First, thanks for all who offer support /advice. Awesome community.
I’m having an issue I just cannot work through for both using the Logitech Harmony (Connect) SmartApp and then a completely different issue using IFTTT…
Smartthings issues discovering Harmony Hubs
I’d much rather add both Harmony Hubs via the Smartthings app to control the hubs via Echo but no matter what I’ve done, I can’t even get the Smartthings Logitech Harmony SmartApp to discover my 2 Harmony Hubs (or either of the 2 Hubs). I receive an immediate ‘Connection to the hub timed out’, Please restart the hub and try again’ message appears after clicking on the SmartApp. Regardless of deleting the SmartApp and adding it back in, I can’t get around this issue.
Following is for IFTTT issues I’m seeing
Hardware: I have an Echo, Smartthings (v2) and 2 Harmony Hubs (Smart Control).
Goal: Control upstairs and (separate) basement Harmony Hub via Echo (Power On, Power Off, Change Channels, etc)
Issue: Using IFTTT, only one Harmony Hub is detected (basement). Upstairs Hub is nowhere to be found although works as appropriate through Logitech remote/ Logitech app to control TV, Roku, (it’s not dead).
Note: Using Echo to control the basement Harmony Hub works with no issue.
Troubleshooting efforts:
-Unplugged basement Harmony Hub, yet IFTTT doesn’t see the Harmony Hub that is online (upstairs). Nothing appears in IFTTT.
-Attempted to delete recipe in IFTTT and re-add. Only basement appears
-Renamed activities so they are different
-Renamed Hubs in Logitech so they are different
-Renamed Hubs in my router so they have different names
-Saw a response (albeit dated) from Logitech suggesting I cannot give Static IP addresses. Apparently, I cannot.
I’m out of ideas. Any thoughts?
End of day, I’d like to control both upstairs and basement via Echo. We mainly sit upstairs so it’s unfortunate the basement appears /works and upstairs does not.
