AVM Fritzbox Integration
Hello Community,
Does someone know a way to integrate AVM Fritzbox Smarthome ?
Integrate it in what way? What are you trying to accomplish?
I mean that I can control the AVM devices with Smartthings ( Like the tuya Integration for example)
Is this what you mean?
The Smart Home | AVM International
Yes. That is the system I mean
Looks like there used to be a Groovy SmartApp for it. WIth the shutdown of Groovy apps, someone would have to develop a replacement on the new architecture or develop an Edge driver that would support it. I haven’t seen anything posted.
[OBSOLETE] AVM Fritz DECT 200
Hi, yes of course. I use all Fritz devices such as thermostats or window sensors in the smartthings app. Fritz smart hub + Matter ist the Key. Screenshot_20250125_214250_SmartThings|203x500
More info:
Matter with FRITZ!
Correct, Matter will be the solution. However, currently this only works when a Fritz! SmartHub is present. Products directly connected to Fritz!Box routers will not be visible, because the Fritz!Box products do not currently act as Matter bridges.
