I have been reading through posts for the last 3 hours trying to figure out what the best device handler to use for the GD00Z-4 Zwave garage door opener is. There seem to be quite a few different variations of the code and I wonder if there is a favorite of the bunch. I also noticed that not all of them have a battery indicator for the tilt sensor.
I’m interested in this also.
I use the handler provided by @RBoy. Its called Z-Wavet Linear/GoControl Garage Door Opener with Low Battery Sensor and Switch Capability and can be found on his site. You should know he charges a fee to access his library SmartApps and Device Handlers.
what are you trying to do with it? The default one works great. But if you’re looking to add switch capability, another will be needed.
