I checked my time. I only got five things activated on the Alexa apps and only two with lights and I checked the time that’s no where near the time and lights come on. I’m just getting up to use restroom sitting on toilet in the dark I see the light come on under the door after sitting for a bit on the toilet with no where near the time. Now I’m typing the message cause I was talking low about the lights whispering then lights just come on
With Alexa, the first thing you should check to see if Hunches is enabled. Hunches can create Routines that perform tasks such as turning on/off lights, etc. if you don’t want it then disable it. Then check in Alexa Routines to see if it created any Routines and remove any that are not needed.
If you are only use Alexa in your home and not SmartThings, you may want to post in the Alexa community forum for any Alexa related questions.
