Anyone aware of an integration or ability to use the Ama Home Wifi Exterior outlet with ST? Here’s link to the device on Amazon. Its called the JRSOKO Wireless Wifi Outlet Compatible with Alexa, Dual Waterproof Outlets,Wireless Smart Outdoor Switch Socket Plug Outlet Timer Control By Smartphone,No Hub Required(Green)
I have tried to connect to several routers, 2.4 and 5.0, I’ve had no luck connecting to anything! At this point all it is, is a expensive manual power switch! If anyone out there has any ideas please share!
