# Amazon Echo - Current summary of what/how it integrates with ST? (May 2016)
**URL:** <https://community.smartthings.com/t/amazon-echo-current-summary-of-what-how-it-integrates-with-st-may-2016/46982>\
**Category:** Connected Things\
**Created:** [May 3, 2016, 7:12pm UTC](https://community.smartthings.com/t/amazon-echo-current-summary-of-what-how-it-integrates-with-st-may-2016/46982 "2016-05-03T19:12:28Z")\
**Posts on this page:** 1\
**Showing post:** 8
<div class="post-metadata">
**Author:** ![JDRoberts](https://yyz2.discourse-cdn.com/smartthings/user_avatar/community.smartthings.com/jdroberts/32/56577_2.png) [@JDRoberts](https://community.smartthings.com/u/JDRoberts)\
**Post date:** [May 4, 2016, 6:15pm UTC](https://community.smartthings.com/t/amazon-echo-current-summary-of-what-how-it-integrates-with-st-may-2016/46982/8 "2016-05-04T18:15:26Z")
</div>
> [@rgreenpc](#):
> How do you assign a routine to a virtual switch. I loaded the switch into Alexa. And can trigger it but haven’t figured how to link the switch to a routine.
Here you go:
> [@\[DEPRECATED\] 2015 Voice Assistant Run Routine FAQ--see 2017 FAQ instead](https://community.smartthings.com/t/faq-using-echo-to-change-a-mode-or-run-a-routine/21123):
> On October 1, 2016, Amazon added the ability to turn on a " routine" from Alexa. If you want to use that method, see the official support article. [https://support.smartthings.com/hc/en-us/articles/210204906-Amazon-Alexa-SmartThings-Routines](https://support.smartthings.com/hc/en-us/articles/210204906-Amazon-Alexa-SmartThings-Routines) Note that the official method will not allow you to use echo to run any routine that includes a lock or a Smart Home Monitor armed state change or another device class that Alexa does not know. The method described below in this FAQ will, but it does require that you create a virtual switch. Although at present echo can only request that smartthings turn devices on, off or dim, by using a virtual switch, you can tell echo to turn that switch on or off, and then have all kinds of things happen in smartthings. For example, if you want to have echo tu…
_[View the full topic](https://community.smartthings.com/t/amazon-echo-current-summary-of-what-how-it-integrates-with-st-may-2016/46982)._
