Anyone install a Ring Pro directly to a transformer?
I finally had a chance to get a Ring Pro, and needed to connect it directly to a transformer. Thanks for this great discussion. There seems to be some mystery to why this is all happening. I’m an electrical engineer, so have insight into this, but am not an expert on these devices. I can describe the issue and some options…
The Ring doorbell devices were designed to be spliced into the loop of a standard doorbell circuit. The Ring must not only do its fancy work, but also act like the switch you replaced so it rings the doorbell. When you use it this way, there is another load in that loop, the doorbell solenoid. That’s the thing that moves the striker to ring the bell. So when you push the button in this normal installation, the switch is shorting out the circuit to some extent in order to ring the bell.
Now… when you connect the Ring Pro directly to a transformer with no bell, you’re shorting out the whole regular transformer with no load in the circuit… bad idea. High current flows in the wire, transformer, and your Ring Pro… which might damage things eventually.
So, this is why the above solutions include a 25 ohm (wire wound) 50 watt resistor in the loop with the transformer and Ring Pro. This acts like a “dummy load” replacing the doorbell. When the button is pushed, the current is limited. The reason the resistor needs to be 50 watts and wire-wound is to keep it from getting too hot should the button be closed for long periods.
Ring also has a couple other solutions for this. One is that they include a Ring Pro Power Kit to help with a couple situations. Situation 1: It is used to jump across the doorbell to get extra power to the Ring Pro. In our case (just a transformer) this is useless. Situation 2: If you look at the instructions online for transformer-only, you will see you can remove the sticker on the device and get to a second set of connections called “Bypass Mode” … which is pretty much exactly like putting the 25 ohm resistor in the loop with the transformer and Ring Pro… it acts like a dummy load. So, you already have what you need in the Ring Pro box to do what you need to install the Ring Pro with transformer only! You can find this instruction in the Ring Pro wiring diagrams for transformer-only use.
What’s inside this Power Pro Kit are more sophisticated devices we don’t need to understand here. I opened up mine out of curiosity and this is what it looks like. The smaller square connector is for Situation 1, and the larger connector is for Situation 2… the bypass mode.
ring power pro kit - small
There is another simpler solution, purchase the Ring Plug-In Adapter For Video Doorbell Pro, which costs $29 each and has a long wire on it with terminals. This plugs into an outlet and connects directly to the Ring Pro. Although the gentleman’s 4-doorbell project was fun and impressive, I bet buying four of these would be way easier. What is this? This is a plug-in transformer with a built in “dummy load” that most transformers do not have… so you don’t have to purchase anything else. Way simpler, although less impressive.
But… don’t forget, when you use a transformer-only installation, you don’t hear anything when the doorbell button is pressed! That’s another issue to solve.
how does this device work for situation 1? best i can figure is that this device acts as a power factor correction due to the striker (which acts as an inductor).
i have a skybell hd, my transformer hums, i wounder if this would silence the transformer?
I just installed one of these for my friend, straight to the wires. She had a mechanical doorbell, so I didn’t need the capacitor. I assumed it would keep the (non-reminders) battery charged, and the doorbell ran entirely on the battery.
Worked on the first try.
I scoured the internet looking for solutions which led me here. I have had success installing a Ring Video Doorbell Pro without any prior doorbell wiring. Here’s what worked for me:
I purchased the following:
Ring Doorbell Pro
Edwards Signalling 599 transformer: https://www.amazon.ca/dp/B00PSMWVM0/ref=pe_3034960_233709270_TE_item
Edwards Signalling 593 Adapter
https://www.amazon.com/Edwards-Signaling-593-Adapter-transformers/dp/B001UKJO8S
Single Gang Old Work Box
18/2 wire
The Edwards transformer with the adapter plate is rated for the enclosed space.
I then made a new hole in my wall for the new box, just above a light switch and adjacent to the outside wall where the doorbell is located.
I took a 16" drill masonry drill bit and drilled through the brick outside - all the way in to where the new electrical box was located. As the box was on a wall perpendicular to the outside wall, it took 16" bit to make it to the box.
I routed some AC wiring from the switch to area where the new box would be installed. I then fed the low voltage wire from the outside at the doorbell to the box location.
I then mounted the transformer to the adapter in the box.
I then installed the box - feeding both wires into it - one on the low voltage side, one on the 110v side of the adapter.
I fastened the box to the studs, hooked everything up and put a cover plate on the box.
Hooked up the low voltage wires to the Ring and mounted per the instructions.
It’s been up and running for several months with no issues whatsoever!
Hope this helps someone out there. Took me a while to figure out this plan!
cheers,
r
The solution to this problem is well explained here
