Backets in SmartApps - Smart Lights Code
Hi Friends,
I would like to avoid brackets “[ ]” when use $something or ${something}.
Example:
“Delay Turn On $ActionSwitchesOn”
Will return:
Delay Turn On [switch1, switch2, switch3]
Would like to see:
Delay Turn On switch1, switch2, switch3
I simply want to avoid showing brackets… like in the SmartApp: Smart Lights
Thank you in advance!
“Delay Turn On $ActionSwitchesOn”.replaceAll("[", “”).replaceAll("]", “”)
I think that should work.
Thank you very much for your fast answer, unfortunately, the option proposed did not work…
Any other idea?
Try:
log.debug "Delay Turn On ${ActionSwitchesOn?.join(', ')}"
Edit: more info here.
Fantastic, thank you guys! This works!
Actually even easier the following works:
$ActionSwitchesOn.join()
That’s it…
Now to make it a bit more fun; what about if i wanted to display the different element separated by AND, like this:
$ActionSwitchesOn.SOMTHING
Returns:
switch1 AND switch2 AND switch3 AND switch4
or
switch1, switch2, switch3 AND switch4
Let me know…
Just use a different character in the join call :smile:
