Is it possible for SmartApps to automatically update themselves on a schedule. Such as:
schedule(“0 0 12 1/1 * ? *”, updated)
So it will run the updated method included in all SmartApps every day, so I wouldn’t have to go to the web IDE and update it manually. Is this possible or are there any other ways of updating multiple SmartApps faster?
I have many instances of a single SmartApp being used by multiple Things, and I want to update the app regularly. But since there are so many instances of it, I’d have to click update in the web IDE far too many times if I wanted to push out updates. Will scheduling the updated method work for automatic updates of all the apps, granted I update them all manually one more time.
I have some apps that subscribe to a virtual switch. When the switch is “flipped” it updates the schedule in the SmartApps. I originally created it for when the scheduler failed routinely. I had IFTTT trigger the switch so the schedules were always resurrected. It worked well.
Dang, this doesn’t really solve the problem, as I have a lot of hubs with only 6 or 7 devices on each. Any other ideas? Or is it possible to subscribe to the events of a device that is not on this hub or location?
Good luck. AFAIK ST wasn’t designed with the idea of multiple hubs in the best way possible. Furthermore, I doubt “lots of hubs” was even a wet dream. If you can find a way to have a device visible to all hubs, then one will work. Otherwise, your use case goes outside the scope of the ST and the way a hub works.
How many hubs are you talking? The simplicity of one switch per hub is hard to beat. Maybe someone else has a better idea.
That I can’t answer… I would assume so, I don’t have two hubs to see what’s common to all and what not. Does he have 75 hubs under the same account/location? Does he have 75 accounts? Lots of questions. But I am open to ideas and ready to find solutions
