Cree Connected Bulb and Lutron Connected Remote - Success Story #2
I have cree connected bulbs and Osram RGBW bulbs. Starting with a Cree to get a group ID, I am able to control my two Osram RGBW bulbs with the connected Bulb remote.
-If paired, unpair your Lutron remote from the Cree Connected bulb. To do so, turn on/off the Cree Connected bulb 4 times MANUALLY. Start with it on, and count OFF … 1.5 seconds … ON … 1.5 seconds and so on 4 times. The last time, the bulb will blink/dim indicating it’s been unpaired.
-Reset your Lutron remote by holding down both on/off switches together for a full 20 seconds until all flashing lights have stopped.
-Install the code as described above in posting #26. Just do the code install.
-Pair Lutron remote with ST hub. Yes, you do need to be within 4-inches of the hub to do this just for the pairing. Once the remote shows up on the ST app on your phone, you no longer need to hold the remote within 4-inches of the hub to complete the task of pairing.
-Pair a Cree Connected bulb with ST hub and turn on/off. Look for a description line such as this in your live logging:
description is read attr - raw: 7FFF0A00080A00000020FE, dni: 7FFF, endpoint: 0A, cluster: 0008, size: 0A, attrId: 0000, result: success, encoding: 20, value: fe
Note the endpoint is: endpoint: 0A
That’s hex.
Enter the decimal version of the endpoint: 10
Open the live logging page.
-Launch the Sticks18 SmartApp. Enter:
Lutron Remote paired to hub
Select the Cree Connected bulb
Endpoint. In this example from the above it would be 10
Live logging says:
description is catchall: 0104 0004 0A 01 0140 00 D0C8 01 00 0000 02 01 EF78
Enter the group id. In this example EF78
Select the OSRAM bulbs you want this remote to control
Enter the endpoint. In this example from the above it would be 03
