@rogersmj,
Yeah, stuff like this does tend to start getting complex fast… I can think of a handful of ways to accomplish what you’re looking for, sure it all involves write some custom SmartApps and some hardware… though I think it could be done with simple z-wave switches vs. a specific controller.
Using your situation above:
** IF Motion: Then turn on lights dim unless I specify “game mode” then light full bright
Here’s how I would attack it: Motion sensor is in the stairway leading to the basement. If motion is detected, it turns on a virtual tile. Next you have a SmartApp that is designed to run when it see the Virtual Tile turn on. The first thing it does is checks to see if a given switch is on.
This switch will be an ordinary Z-wave light switch that is NOT hooked to any load… just line coming in, and neutral. No load wire.
If the switch is off (default position), the program runs the default set of instructions: Turn on lights 1,2, and 3 at 45%, 60%, and 50% respectively. However, if the switch is on, then we run the alternate set of instructions: Turn on lights 1, 2, and 3 at full brightness.
So essentially the Motion Sensor is the trigger to do something. Then your ordinary Z-wave switch is the toggle telling it to either run one set or instructions, or run a different set of instructions.
There would, of course, be some details to be worked out: For example we need the SmartApp to trigger when it sees that Toggle switch turn on or off. We also need to work out how you want to turn off lights (via a switch? automatically when motion stops?) as well as whether you want the toggle to remember what state it’s in (TV mode or Game mode) or just default back to TV mode.
So, some details, but certainly do able… I don’t think it would be even that terrible complex of an App to write.
It’s also possible that this might be able to be configured even better with an Aeon 4-button remote. I don’t have one of these and have never written an app for it, so I don’t know how it would work exactly, but I envision you’d have a different mode for each button: TV mode, Game mode, “Romantic mode”, off. You’d have the motion sensor still be your trigger to turn on, and probably set it up so it triggers “TV mode” by default, but then each of the other four modes could be triggers easily with a button on the remote.
