RBoy
21
This should be an easy fix, ZigBee devices send battery voltage instead of % like Z-Wave devices. This to me means that the threshold for upper/lower voltage aren’t defined correctly in the ZigBee DTH. I had a look at the DTH it’s using a custom call to the platform API parseSmartThingsBatteryValue to convert the voltage to battery
That’s a custom handler that probably doesn’t use the standard zigbee battery parsing. You can switch it to the smartsense open/closed and I’m guessing the battery % will be fixed and it will run local.
