	page(name: "timeIntervalInput", title: "Only during a certain time") {
		section {
			input "starting", "time", title: "Starting", required: false
			input "ending", "time", title: "Ending", required: false
def chooseButton() {
	dynamicPage(name: "chooseButton", install: true, uninstall: true) {
		section("Step 1: Select Your Button Device") {
			input "buttonDevice", "capability.button", title: "Button Device", multiple: false, required: true, submitOnChange: true
        if(buttonDevice){
        	state.buttonType =  buttonDevice.typeName
            if(state.buttonType.contains("Aeon Minimote")) state.buttonType =  "Aeon Minimote"
            log.debug "Device Type is now set to: "+state.buttonType
            state.buttonCount = manualCount?: buttonDevice.currentValue('numberOfButtons')
            //if(state.buttonCount==null) state.buttonCount = buttonDevice.currentValue('numButtons')	//added for kyse minimote(hopefully will be updated to correct attribute name)
            section("Step 2: Configure Your Buttons"){
            	if(state.buttonCount<1) {
                	paragraph "The selected button device did not report the number of buttons it has. Please specify in the Advanced Config section below."
                else {
                	for(i in 1..state.buttonCount){
                		href "configButtonsPage", title: "Button ${i}", state: getDescription(i)!="Tap to configure"? "complete": null, description: getDescription(i), params: [pbutton: i]
        section("Set Custom Name (Optional)") {
        	label title: "Assign a name:", required: false
        section("Advanced Config:", hideable: true, hidden: hideOptionsSection()) {
            	input "manualCount", "number", title: "Set/Override # of Buttons?", required: false, description: "Only set if DTH does not report", submitOnChange: true
                input "collapseAll", "bool", title: "Collapse Unconfigured Sections?", defaultValue: true
                input "hwSpecifics", "bool", title: "Hide H/W Specific Details?", defaultValue: false
        section(title: "Only Execute When:", hideable: true, hidden: hideOptionsSection()) {
			def timeLabel = timeIntervalLabel()
			href "timeIntervalInput", title: "Only during a certain time", description: timeLabel ?: "Tap to set", state: timeLabel ? "complete" : null
			input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
					options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
			input "modes", "mode", title: "Only when mode is", multiple: true, required: false
def configButtonsPage(params) {
	if (params.pbutton != null) state.currentButton = params.pbutton.toInteger()
	dynamicPage(name: "configButtonsPage", title: "CONFIGURE BUTTON ${state.currentButton}:\n${state.buttonType}", getButtonSections(state.currentButton))
def getButtonSections(buttonNumber) {
	return {
    	def picNameNoSpace = "${state.buttonType}${state.currentButton}.png"-" "-" "-" "-"/"-"-"
        //log.debug picNameNoSpace
        section(){	//"Hardware specific info on button selection:") {
			if(hwSpecifics== false) paragraph image: "https://cdn.rawgit.com/stephack/ABC/master/resources/images/${picNameNoSpace}", "${getSpecText()}"
        def myDetail
        for(i in 1..17) {//Build 1st 17 Button Config Options
        	myDetail = getPrefDetails().find{it.sOrder==i}
        	section(myDetail.secLabel, hideable: true, hidden: !(shallHide("${myDetail.id}${buttonNumber}") || shallHide("${myDetail.sub}${buttonNumber}"))) {
				input "${myDetail.id}${buttonNumber}_pushed", myDetail.cap, title: "When Pushed", multiple: true, required: false, submitOnChange: collapseAll
				if(myDetail.sub && isReq("${myDetail.id}${buttonNumber}_pushed")) input "${myDetail.sub}${buttonNumber}_pushed", "number", title: myDetail.sTitle, multiple: false, required: isReq("${myDetail.id}${buttonNumber}_pushed"), description: myDetail.sDesc
				if(showHeld()) input "${myDetail.id}${buttonNumber}_held", myDetail.cap, title: "When Held", multiple: true, required: false, submitOnChange: collapseAll
				if(myDetail.sub && isReq("${myDetail.id}${buttonNumber}_held")) input "${myDetail.sub}${buttonNumber}_held", "number", title: myDetail.sTitle, multiple: false, required: isReq("${myDetail.id}${buttonNumber}_held"), description: myDetail.sDesc
        	if(i==3 || i==8 || i==13 || i==17) section(" "){}
		section("Set Mode", hideable: true, hidden: !shallHide("mode_${buttonNumber}")) {
			input "mode_${buttonNumber}_pushed", "mode", title: "When Pushed", required: false, submitOnChange: collapseAll
			if(showHeld())input "mode_${buttonNumber}_held", "mode", title: "When Held", required: false, submitOnChange: collapseAll
		def phrases = location.helloHome?.getPhrases()*.label
		if (phrases) {
        	section("Run Routine", hideable: true, hidden: !shallHide("phrase_${buttonNumber}")) {
				//log.trace phrases
				input "phrase_${buttonNumber}_pushed", "enum", title: "When Pushed", required: false, options: phrases, submitOnChange: collapseAll
				if(showHeld()) input "phrase_${buttonNumber}_held", "enum", title: "When Held", required: false, options: phrases, submitOnChange: collapseAll
        section("Notifications:\nSMS, In App or Both", hideable: true, hidden: !shallHide("notifications_${buttonNumber}")) {
        paragraph "****************\nWHEN PUSHED\n****************"
			input "notifications_${buttonNumber}_pushed", "text", title: "Message", description: "Enter message to send", required: false, submitOnChange: collapseAll
            input "phone_${buttonNumber}_pushed","phone" ,title: "Send Text To", description: "Enter phone number", required: false, submitOnChange: collapseAll
            input "valNotify${buttonNumber}_pushed","bool" ,title: "Notify In App?", required: false, defaultValue: false, submitOnChange: collapseAll
            if(showHeld()) { paragraph "*************\nWHEN HELD\n*************"
				input "notifications_${buttonNumber}_held", "text", title: "Message", description: "Enter message to send", required: false, submitOnChange: collapseAll
				input "phone_${buttonNumber}_held", "phone", title: "Send Text To", description: "Enter phone number", required: false, submitOnChange: collapseAll
				input "valNotify${buttonNumber}_held", "bool", title: "Notify In App?", required: false, defaultValue: false, submitOnChange: collapseAll
        if(enableSpec()){
        	section(" "){}
			section("Special", hideable: true, hidden: !shallHide("container_${buttonNumber}")) {
				input "container_${buttonNumber}_pushed", "device.VirtualContainer", title: "When Pushed", required: false, submitOnChange: collapseAll
				if(showHeld())input "container_${buttonNumber}_held", "device.VirtualContainer", title: "When Held", required: false, submitOnChange: collapseAll
def enableSpec() {
	return false
def showHeld() {
	if(state.buttonType.contains("100+ ")) return false
	else return true
def shallHide(myFeature) {
	if(collapseAll) return (settings["${myFeature}_pushed"]||settings["${myFeature}_held"]||settings["${myFeature}"])
	return true
def isReq(myFeature) {
    (settings[myFeature])? true : false
def getDescription(dNumber) {
    def descript = ""
    if(!(settings.find{it.key.contains("_${dNumber}_")})) return "Tap to configure"
    if(settings.find{it.key.contains("_${dNumber}_pushed")}) descript = "\nPUSHED:"+getDescDetails(dNumber,"_pushed")+"\n"
    if(settings.find{it.key.contains("_${dNumber}_held")}) descript = descript+"\nHELD:"+getDescDetails(dNumber,"_held")+"\n"
    //if(anySettings) descript = "PUSHED:"+getDescDetails(dNumber,"_pushed")+"\n\nHELD:"+getDescDetails(dNumber,"_held")//"CONFIGURED : Tap to edit"
	return descript
def getDescDetails(bNum, type){
	def numType=bNum+type
	def preferenceNames = settings.findAll{it.key.contains("_${numType}")}.sort()		//get all configured settings that: match button# and type, AND are not false
    if(!preferenceNames){
    	return " **Not Configured** "
    else {
    	def formattedPage =""
    	preferenceNames.each {eachPref->
        	def prefDetail = getPrefDetails().find{eachPref.key.contains(it.id)}	//gets decription of action being performed(eg Turn On)
        	def prefDevice = " : ${eachPref.value}" - "[" - "]"											//name of device the action is being performed on (eg Bedroom Fan)
            def prefSubValue = settings[prefDetail.sub + numType]?:"(!Missing!)"
            if(prefDetail.type=="normal") formattedPage += "\n- ${prefDetail.desc}${prefDevice}"
            if(prefDetail.type=="hasSub") formattedPage += "\n- ${prefDetail.desc}${prefSubValue}${prefDevice}"
            if(prefDetail.type=="bool") formattedPage += "\n- ${prefDetail.desc}"
		return formattedPage
def installed() {
	initialize()
def updated() {
	unsubscribe()
	initialize()
def initialize() {
    log.debug "INITIALIZED with settings: ${settings}"
	app.label==app.name?app.updateLabel(defaultLabel()):app.updateLabel(app.label)
	subscribe(buttonDevice, "button", buttonEvent)
    state.lastshadesUp = true
def defaultLabel() {
	return "${buttonDevice} Mapping"
def getPrefDetails(){
	def detailMappings =
    	[[id:'lightOn_', sOrder:1, desc:'Turn On ', comm:turnOn, type:"normal", secLabel: "Switches (Turn On)", cap: "capability.switch"],
         [id:'lights_', sOrder:3, desc:'Toggle On/Off', comm:toggle, type:"normal", secLabel: "Switches (Toggle On/Off)", cap: "capability.switch"],
     	 [id:"lightOff_", sOrder:2, desc:'Turn Off', comm:turnOff, type:"normal", secLabel: "Switches (Turn Off)", cap: "capability.switch"],
     	 [id:"lightDim_", sOrder:4, desc:'Dim to ', comm:turnDim, sub:"valLight", type:"hasSub", secLabel: "Dimmers (On to Level - Group 1)", cap: "capability.switchLevel", sTitle: "Bright Level", sDesc:"0 to 100%"],
     	 [id:"lightD2m_", sOrder:5, desc:'Dim to ', comm:turnDim, sub:"valLight2", type:"hasSub", secLabel: "Dimmers (On to Level - Group 2)", cap: "capability.switchLevel", sTitle: "Bright Level", sDesc:"0 to 100%"],
         [id:'dimPlus_', sOrder:6, desc:'Brightness +', comm:levelUp, sub:"valDimP", type:"hasSub", secLabel: "Dimmers (Increase Level By)", cap: "capability.switchLevel", sTitle: "Increase by", sDesc:"0 to 15"],
     	 [id:'dimMinus_', sOrder:7, desc:'Brightness -', comm:levelDown, sub:"valDimM", type:"hasSub", secLabel: "Dimmers (Decrease Level By)", cap: "capability.switchLevel", sTitle: "Decrease by", sDesc:"0 to 15"],
         [id:'lightsDT_', sOrder:8, desc:'Toggle Off/Dim to ', comm:dimToggle, sub:"valDT", type:"hasSub", secLabel: "Dimmers (Toggle OnToLevel/Off)", cap: "capability.switchLevel", sTitle: "Bright Level", sDesc:"0 to 100%"],
         [id:"speakerpp_", sOrder:9, desc:'Toggle Play/Pause', comm:speakerplaystate, type:"normal", secLabel: "Speakers (Toggle Play/Pause)", cap: "capability.mediaPlayback"],
     	 [id:'speakervu_', sOrder:10, desc:'Volume +', comm:levelUp, sub:"valSpeakU", type:"hasSub", secLabel: "Speakers (Increase Vol By)", cap: "capability.audioVolume", sTitle: "Increase by", sDesc:"0 to 15"],
     	 [id:"speakervd_", sOrder:11, desc:'Volume -', comm:levelDown, sub:"valSpeakD", type:"hasSub", secLabel: "Speakers (Decrease Vol By)", cap: "capability.audioVolume", sTitle: "Decrease by", sDesc:"0 to 15"],
         [id:'speakernt_', sOrder:12, desc:'Next Track', comm:speakernexttrack, type:"normal", secLabel: "Speakers (Go to Next Track)", cap: "capability.mediaTrackControl"],
         [id:'speakerpt_', sOrder:13, desc:'Previous Track', comm:speakerprevioustrack, type:"normal", secLabel: "Speakers (Go to Previous Track)", cap: "capability.mediaTrackControl"],
    	 [id:'speakermu_', sOrder:14, desc:'Mute', comm:speakermute, type:"normal", secLabel: "Speakers (Toggle Mute/Unmute)", cap: "capability.audioMute"],
         [id:'sirens_', sOrder:15, desc:'Toggle', comm:toggle, type:"normal", secLabel: "Sirens (Toggle)", cap: "capability.alarm"],
     	 [id:"locks_", sOrder:16, desc:'Lock', comm:setUnlock, type:"normal", secLabel: "Locks (Lock Only)", cap: "capability.lock"],
     	 [id:"fanAdjust_", sOrder:17,desc:'Adjust', comm:adjustFan, type:"normal", secLabel: "Fans (Adjust - Low, Medium, High, Off)", cap: "capability.switchLevel"],
     	 [id:"shadeAdjust_", sOrder:18,desc:'Adjust', comm:adjustShade, type:"normal", secLabel: "Shades (Adjust - Up, Down, or Stop)", cap: "capability.doorControl"],
     	 [id:"mode_", desc:'Set Mode', comm:changeMode, type:"normal"],
     	 [id:"phrase_", desc:'Run Routine', comm:runRout, type:"normal"],
		 [id:"notifications_", desc:'Send Push Notification', comm:messageHandle, sub:"valNotify", type:"bool"],
     	 [id:"phone_", desc:'Send SMS', comm:smsHandle, sub:"notifications_", type:"normal"],
         [id:"container_", desc:'Cycle Playlist', comm:cyclePL, type:"normal"],
    return detailMappings
def buttonEvent(evt) {
	if(allOk) {
    	def buttonNumber = evt.jsonData.buttonNumber
		def pressType = evt.value
		log.debug "$buttonDevice: Button $buttonNumber was $pressType"
    	def preferenceNames = settings.findAll{it.key.contains("_${buttonNumber}_${pressType}")}
    	preferenceNames.each{eachPref->
        	def prefDetail = getPrefDetails()?.find{eachPref.key.contains(it.id)}		//returns the detail map of id,desc,comm,sub
        	def PrefSubValue = settings["${prefDetail.sub}${buttonNumber}_${pressType}"]	//value of subsetting (eg 100)
        	if(prefDetail.sub) "$prefDetail.comm"(eachPref.value,PrefSubValue)
        	else "$prefDetail.comm"(eachPref.value)
def turnOn(devices) {
	log.debug "Turning On: $devices"
	devices.on()
def turnOff(devices) {
	log.debug "Turning Off: $devices"
	devices.off()
def turnDim(devices, level) {
	log.debug "Dimming (to $level): $devices"
	devices.setLevel(level)
def adjustFan(device) {
	log.debug "Adjusting: $device"
	def currentLevel = device.currentLevel
	if(device.currentSwitch == 'off') device.setLevel(15)
	else if (currentLevel < 34) device.setLevel(50)
  	else if (currentLevel < 67) device.setLevel(90)
	else device.off()
def adjustShade(device) {
	log.debug "Shades: $device = ${device.currentMotor} state.lastUP = $state.lastshadesUp"
	if(device.currentMotor in ["up","down"]) {
    	state.lastshadesUp = device.currentMotor == "up"
    	device.stop()
    } else {
    	state.lastshadesUp ? device.down() : device.up()
//    	if(state.lastshadesUp) device.down()
//        else device.up()
        state.lastshadesUp = !state.lastshadesUp
def speakerplaystate(device) {
	log.debug "Toggling Play/Pause: $device"
	device.currentValue('playbackStatus').contains('playing')? device.stop() : device.play()
def speakernexttrack(device) {
	log.debug "Next Track Sent to: $device"
	device.nextTrack()
def speakerprevioustrack(device) {
	log.debug "Previous Track Sent to: $device"
	device.previousTrack()
def speakermute(device) {
	log.debug "Toggling Mute/Unmute: $device"
	device.currentValue('mute').contains('unmuted')? device.mute() : device.unmute()
def levelUp(device, inclevel) {
	log.debug "Incrementing Level (by +$inclevel: $device"
	def currentVol = device.currentValue('volume')[0]	//currentlevel return a list...[0] is first item in list ie volume level
    def newVol = currentVol + inclevel
  	device.setVolume(newVol)
    log.debug "Level increased by $inclevel to $newVol"
def levelDown(device, declevel) {
	log.debug "Decrementing Level (by -declevel: $device"
    def newVol = currentVol.toInteger()-declevel
    log.debug "Level decreased by $declevel to $newVol"
def setUnlock(devices) {
	log.debug "Locking: $devices"
	devices.lock()
def toggle(devices) {
	log.debug "Toggling: $devices"
	if (devices*.currentValue('switch').contains('on')) {
		devices.off()
	else if (devices*.currentValue('switch').contains('off')) {
		devices.on()
	else if (devices*.currentValue('alarm').contains('off')) {
        devices.siren()
	else {
		devices.on()
def dimToggle(devices, dimLevel) {
	log.debug "Toggling On/Off | Dimming (to $dimLevel): $devices"
	if (devices*.currentValue('switch').contains('on')) devices.off()
	else devices.setLevel(dimLevel)
def runRout(rout){
	log.debug "Running: $rout"
	location.helloHome.execute(rout)
def messageHandle(msg, inApp) {
	if(inApp==true) {
    	log.debug "Push notification sent"
    	sendPush(msg)
def smsHandle(phone, msg){
    log.debug "SMS sent"
    sendSms(phone, msg ?:"No custom text entered on: $app.label")
def changeMode(mode) {
	log.debug "Changing Mode to: $mode"
	if (location.mode != mode && location.modes?.find { it.name == mode }) setLocationMode(mode)
def cyclePL(device) {
	//int currPL = device.currentValue('lastRun')
   // int nextPL = currPL+1
    device.cycleChild()
    //device.on(nextPL)
// execution filter methods
private getAllOk() {
	modeOk && daysOk && timeOk
private getModeOk() {
	def result = !modes || modes.contains(location.mode)
	log.trace "modeOk = $result"
	result
private getDaysOk() {
	def result = true
	if (days) {
		def df = new java.text.SimpleDateFormat("EEEE")
		if (location.timeZone) {
			df.setTimeZone(location.timeZone)
		else {
			df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
		def day = df.format(new Date())
		result = days.contains(day)
	log.trace "daysOk = $result"
	result
private getTimeOk() {
	def result = true
	if (starting && ending) {
		def currTime = now()
		def start = timeToday(starting).time
		def stop = timeToday(ending).time
		result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
	log.trace "timeOk = $result"
	result
private hhmm(time, fmt = "h:mm a") {
	def t = timeToday(time, location.timeZone)
	def f = new java.text.SimpleDateFormat(fmt)
	f.setTimeZone(location.timeZone ?: timeZone(time))
	f.format(t)
private hideOptionsSection() {
	(starting || ending || days || modes || manualCount) ? false : true
private timeIntervalLabel() {
	(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
	def text =
        "	Set Modes \n"+
        "	Run Routines \n"+
def getSpecText(){
	if(state.buttonType == "Lutron Pico") {
    	switch (state.currentButton){
        	case 1: return "Top Button"; break
			case 2: return "Bottom Button"; break
			case 3: return "Middle Button";break
			case 4: return "Up Button"; break
			case 5: return "Down Button"; break
	if(state.buttonType.contains("Aeon Minimote")) {
        	case 1: return "Top Left Button"; break
			case 2: return "Top Right Button"; break
			case 3: return "Lower Left Button";break
			case 4: return "Lower Right"; break
	if(state.buttonType.contains("WD100+ Dimmer")) {
        	case 1: return "Double-Tap Upper Paddle"; break
			case 2: return "Double-Tap Lower Paddle"; break
			case 3: return "Triple-Tap Upper Paddle";break
			case 4: return "Triple-Tap Lower Paddle"; break
            case 5: return "Press & Hold Upper Paddle\n(See user guide for quirks)"; break
			case 6: return "Press & Hold Lower Paddle\n(See user guide for quirks)"; break
			case 7: return "Single Tap Upper Paddle\n(See user guide for quirks)"; break
			case 8: return "Single Tap Lower Paddle\n(See user guide for quirks)"; break
    if(state.buttonType.contains("WS100+ Switch")) {
            case 5: return "Press & Hold Upper Paddle"; break
			case 6: return "Press & Hold Lower Paddle"; break
			case 7: return "Single Tap Upper Paddle";break
			case 8: return "Single Tap Lower Paddle"; break
    if(state.buttonType.contains("Inovelli")) {
        	case 1: return "NOT OPERATIONAL - DO NOT USE"; break
        	case 2: return "2X Tap Upper Paddle = Pushed\n2X Tap Lower Paddle = Held"; break
			case 3: return "3X Tap Upper Paddle = Pushed\n3X Tap Lower Paddle = Held"; break
			case 4: return "4X Tap Upper Paddle = Pushed\n4X Tap Lower Paddle = Held";break
			case 5: return "5X Tap Upper Paddle = Pushed\n5X Tap Lower Paddle = Held"; break
            case 6: return "Hold Upper Paddle = Pushed\nHold Lower Paddle = Held"; break
    if(state.buttonType.contains("ZRC-90")) {
        	case 1: return "Tap or Hold Button 1"; break
        	case 2: return "Tap or Hold Button 2"; break
			case 3: return "Tap or Hold Button 3"; break
			case 4: return "Tap or Hold Button 4";break
			case 5: return "Tap or Hold Button 5"; break
            case 6: return "Tap or Hold Button 6"; break
            case 7: return "Tap or Hold Button 7"; break
        	case 8: return "Tap or Hold Button 8"; break
			case 9: return "2X Tap Button 1\nHold Not Available"; break
			case 10: return "2X Tap Button 2\nHold Not Available";break
			case 11: return "2X Tap Button 3\nHold Not Available"; break
            case 12: return "2X Tap Button 4\nHold Not Available"; break
            case 13: return "2X Tap Button 5\nHold Not Available"; break
        	case 14: return "2X Tap Button 6\nHold Not Available"; break
			case 15: return "2X Tap Button 7\nHold Not Available"; break
			case 16: return "2X Tap Button 8\nHold Not Available";break
    return "Not Specified By Device"
/*FOR NEW INPUTS//////////////
1. add input to config
2. add info to detailMappings including subvalue if needed
3. ensure correct type is used in map..or create a new one with its own formattedPage
FOR NEW BUTTON DEVICE TYPES///////////////
1. ensure device reports buttonNumber
2. if not, add sendEvent to DTH as needed OR just enter manually
3. add any special instructions to getSpecText() using dth name
4. create pics for each button using dthName+dNumber
It should work as the previous version was working, but the previous musicPlayer features have been replaced by the new capabilities of the new LAN Sonos Player WebSocket and the previous track option has been added.
If you want to use the buttons with any device which has the musicPlayer capability, then use the original version of the SmartApp. This is differentiated by the name, as Sonos Update has been added to the name.
Please test it, and let me know if the changed features are not working.
@Paul_Sheldon, do you want to have a look? You could add it to your GitHub repo. I’ve updated the original version of the SmartApp, but not yours with the Color Bulb part.
@GSzabados
Yeah man, Yeah… It seems to work perfectly so far.
Thank you good sir. You are gold.
@hypyke
Yes thank you I’ll review , did you branch of my master and do changes as you can then send a request for me to merge them in. That way we keep only one version live. If not I’ll do a manual merge so everyone will get the updated version.
I also have the Fan Control code to upload too
Regards
Paul
@Paul_Sheldon It was @GSzabados who did the updates.
I think his changes were to REPLACE the music player functionality which, even though deprecated now it seems would still be needed by some folks. A version with both music and media player would be ideal for an official ABC release I would think.
Just what I gleaned from what was written. @GSzabados would know better than I.
Just don’t want other users of ABC to get boned. :slight_smile:
Hi Paul,
I haven’t read through the whole thread when grabbed ABC for myself. So it is based on the original code. I’ve just notices your updates from 6 month ago regarding the Hue Color bulbs.
So, a manual update/fork would be required. As I wrote this is for the new Sonos. If anyone use and old DHT, which uses the musicPlayer, then this code is not backward compatible.
Thanks, I’ll look to see if I can add a toggle for Music Player / Sonos and incorporte both
It is not only the capability, but the command has changed too for the volume control. Plus I added the previous track option to the list.
You can get over the volume one if you put an if statement into the command part with the capability in question.
I’ve mostly changed these things only for myself to make my buttons working. It was second that someone asked for it. But why not share the love…
I’ll have a go this weekend and then maybe you could test it for me to see if your side still works
Ok! Send me a PM from where I should get the code. :+1:
I’ve updated the feature branch now, updated slightly so levels are between 0-100 (max & min checks) if you can load and recheck Sonos please. I am checking as much of other functionality. thanks
Ok, I will do tonight. I don’t think that the negative values were any problem, the platform could handle it.
Just a quick question: I’m using ABC for scene control with Zooz switches and Dimmers. I have a couple of rooms that are 3 or 4 way switches with Zooz switches installed at each switch location.
Is there a way to copy my button mappings to use the same mapping on multiple switches in a 3 way setup?
I couldn’t see a way to copy them in either the app or the raw code on the IDE. I’m hoping there’s an easy way, because setting up 4-5 different button presses that utilize 6-7 smart bulbs on numerous switches quickly becomes a big pain.
My buttons were starting to act weird. They would do everything twice. I decided to delete the smart app and start over. After coming here I saw the new child/parent setup. I did that and now get a server error when selecting a button (i.e. 1 or 2) for my device. I then decided to go back to the old app but it us doing the same thing. Any ideas? Thanks for any help.
Edit:
I figured it out. I installed the newer version of the Smartthings app a while ago I went back to the classic app and everything went fine.
Edit:
The weird cycling is still happening.
Hello , does any one have the link for the latest code for this on github ?
@uacolon, here is it:
@Paul_Sheldon takes care of it.
© 2019 SmartThings, Inc. All Rights Reserved. Terms of Use | Privacy Policy
SmartThings; SmartApps®; Physical Graph; Hello, Home; and Hello, Smart Home are all trademarks of the SmartThings, Inc.
