Hi, under specific dimmer settings, brightness is supposed to be the max brightness for individual bulbs, right?
The individual level settings under āSet these to override the default settingsā are individual dimmer level settings for each bulb, if entered these levels will be applied to the specific dimmer in lieu of the default levels set in the main āDimmers and defaultsā sectionā¦
Sorry for my bad explaining.
Im trying to figure out these specific settings, If I modify the brightness and nothing else on one specific bulb.
I cant figure out what Its doing, I have tried off, 50% , 100%, but nothing happends.
the 4 individual overrides apply to the 4 lux ranges set.
you turn on a dimmer via some other automation, you treat it as a switch.
auto dimmer looks at the current Lux reading, then sets the dimmer level to either the default dimmer level for that lux range, or the specific level if one is set.
I just realized Its probably because I have the circadian daylight coordinator installed, which also dims according to lux but in another way.
Is it possible to have it to automaticly dim without turning switch off / on?
Example If I have 4 modes during s day, make it automaticly dim when it enters a new mode?
If not with this app, maybe some routine I could setup in CoRE? Is it a problem running this along with circadian daylight smartapp? Thanksā¦
Yes, anything is possible, however the app wasnāt written with this use case in mind.
It was specifically written to be mode independent and Lux level dependent, this offers the most flexibility and mitigates the requirement to have multiple mode combinations that are time and or presence dependent, ie day-present, night-present, day-away, night-away and the likeā¦
Just pasting in a modād version of Danielās Weather Station refresh app which updates the Smart Weather Tile when a motion sensor event is triggered. This updates the LUX on the Smart Weather Tile (installed as a device from the web IDE) based on an event trigger, rather than on a timerā¦so much more reliable:
* Manual Weather Refresh
* Copyright 2015 Daniel Vorster
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.01
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Weather Updater",
namespace: "dpvorster",
author: "Daniel Vorster",
description: "Refreshes weather tile",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
section {
input "devices", "capability.temperatureMeasurement", title: "When these devices sends events", multiple: true, required: true
input "weather", "capability.relativeHumidityMeasurement", title: "Update this weather device:", multiple: true, required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(devices, "temperature", appHandler)
subscribe(devices, "motion", appHandler)
weather.refresh()
def appHandler(evt) {
weather.refresh()
Like Mike, Iāve just installed a Fibaro outside in our entry way. ST now has default support for these, which report LUX value every time there is a 200 LUX or more change. You can gain more control over this with a custom device handlerā¦but for Iām sticking with the ST default.
The Weather Tile/Weather Underground method works, but I recently realized the LUX values provided there are all ācalculatedā based on weather and time of day.
Comparing this sensor to the 2015 ST version, and HUE, Fibaro is easily the best so far. Hopefully the Fibaro sensors will stay stable as Iām having to reset random ST (Centralite) sensors almost daily.
Really love this App! Like someone elseās comment, my wife is pretty impressed which is a first on my home automation journey!
Only issue is that my āAuto adjust levels during LUX changesā isnāt working. If a light is on at 30% and the LUX changes to the next threshold, the only way to get my dimmer to change is to power off/on the switch. Iām sure Iām missing something simple in my config but hoped it was an easy fix.
What happened to this? The repo is gone.
Anyone still have a copy of this app? Mikeās repo is gone! Thanks.
Iām also looking for a copy of this! Can someone @ me if itās posted?
Here you go:
* Auto Dimmer V2.1
* Author: Mike Maxwell
1.1 2014-12-21
--updated logging for more clarity
1.2 2014-12-27
--complete rewrite
1.3 2015-01-08
--corrected logic errors (3 lux settings map to 4 lux ranges and dimmer settings)
1.4 2015-02-10
--added refresh for dynamic page dimmer overrides
--added free non commercial usage licensing
--pretty typing cleanup
1.5 2015-02-11
--variable re-name fix
--mapped 100 to 99% dimmer level
1.6 2015-03-01
--fixed dimmer overrides that wouldn't stick sometimes
1.7 2015-05-27
--Had to change mode input and methods, broke for some reason
1.8 2015-06-29
--updated description and renamed app
1.9 2015-09-10
--changed log output for better clarity
2.0 2015-09-29
--complete front end re-write, dynamic pages galore
--implemented dynamic adjustment option, with gradual adjustable ramp rate changes
2.1 2015-09-30
--added dimmer specific level option (off)
definition(
namespace : "MikeMaxwell",
author : "Mike Maxwell",
description : "This add on smartApp automatically adjusts dimmer levels when dimmer(s) are turned on from physical switches or other smartApps.\n" +
"Levels are set based on lux (illuminance) sensor readings and the dimmer levels that you specify." +
"This smartApp does not turn on dimmers directly, this allows you to retain all your existing on/off smartApps.\n"+
"autoDimmer provides intelligent level management to your existing automations.",
category : "My Apps",
iconUrl : "https://s3.amazonaws.com/smartapp-icons/Convenience/smartlights.png",
iconX2Url : "https://s3.amazonaws.com/smartapp-icons/Convenience/smartlights@2x.png",
iconX3Url : "https://s3.amazonaws.com/smartapp-icons/Convenience/smartlights@3x.png"
preferences {
page(name: "main")
page(name: "aboutMe", nextPage : "main")
page(name: "luxPage") //, nextPage : "dimmersPage")
page(name: "dimmersPage", nextPage : "main")
page(name: "overridePage")
page(name: "dimmerOptions")
def installed() {
state.anyOptionsSet = false
init()
def updated() {
unsubscribe()
init()
def init(){
subscribe(dimmers, "switch.on", dimHandler)
subscribe(luxOmatic, "illuminance", luxHandler)
def dimHandler(evt) {
//get the dimmer that's been turned on
def dimmer = dimmers.find{it.id == evt.deviceId}
log.trace "${dimmer.displayName} was turned on..."
setDimmer(dimmer,false)
def luxHandler(evt){
//see if any dimmers are set to auto lux adjust
def autoLuxers = settings.findAll{it.key.endsWith("_autoLux") && it.value == true}
if (autoLuxers){
autoLuxers.each{ al ->
def dimmer = dimmers.find{it.id == al.key.replace("_autoLux","")}
if (dimmer.currentValue("switch") == "on") {
if (evt){
log.trace "${dimmer.displayName} detected a change in illummance..."
} else {
log.trace "${dimmer.displayName} detected a ramp request..."
setDimmer(dimmer,true)
def setDimmer(dimmer,isRamp){
if (modeIsOK()) {
def newLevel = 0
log.debug "modeOK: True"
//get its current dim level
def crntDimmerLevel = dimmer.currentValue("level").toInteger()
//get currentLux reading
def crntLux = luxOmatic.currentValue("illuminance").toInteger()
def prefVar = dimmer.id
def dimVar
if (crntLux < luxDark.toInteger()) {
//log.debug "mode:dark"
prefVar = prefVar + "_dark"
dimVar = dimDark
} else if (crntLux < luxDusk.toInteger()) {
//log.debug "mode:dusk"
prefVar = prefVar + "_dusk"
dimVar = dimDusk
} else if (crntLux < luxBright.toInteger()) {
//log.debug "mode:day"
prefVar = prefVar + "_day"
dimVar = dimDay
} else {
//log.debug "mode:bright"
prefVar = prefVar + "_bright"
dimVar = dimBright
def newDimmerLevel = (this."${prefVar}" ?: dimVar).toInteger()
if (newDimmerLevel == 100) newDimmerLevel = 99
if ( newDimmerLevel == crntDimmerLevel ){
log.info "${dimmer.displayName}, changeRequired: False"
} else {
log.info "${dimmer.displayName}, changeRequired: True"
//if (!this."${prefVar}") log.debug "useDefaults: true"
//else log.debug "useDefaults: False"
if (isRamp) {
if (newDimmerLevel == 0){
log.info "${dimmer.displayName}, currentLevel:${crntDimmerLevel}%, requestedLevel:${newDimmerLevel}%, currentLux:${crntLux}"
dimmer.off()
} else {
def rampRate = dimmer.id
rampRate = rampRate + "_ramp"
def rampInt = (this."${rampRate}" ?: 2).toInteger()
//log.debug "rampRate:${rampInt}"
def rampLevel
if (crntDimmerLevel < newDimmerLevel){
rampLevel = crntDimmerLevel + rampInt
} else {
rampLevel = crntDimmerLevel - rampInt
log.info "${dimmer.displayName}, currentLevel:${crntDimmerLevel}%, requestedLevel:${newDimmerLevel}%, rampLevel:${rampLevel}%, currentLux:${crntLux}"
dimmer.setLevel(rampLevel)
if (rampLevel != newDimmerLevel){
//log.debug "call setDimmer again in 60 seconds..."
runIn(60,luxHandler)
} else {
dimmer.off()
} else {
dimmer.setLevel(newDimmerLevel)
} else {
log.debug "modeOK: False"
/* whatever methods * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */
def modeIsOK() {
def result = !modes || modes.contains(location.mode)
return result
/* page methods * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */
def main(){
def isLuxComplete = luxPageComplete() == "complete"
def isDimComplete = dimmersPageComplete() == "complete"
def allComplete = isLuxComplete && isDimComplete
def toDo = null
if (!isLuxComplete){
toDo = "luxPage"
} else if (!isDimComplete){
toDo = "dimmersPage"
//log.info "main- allComplete: ${allComplete} lux:${isLuxComplete} dim:${isDimComplete}"
return dynamicPage(
,title : "Main Page"
,nextPage : toDo
,install : allComplete
,uninstall : true
section(){
href(
,title : "About Me..."
,required : false
,page : "aboutMe"
,description: null
if (isLuxComplete){
href(
,title : "Illuminance settings..."
,required : false
,page : "luxPage"
,description: null
,state : luxPageComplete()
if (isDimComplete){
href(
,title : "Dimmers and defaults..."
,required : false
,page : "dimmersPage"
,description: null
,state : dimmersPageComplete()
if (allComplete){
href(
,title : "Specific dimmer settings..."
,required : false
,page : "overridePage"
,description: null
,state : anyOptionsSet()
input(
,type : "mode"
,title : "Set for specific mode(s)"
,multiple : true
,required : false
def aboutMe(){
return dynamicPage(name: "aboutMe"){
section ("About Me"){
paragraph "This add on smartApp automatically adjusts dimmer levels when dimmer(s) are turned on from physical switches or other smartApps.\n" +
def luxPage(){
def toDo = null
toDo = "main"
return dynamicPage(name: "luxPage",nextPage: toDo){
section ("Illuminance settings"){
input(
,title : "Use this illuminance Sensor..."
,multiple : false
,required : true
,type : "capability.illuminanceMeasurement"
section("Select Lux levels"){
input(
,title : "It's Dark below this level..."
,multiple : false
,required : true
,type : "enum"
,options : ["10":"10 Lux","25":"25 Lux","50":"50 Lux","75":"75 Lux","100":"100 Lux"]
input(
,title : "Dusk/Dawn is between Dark and here..."
,multiple : false
,required : true
,type : "enum"
,options : ["100":"100 Lux","125":"125 Lux","150":"150 Lux","175":"175 Lux","200":"200 Lux","300":"300 Lux","400":"400 Lux","500":"500 Lux","600":"600 Lux"]
input(
,title : "Overcast is between Dusk/Dawn and here, above this level it's considered Sunny."
,multiple : false
,required : true
,type : "enum"
,options : ["500":"500 Lux","1000":"1000 Lux","1500":"1500 Lux","2000":"2000 Lux","3000":"3000 Lux"]
def dimmersPage(){
return dynamicPage(name: "dimmersPage",title: "Dimmers and defaults"){
section ("Default dim levels for each brigtness range"){
input(
,title : "When it's Dark out..."
,multiple : false
,required : true
,type : "enum"
,options : ["10":"10%","20":"20%","30":"30%","40":"40%","50":"50%","60":"60%","70":"70%","80":"80%","90":"90%","100":"100%"]
input(
,title : "For Dusk/Dawn use this..."
,multiple : false
,required : true
,type : "enum",
input(
,title : "When it's Overcast..."
,multiple : false
,required : true
,type : "enum"
input(
,title : "When it's Sunny..."
,multiple : false
,required : true
,type : "enum"
section ("Dimmers to manage"){
input(
,multiple : true
,required : true
,type : "capability.switchLevel"
def overridePage(){
return dynamicPage(name: "overridePage"){
section("Specific dimmer settings"){
def sortedDimmers = dimmers.sort{it.displayName}
sortedDimmers.each() { dimmer ->
def safeName = dimmer.id
def name = dimmer.displayName
href(
name : safeName + "_pg"
,title : name
,required : false
,page : "dimmerOptions"
,params : [id:safeName,displayName:name]
,description: null
,state : dimmerOptionsSelected(safeName)
def dimmerOptions(params){
def safeName
def displayName
if (params.id) {
safeName = params.id
displayName = params.displayName
} else if (params.params) {
safeName = params.params.id
displayName = params.params.displayName
//log.info "safeName:${safeName} name:${displayName}"
return dynamicPage(name: "dimmerOptions") {
section("${displayName} Options") {
input(
name : safeName + "_autoLux"
,title : "Auto adjust levels during LUX changes"
,required : false
,type : "bool"
input(
name : safeName + "_ramp"
,title : "Percent rate of change for Auto adjust (2% default)"
,multiple : false
,required : false
,type : "enum"
,options : ["1":"1%","2":"2%","5":"5%"]
section("Set these to override the default settings."){
input(
name : safeName + "_dark"
,title : "Dark level"
,multiple : false
,required : false
,type : "enum"
,options : ["0":"Off","10":"10%","20":"20%","30":"30%","40":"40%","50":"50%","60":"60%","70":"70%","80":"80%","90":"90%","100":"100%"]
input(
name : safeName + "_dusk"
,title : "Dusk/Dawn level"
,multiple : false
,required : false
,type : "enum"
input(
name : safeName + "_day"
,title : "Overcast level"
,multiple : false
,required : false
,type : "enum"
input(
name : safeName + "_bright"
,title : "Bright level"
,multiple : false
,required : false
,type : "enum"
/* href methods * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * */
def dimmersPageComplete(){
if (dimmers && dimDark && dimDusk && dimDay && dimBright){
return "complete"
} else {
return null
def dimmerOptionsSelected(safeName){
def optionsList = ["${safeName}_autoLux","${safeName}_dark","${safeName}_dusk","${safeName}_day","${safeName}_bright"]
if (optionsList.find{this."${it}"}){
state.anyOptionsSet = true
return "complete"
} else {
return null
def anyOptionsSet(){
if (state.anyOptionsSet) {
return "complete"
} else {
return null
def luxPageComplete(){
if (luxOmatic && luxDark && luxDusk && luxBright){
return "complete"
} else {
return null
Mike,
Iād love to get hold of a copy of this Smart App but the link appears to be dead.
Is it still hidden away somewhere?
Thanks in advance
