Anyon had luck with Ring Spotlight Cam Plus Battery
Hi I am new here and already searched on Rings Forum. I bought the Ring Spotlight Cam Plus from the German Webshop TINK where this cam is marked as compatible with ST. But when I try to add it in the App no device shows up. The device works flawless in the Ring App. Any suggestions or is the model not compatible. Thanks for your support
Only the mains powered version of that model is compatible. The batterypowered version is not.
The Product description page on the Tink site is incorrect, so you should talk to them.
