Good Day,
First post here, although I have used this forum extensively for setting up my home, so a belated thanks to everyone.
I am looking for a way to turn my sauna on remotely. It comes with a remote switch that functions as a momentary relay (afaik). I have included the wiring diagram in the package that I got.
When pressed the the switch has a blue led that turns on, and the sauna starts, when pressed again the led goes off and the sauna turns off.
I would like to hook it up to either a zwave or wifi switch that can be accessed and scheduled through smartthings. I have been looking at devices like this, https://www.amazon.ca/Inching-Self-locking-Wifi-Switch-Module/dp/B0752P57ZG. However this is a bit beyond my expertise.
Ideally I could wire this in tandem, so that I could still use the remote switch or smartthings. I would like to maintain the functionality of the led to notify me if the sauna is on, and have a similar notification in smartthings. For example if I start the sauna from the control panel inside, the app would notify me that the sauna is on, the same way the blue led comes on on the switch.
Any help or guidance would be really appreciated. I just need to know where to get started.
I also found this link which shows a very similar switch to what came with the device. https://mgispeedware.com/product/22mm-push-button-6-pin-red-led/
Thanks,
Mason
