# Announcing HousePanel Control Panel \[Alpha\]
**URL:** <https://community.smartthings.com/t/announcing-housepanel-control-panel-alpha/91639>\
**Category:** Projects & Stories\
**Tags:** project\_dashboard, open-dash\
**Created:** [July 2, 2017, 7:26pm UTC](https://community.smartthings.com/t/announcing-housepanel-control-panel-alpha/91639 "2017-07-02T19:26:16Z")\
**Posts on this page:** 1\
**Showing post:** 97
<div class="post-metadata">
**Author:** ![ady624](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/ady624/32/32610_2.png) [@ady624](https://community.smartthings.com/u/ady624)\
**Post date:** [August 4, 2017, 1:01am UTC](https://community.smartthings.com/t/announcing-housepanel-control-panel-alpha/91639/97 "2017-08-04T01:01:40Z")
</div>
I released a Connector code for easy integration some while back. That gives you the ability to list all existing webCoRE pistons and execute any of them.
> [@webCoRE Connector - two way webCoRE integration framework for developers](https://community.smartthings.com/t/webcore-connector-two-way-webcore-integration-framework-for-developers/89613):
> Hi guys, I’ve written a little connector that should help you integrate webCoRE. As you probably know, webCoRE now supports multiple installed instances, making the listing of pistons a little more complicated. The connector is (hopefully) handling that right. /\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*/ /\* webCoRE Connector v0.2 \*/ /\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*/ /\* Copyright 2016 Adrian Caramaliu \<ady624(at)gmail.com\> \*/ /\* \*/ /\* This program is free software: you can redistribute it and/or modify \*/ /\* it under the terms of the GNU General Public License as published by \*/ /\* th…
_[View the full topic](https://community.smartthings.com/t/announcing-housepanel-control-panel-alpha/91639)._
