Not sure if anyone has gotten info to come over from smartthings and in the proper way. I just set it up in the smartthings app and I’m getting over a bunch of device info, like charge level, speaker volume, etc. but it doesn’t seem to be in the right format for a traditional vacuum robot entity.
I think I’ve figured out the API call that gets the stream, but not sure how to get that into an actual video stream.
curl -H "Authorization: Bearer {api_key}" -X POST https://api.st-av.net/v1/stream/webrtc?source_id={vacuum_id}
will give me:
something like this:
"stream": {
"stream_id": "{Stream_ID_String}",
"turn_url": "turn:turn.usw2.st-av.net:3478",
"username": "1646189864:{Stream_ID_String}",
"password": "{SomePassword=}"
I’d like to add this to Home-Assistant as well if anyone has any ideas/tips that would be greatly appreciated.
