ghesp
(Greg)
December 20, 2015, 7:55pm
1
I’m a bit confused how exactly my SmartThings keeps entering Night mode.
I’ve checked all my routines, but nothing is triggering it to go into night mode automatically. Is there some preset settings or default which triggers Night Mode?
sidjohn1
(sidjohn1)
December 20, 2015, 8:54pm
2
No, check your smartapps too. Logs may help as well.
Logs and SmartThings:
https://graph.api.smartthings.com : This is the first place to go when SmartThings are not acting right. This is also the developer site, even if you’re not geek this is an excellent resource to check logs and forcibly delete smart apps and devices.
Live Logging:
https://graph.api.smartthings.com > Live Logging
This is where real time logs can be found. If you are having problems paring new devices or debugging code, this is a great place to start.
Hub logs:
https://graph.api.smartthings.com > My Hubs > List Events > From Hub
Great place to see hub connectivity all PING’s (I’m Alive) and hub disconnect/reconnect messages can easily be seen here. These entries are historical up to 7 days
Device logs:
https://graph.api.smartthings.com > My Devices > (Choose a de…
