I hate to do this to everyone but I am a newbie to Smartthings app programming and I’m trying to get my ITACHI IP2IR working:
IP address is 192.168.1.184
I have an IR Blaster on port 3
Here is my code that reports the event fires in the IDE but doesn’t ever get the blaster to transmit either in the IDE or when I try to manually trigger it after installing it on my phone. With the ILEARN app it does fire. Can anyone figure out why when I trip the virtual switch it doesn’t send anything to the ITACHI?
- My First SmartApp
- Copyright 2017 Tim Huey
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
definition(
name: “My First SmartApp”,
namespace: “TimHuey”,
author: “Tim Huey”,
description: “intro to groovy”,
category: “My Apps”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png”)
preferences {
section(“When switch turn on detected:”) {
input “ifswitchon”, “capability.switch”, required: true, title: “What switch?”
/section(“Turn on this light”) {
input “theswitch”, “capability.switch”, required: true
def installed() {
log.debug “Installed with settings: ${settings}”
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
initialize()
def initialize() {
// TODO: subscribe to attributes, devices, locations, etc.
subscribe(ifswitchon, “switch.on”, SwitchOnDetectedHandler)
def SwitchOnDetectedHandler(evt) {
log.debug “SwitchOnDetectedHandler called: $evt"
def deviceNetworkId = “C0A8000C:1386"
def theCom = “sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,1673,343,86,21,3732"
sendHubCommand(new physicalgraph.device.HubAction(”””$theCom\r\n""", physicalgraph.device.Protocol.LAN, deviceNetworkId))
// TODO: implement event handlers
