Very new here, but not to coding. Two basic questions:
Is there some place you get base code for a device or did someone simply create these from scratch? For example, there are a number of modified door sensor device handlers that all look very similar. I was wondering if that meant they were from some common source that people were pulling from (ie, one of the device handlers listed in the developer interface).
If a device has a number of configurations available and they aren’t exposed via the device handler available for it, how do you add configurations to a device handler? Note: I’m leaving this question in even though I see it in the developer documentation, just in case it is not as simple as it may sound.
