I would like to build a battery-operated Zigbee or Zwave relay (just on and off, nothing fancy). Has anybody experience with it? I couldn’t find a single off-the-shelf product, but I do not want to use an arduino because of the power consumption (it should run for at least 3-6 month on 2-4 AA/AAA)
The example in the link above is for a ZigBee router device (always on). To get long battery life you will need to convert it to an end device that puts the propeller a sleep and only wakes it when data has been received. The ZigBee spec has this all very well defined.
Please take note this is not a kit or an Arduino (code and go) solution it is a blog post that discuss the parts required and circuit to turn a LED on and off. You could easily modify the circuit and add a relay.
That does not help me. The main goal I have is to replace a wall switch, that does not have a neutral, and where I can not send a current through the wire without activating the device on the switch (for simplicity think a LED lamp).
Why isn’t the relay drawing power from the wire instead of batteries? The aeotec microswitches are often used for this. And they’ll pass a home inspection in most places, which DIY may not.
Without a neutral wire, the z-wave switch does not have power when turned off, so it goes offline.
Fibaro dimmers are a working solution since they don’t require a neutral wire.
I am also looking for a solution to control my roller shutters that don’t have a neutral, so a battery powered switch could do the trick, but I can’t seem to find anything online. Any help would be appreciated.
