Yep already did thanks
definition(
name: “Schedule Switch on by date”,
namespace: “lgkapps”,
author: “lgkahn”,
description: “Control a device , turn on on given date.”,
category: “Green Living”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch@2x.png”
preferences {
section("Select the outlet(s)… "){
input “outlets”, “capability.switch”, title: “Outlets”, multiple: true
section("Start after Date format (yyyymmdd)..."){
input "startDate", "number", title: "Date?"
section("End after Date format (yyyymmdd)..."){
input "endDate", "number", title: "Date?"
section("Time Zone Offset ie -5 etc...."){
input "tzOffset", "number", title: "Offset?", range: "-12..12"
section("Disabled?"){
input "disabled", "bool", title: "Disabled?", defaultValue: false
section( "Notifications" ) {
input("recipients", "contact", title: "Send notifications to") {
input "sendPushMessage", "enum", title: "Send a push notification?", options: ["Yes", "No"], required: false
input "alsoSendTextMessage", "enum", title: "Also Send a text message?", options: ["Yes", "No"], required: false
input "phone1", "phone", title: "Send a Text Message?", required: false
def installed()
log.debug “in switch controller installed”
def updated()
log.debug "in coil controller updated … "
unsubscribe()
if (disabled == null)
disabled = false
// turn off if on
if (disabled == true)
log.debug "Disabled!"
outlets.off()
subscribe(location, "sunrise", sunriseHandler)
def sunriseHandler(evt)
log.debug "in sunrise handler"
log.debug "set offset = $tzOffset"
log.debug “disabled = $disabled”
def today = new Date();
def ltf = new java.text.SimpleDateFormat("yyyyMMdd")
ltf.setTimeZone(TimeZone.getTimeZone("GMT${tzOffset}"))
String date1 = ltf.format(today);
int intdate = Integer.parseInt(date1)
log.debug "int date = $intdate"
log.debug "enddate = $endDate"
log.debug "startdate = $startDate"
def currSwitches = outlets.currentSwitch
def onOutlets = currSwitches.findAll { switchVal -> switchVal == "on" ? true : false }
def onsize = onOutlets.size()
def allsize = outlets.size()
log.debug "Currently Disabled!"
else
if ((intdate >= startDate) && (intdate <= endDate))
// dont do anything if already on
log.debug "In try turn on, number of outlets on = $onsize, total outlets = $allsize."
if (onsize != allsize)
log.debug "turning outlets On as we are within the date range ($startDate - $endDate)!"
mysend("Turning device(s) On as we are within the date range ($startDate - $endDate)!")
outlets.on()
else log.debug "Not turning on again, all already on!"
else
// dont do anything if already off
log.debug "In try turn off, number of outlets On = $onsize."
if (onsize != 0)
log.debug "turning outlets Off! as we are no longer within the date range ($startDate - $endDate)!"
mysend("Turning device(s) Off aw we are no longer within the date range ($startDate - $endDate)!")
outlets.off()
else log.debug "All outlets already off!"
private mysend(msg) {
if (location.contactBookEnabled) {
log.debug(“sending notifications to: ${recipients?.size()}”)
sendNotificationToContacts(msg, recipients)
else {
if (sendPushMessage != “No”) {
log.debug(“sending push message”)
sendPush(msg)
if ((phone1) && (alsoSendTextMessage == "Yes")) {
log.debug("sending text message")
sendSms(phone1, msg)
// log.debug msg
