What rule engine are you using? Seems like a lot of sensors and none of them did the trick.
I personally use mostly the Iris Motiom Sensors with webCoRE or SmartLighting.
RBoy
3
It may sounds like an issue with your mesh, either the events aren’t reaching the hub or the commands are reaching your device.
You can open IDE Live Logging and see the flow of events and commands. Make sure you have a few repeaters in your mesh for best performance.
Sorry guys, didn’t see answers till now, need to have my primary email associated with the forum. So the actual issue was that after motion there would a lag of at least 5-10 seconds and if there is another motion in next 10 minutes it won;t do anything. I did try tweaking the jumper but no luck, So far Dome is closet thing working…
