I have the original Motion Det and the new ones. I can no longer get a battery reading from the original detectors, only from the new ones. Is this the same for everyone else? The old detectors still work and are better at sensing motion at a distance so I continue to use them. Thanks.
If you’re on a V2 hub then the original battery level support is gone for the gen 1 motion sensors. They still work but they are not fully compliant with the V2 hub.
Understood. That would be the case. Thanks.
