iI am trying to do a simple thing: start the lights when outside visibilty is below a certain threshold. I don’t have any weather station nor light sensor. I was thinking of using weather report to trigger an automation based on visibility report but i am not able to fing any one working. What would you suggest?
I’ve got one of these controlling my lighting automation, and with the DTH written by @erocm1231 for this sensor, I have it reporting lux every 1 minute (instead of a minimum of 8 minutes as offered by the standard DTH provided by Samsung). You must have the sensor on a wired supply for such frequent updating.
This has been working perfectly for the 18mths I have been using it and brings different lights on at different lux levels to suit my needs.
I think you have at least a couple virtual sensor/data sources in ST, but I have not used them for lux/light/visibility in automation, just for reference:
ST/ custom-device-type/ Accuweather Device Device AccuWeather/ [cloudCover] - you’d have to code your own calculation of visibility with time of day, cloudCover and whatever else you could scrape.
ST/ custom-device-type/ Outside-v1 Type SmartWeather Station Tile/ [illuminance] range 0/10000 calculated from time of day and apparent weather .
Not sure if either service will last but it one of the best features of ST customizable service . Hope the decision-makers don’t nuke what makes ST special, like this stuff.
