@urman
@geko
Does anyone operate the Lowes Utilitech Siren plugged in to the wall?
I know the AC adapter does not come with it, but wanted to verify it will work.
Are both the Lowes Utilitech and the FortrezZ zwave repeaters?
Thx
@urman
@geko
Thx
Only the FortrezZ is a repeater. The Utilitechs main source of power are batteries, while the FortrezZ is meant to be plugged in.
Battery backup is NO GOOD if it canāt communicate with the cloud because the internet is down as well.
So Andrew, is the siren type ready?
I believe it may be released already. Have you tried pairing it?
I donāt see it on the devices list in IDE.
Me too. I canāt find this functionality anywhere yet.
Iām having problems with my Fortrezz SSA2USR. If I test it without being paired it, the siren goes off and the strobe light works perfectly. However, when part of the network and set to be triggered by a motion sensor, it acts in a weird way. WHen triggered by motion, the siren goes off for less than a second ,then for a second, then for a couple of seconds then stops. Sometimes it goes off for a second and stops.
Anyone experienced similar effects?
Is there anything seriously loud?
I have the FortrezZ and Iām seriously disappointed with how loud it is. Itās in my garage and I can barely hear it upstairs in the house. I can hear it standing in my driveway, but not next door. It sounds like a smoke alarm. I want it to wake up the neighbors if it goes off.
Check zoning, this is not allowed in many cities, even for smoke alarms.
If you meant wake up a specific set of neighbors, you can have them notified in any of several ways.
Any update on whether the Aeotec siren works with SmartThings yet?
It works but itās not yet certified. Weāre looking into a bug related to the strobe-only functionality and hope to have it officially tested and certified within a month.
Utilitech Siren yet?
I have two of them and they work just fine. Set them up through the SmartThings app. Also have them attached through the Minimote to toggle on/offā¦
I use them as well. But just wanted a specific device type so I could see battery.
Most of the time just because your power is out doesnāt mean that your internet necessarily is as well. As long as you have your ST hub and your modem/router plugged into the UPS you should be fine.
Is the Aeotec siren a signal repeater?
Lol 1000k clicks! Flattering
I found this thread while investigating whether I could use the Gocontrol Home Security Suite Z wave devices with the Smartthings hub which I bought at the same time. I didnāt see an answer, but after fiddling a while, it works! It was kind of partially paired at first, I guess. The siren, model number WA105DBZ-1, finally works. I set up an automation and everything.
So as to the title of the thread, ābest wireless siren,ā based on ease of set up Iād say 3/5 stars, but price value is 4/5. Pretty good for the $80 I paid on amazon for this kit.
Though I see itās more costly now.
