What device handler are you using for the GE Z-Wave Plus Smart Lighting & Appliance Control Outdoor Module, On/Off, 1 Weather-Resistant Outlet Cover, Plug-in. I tried using the Z-Wave Switch Generic but I am getting tons of repeated failed commands when I look at the logs in the Smarthings API dashboard “My Devices”. Is there a better DH out there?
I am using the standard Z-Wave Switch with out issue.
Failed commands in this situation usually mean the switch is having trouble staying connected to the mesh, which is almost always a range issue. Although it can be a defective device, it happens.
What messages do you get when you run a zwave repair?
I switched to this DH and it seems to be much better
