Hey guys,
Unfortunately, I have to come back hoping for a hint or solution to a wiring issue I have. While my father in law is out of country, I wanted to get this hammered out.
I have a pendant light at my entry way door, that is on a 3-way switch. Unfortunately, I was an idiot when I started wiring GE switches, and never took enough pictures of this mess of wiring. But I have learned to trace this all pretty good, and think I know what everything is.
I have a standard GE switch, and the 12723 Add-on Switch. Downstairs, I have power coming in from the breaker, it powers two other GE switches (exterior house, and exterior entryway) (working fine) and this switch (interior entryway). All switches power on and report to the hub. Additionally, all 3 switches light the respective lights properly at this time.
I have all my neutrals pigtailed, and then attached to each of the three switches, and I have my two loads (for my first two switches) functioning perfectly. (By the way, this is a total of 7 bundles of wires going into a 3 gang box… ugh). Lastly, I have all my grounds pigtailed, and attached to all three switches. These first two switches are just standard 2-way switches.
Now for the problem I am having… On the 3-way, upstairs, I have only 1 set of wires coming in. 1 Ground, 1 Neutral, 1 Black, 1 Red. With the circuit on, and the bblack/red wires unplugged from any switch downstairs, both the black and red get no power (from my no-contact elec. detector). If I check, the 3-way master is hot on the traveler screw as well. (Noted to state its functioning at the switch itself).
The upstairs switch is wired with neutral, ground, and red as the traveler (as it was for the rest of my GE 3-ways). I capped the black at both ends.
So walking through this once I wired upstairs… I go downstairs, I pull the red wire to the 3-way master, into the traveler screw, lock it down, flip the breaker. I check and the black wire between the floors (believed to be) is generating no heat/power. I go upstairs, black is still “dead”. This is a good thing seeing as I believe its not plugged into anything–and it seems it is not. Yay.Then I check the traveler wire, and its hot. I go downstairs, the switch activates the light. I go upstairs…and nothing. The switch is a dummy switch, doing nothing.
I then tried to run the black and red wire, both travelers, at both sides. Nothing. This way, I do have voltage running across the wire on red and black, but cant control the 3-way from upstairs.
In attached picture, I show the wiring as currently setup. The switch in question is on the far left. The power is coming in from breaker in the far right. There is a “stray” wire in the upper right, which appears to be a dead wire, to my outside lights–which work fine. It seems it was just capped outside in the light box, but yet was energized. Last to note, the load appears to be accurate on second switch—its turning the second set of lights on (Exterior entryway light).
Any thoughts appreciated… I am at a loss here. Hours of trial and error—and talks with a coworker who use to be an electrician. At this point, I am wondering if one of my switches is bad? or I am doing something dumb. Both can be true too…
Thanks guys!
