thank you getting closer… i did as you outlined and even saved the new vid in the device handler and republished but still getting “checking status” on the dashboard view
ie
C:\st>cli-win presentation:device-config:generate 7e6bf0ba-7cb0-40a1-876a-a56adcd2084c --dth -j > st814.json.orig
C:\st>copy st814.json.orig st814.json.new
1 file(s) copied.
C:\st>e st814.json.new
C:\st>dir /od
Volume in drive C is Windows
Volume Serial Number is B259-C6B9
Directory of C:\st
07/31/2020 01:04 PM 99,544,590 cli-win.exe
08/05/2020 03:35 PM 28,301,141 smartthings-win.zip
08/05/2020 03:41 PM 1,090 st814.dv
08/05/2020 03:42 PM smartthings-win
08/05/2020 03:42 PM 0 smartthings.log
08/06/2020 02:15 PM 7,647 st814.json.orig
08/06/2020 02:15 PM .
08/06/2020 02:15 PM …
08/06/2020 02:19 PM 4,480 st814.json.new
6 File(s) 127,858,948 bytes
3 Dir(s) 365,772,607,488 bytes free
C:\st>cli-win presentation:device-config:create -i st814.json.new
mnmn: SmartThingsCommunity
vid: 97ba8873-f610-3322-a2be-ec1650316228
type: dth
dpInfo: null
iconUrl: null
dashboard:
states:
- component: main
capability: temperatureMeasurement
version: 1
values:
visibleCondition: null
actions:
- component: main
version: 1
values:
detailView:
- component: main
version: 1
values:
visibleCondition: null - component: main
capability: relativeHumidityMeasurement
version: 1
values:
capability: battery
version: 1
values:
capability: configuration
version: 1
values:
capability: healthCheck
version: 1
values:
automation:
conditions:- component: main
version: 1
values:
version: 1
values:
capability: battery
version: 1
values:
capability: alarm
version: 1
values:
version: 1
values:
version: 1
values:
actions: - component: main
version: 1
values:
version: 1
values:
capability: battery
version: 1
values:
capability: alarm
version: 1
values:
version: 1
values:
version: 1
values:
- component: main
C:\st>cli-win presentation 97ba8873-f610-3322-a2be-ec1650316228 -j
“mnmn”: “SmartThingsCommunity”,
“vid”: “97ba8873-f610-3322-a2be-ec1650316228”,
“iconUrl”: null,
“dashboard”: {
“states”: [
“label”: “{{temperature.value}} {{temperature.unit}}”,
“alternatives”: [
“key”: “C”,
“value”: “°C”,
“type”: “active”,
“description”: null
“key”: “K”,
“value”: “°K”,
“type”: “active”,
“description”: null
“key”: “F”,
“value”: “°F”,
“type”: “active”,
“description”: null
“group”: null,
“capability”: “temperatureMeasurement”,
“version”: 1,
“component”: “main”,
“visibleCondition”: null
“actions”: ,
“basicPlus”:
“detailView”: [
“version”: 1,
“label”: “___PO_CODE_SMARTTHINGS_DREAM_SAC_TMBODY_TEMPERATURE”,
“displayType”: “slider”,
“toggleSwitch”: null,
“standbyPowerSwitch”: null,
“switch”: null,
“slider”: {
“range”: [
-20,
50
“step”: null,
“unit”: “temperature.unit”,
“command”: null,
“value”: “temperature.value”
“pushButton”: null,
“playPause”: null,
“playStop”: null,
“list”: null,
“textField”: null,
“numberField”: null,
“stepper”: null,
“state”: null,
“multiArgCommand”: null,
“capability”: “relativeHumidityMeasurement”,
“version”: 1,
“label”: “___PO_CODE_SMARTTHINGS_DREAM_SAC_HEADER_HUMIDITY_CHN”,
“switch”: null,
“slider”: {
“range”: [
0,
100
“step”: null,
“unit”: null,
“command”: null,
“value”: “humidity.value”
“pushButton”: null,
“playPause”: null,
“playStop”: null,
“list”: null,
“textField”: null,
“stepper”: null,
“state”: null,
“capability”: “battery”,
“version”: 1,
“label”: “___PO_CODE_SMARTTHINGS_DREAM_SAC_TMBODY_BATTERY”,
“switch”: null,
“slider”: {
“range”: [
0,
100
“step”: null,
“unit”: null,
“command”: null,
“value”: “battery.value”
“pushButton”: null,
“playPause”: null,
“playStop”: null,
“list”: null,
“textField”: null,
“stepper”: null,
“state”: null,
“automation”: {
“conditions”: [
“version”: 1,
“displayType”: “numberField”,
“slider”: null,
“list”: null,
“numberField”: {
“value”: “temperature.value”,
“range”: [
-20,
50
“textField”: null,
“emphasis”: null,
“version”: 1,
“slider”: null,
“list”: null,
“numberField”: {
“value”: “humidity.value”,
“unit”: null,
