Best Smart Radiator Thermostat with App Control in 2026: Top 2 Picks
Hi everyone,
I’m looking for a smart thermostat that allows me to control my home’s heating through an app. I have come across these two options here:
Sensi Smart Thermostat ST55
ecobee Smart Thermostat Premium
but I’m not sure which one would be the better choice.
I’m mainly interested in easy installation, reliable app control, customizable schedules, and energy savings. Has anyone used either of these models? I’d appreciate your recommendations or suggestions for other good options.
Thanks in advance!
I’ve used the Ecobee - both their older and newer versions. I don’t use it for radiators though. It integrates with ST and provides all of the functions you indicate either locally or via their cloud. As I recall, there is a kit if you don’t have the C wire, but ideally, you have a C wire. it can be DIY installation. Mostly for single or two stage equipment. Energy savings mostly accrue if you leave for work, etc. I’m not aware of, but with its setback feature, you could set back temp more IMHO. Also, the update interval (to use with other devices) is only about once every 10-15 minutes. The newer version has air quality, but it is not exposed to ST.
Thanks for sharing your experience with Ecobee! The SmartThings integration and setback features sound useful. I especially appreciate the information about the C wire and the 10–15 minute update interval. I’ll keep these points in mind while comparing different smart thermostat options. It’s helpful to hear from someone who has used both the older and newer versions.
Hello, I’d lean toward ecobee Premium for its extra features and room sensors, while Sensi is worth considering if you prefer something simpler.
I haven’t used either of those models, but I’d check which one has solid SmartThings support before deciding. Reliable scheduling usually matters more day to day than extra features, so I’d lean towards whichever has better reviews for schedule setup.
