Battery Powered Z-Wave or ZigBee LED Light?
#1
Is there such a device? It would be nice to have LED lighting in places you don’t want to run power or an extension cord. Under tables, chairs, etc. Figured it could be possible with battery powered door locks, thermostats and smoke detectors but I haven’t been able to find such a device.
I’m wanting to light some steps on a stand alone riser that’s not adjacent to a wall or near any power source. I see the Tethercell which would work as well, but it’s not SmartThings compatible.
Battery Operated Garden Lights?
#2
The only one I know of is the Hue Go, but it will only run for about 2hours on battery, then it shuts itself off.
The problem is that a light just takes too much battery to also run a radio… There are some decent nonnetworked ones with remote controls or motion detectors. I personally like Mr. beams. But they don’t integrate with SmartThings.
(Kevin) #3
Do you have to have have a radio in it? Or is it more of a ease of turning it on and off?
My first thought is that there are tons of motion activated battery powered lights. I have tons of the round ones from ikea in all my closets. After that, you could use a usb battery pack and a led strip that takes usb, think like the bias lights for tv’s. But they are on when power is applied.
#4
Thanks for the responses. Yeah, that’s a horrible battery time. Plus quite an investment for 4 lights and I think I’d also need the Hue Bridge before I could use it with ST.
It’s for a riser in a home theater, so motion sensors wouldn’t work. I’d prefer it to be radio controlled so I can have them turned off when my canned lighting is on and then turn on when I dim or turn off the canned lighting to view a movie.
#5
Did you ever find a solution for this? I’ve been trying to figure out something similar for both under cabinet lighting and some lights on my bookshelves. I’d like them to be able to be controlled with ST where ever possible. Sounds like I came to the same results as this thread did when I looked in to it a few nights ago. My next thought was to try and find some form of battery operated ZigBee controller to use as a NO/NC switch trigger but so far I haven’t seen anything in that arena yet either.
#6
Unfortunately, no. I’m just going to get some photoelectric night lights since my steps are across from my wall plugs. This will basically perform the effect I was looking for by turning on when the lights dim and turn off when the lights are on.
#7
Seems to be a gap in the market. I have a hue go but that’s limited as mentioned here.
#8
Just a quick update, since this came up in a different thread this week…
There are some battery powered small lights which have an IR remote. These are usually pretty dim, you’re lucky if they’re 50 lm each. And they eat up batteries pretty fast. But they do exist.
As long as the remote is an IR remote (not an RF remote) you can probably control it with a harmony home hub. So if this is a room where you already have a harmony to control the home theater, you could add control of these kinds of lights and automate it through SmartThings.
( The other thread was discussing some display cases in an entertainment room where there was already a harmony.)
Because this is an IR signal, the harmony hub, or one of its IR blaster’s, will have to be line of sight to the light. But it should work.
I’m using this with some flameless candles and it works well for what I want. Home Depot often has a selection of battery operated lights with remotes, and then you can check to see what kind of remote it is. There are some available on Amazon, but the product descriptions aren’t always accurate, so you may need to return them if they’re not a remote that’s compatible.
Again, this isn’t going to work for a regular reading light or anything brighter. You’re talking about the equivalent of 5 to 15 W in an old style light. But it might be an option for closet lights or night lights or party lights.
https://support.myharmony.com/en-us/compatibility
