I’ve modified the SmartThings energy app (normally turns switches off if an energy threshold is exceeded) to turn on/off selected switches if a set power use threshold is exceeded on monitored Smart Switches.
Normally you would use a remote, or a load sensing outlet to manage a dust collector (vacuum) when a power tool is powered up. I’m using a few inexpensive: Aeon Labs DSC06106-ZWUS - Z-Wave Smart Energy Switches to manage the dust collector automatically. SmartThings Smart Plugs (Zigbee) work well too, but they are only rated to 12 amps. The Aeon Smart Energy Switch monitors energy use, works as a switch, and is rated to 15 amps.
If tools are plugged into one or more selected smart plugs, powering up any tool will trigger selected switches to remotely turn on dust collectors or vacuums, providing tool power draw is above the threshold you select. Once power use is below the set threshold on monitored Smart Plugs, the app powers off the “slave” switches. You can also set an off delay so the dust collector can clear the dust collection tubes after you power off the tool. This frees you to plug tools and vacuums/collectors into separate circuits to avoid popping breakers. This bit of code and a few smartplugs effectively replaces devices like this without the need to run extension cords from separate circuits.
The app below will not work correctly unless you use this very slick device handler for the Aeon. It reports power use changes instantaneously to Smarthings and allows you configure a few options. Make sure you configure ReportType=1 in the device options via the smartphone app: https://raw.githubusercontent.com/constjs/jcdevhandlers/master/devicetypes/jscgs350/my-aeon-metering-switch.src/my-aeon-metering-switch.groovy
Here’s the bit of code you will need to install to yourself using the web ide. I am an absolute code neophyte, so if you see any issues, feel free to comment
- Shop Dust Management Control
- Copyright 2016 Dennis Wood
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
definition(
name: “Dust Collector Switch Control”,
namespace: “denniswood”,
author: “Dennis Wood”,
description: “App to Manage Dust Collector”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
preferences {
section {
input(name: “meter”, type: “capability.powerMeter”, title: “When any of These SmartPlugs…”, required: true, multiple: true, description: null)
input(name: “threshold”, type: “number”, title: “Reports Power use Above…”, required: true, description: “in either watts or kw.”)
input(name: “switches”, type: “capability.switch”, title: “Turn On These Switches”, required: true, multiple: true, description: null)
input(name: “offdelay”, type: “number”, title: “Off Delay when Power Drops (seconds)”, required: true )
def installed() {
log.debug “Installed with settings: ${settings}”
unsubscribe()
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
initialize()
def initialize() {
subscribe(meter, “power”, meterhandler)
def meterhandler(evt) {
def meterValue = evt.value as double
def thresholdValue = threshold as int
log.debug “$evt.displayName is $evt.value”
if (meterValue > thresholdValue) {
switches.on()
else {
def delay = offdelay * 1000
log.debug “Delay is ${delay} ms”
switches.off(delay: delay)
Here are a few pics of the dust collection system. The Dust Deputy Cyclone is very effective at capturing dust/debris.
One of the tool vacuum connections:
Table saw vacuum connection.
2 1/2" system with blast gates.
This Zwave receptacle powers the Rigid vacuum. The app switches it on/off based on the smart switch power use to the tools.
The cyclone captures virtualy all the dust, keeping the vaccum very clean.
Here’s what actually ended up in the cyclone bucket.
The smart switch tool connections.
If you want to use a manual dust control, this works: http://ivacswitch.com/ivac-switch/
If you’re a newbee like I was a few weeks ago, read this:
