This is a Tracfone device -
https://www.target.com/p/tracfone-alcatel-raven-lte-black/-/A-53160776
Works fine on wifi without activation. I put it in airplane mode, removed the sim and put it on WiFi - Has a wonderful 5 inch bright IPS screen. works great for running smarttiles or dashboards.
I bought 4 and put them on the walls.
Awesome. Can it be forced into a kiosk mode?
You donât even need to do that if you use sharptools. Simply make/grab a widget for the thing you want to control.
I might pick up a handful. Run it dim until its camera picks up movement, then brighten, and have the widgets there waiting for anything needed in that room (or select other functions).
I had a hard time finding it in the store - the computer said they had 6 and they couldnât find a single one. Turns out they were all on a standalone Tracfone display thingy. Keep that in mind when you go to the store
I use the âfullyâ kiosk browser and set the homepage to http://app.actiontiles.com. Settings for running in kiosk mode in the paid version
I got three of âem.
First will be as a touch switch for my upstairs bathroom, outside the door. Will have both bulbs on a hue widget.
