In the discussion on the smart chair, you’ll see several posts on making your own pressure sensor which might also be of interest.
You probably already know this part, but for other people reading along, with any of these devices unless they are purposebuilt for going under the mattress you want to put only the dry contact pad under the mattress itself. Then cable it out to the radio/battery so that that piece is in a normal open air location, probably fixed to the side of the bed frame. That way you don’t have to worry about overheating.
