Like the rest - mine is down too - I figured it was something done by alarm.com - waiting and hoping for a fix - I really loved this Smartapp. Alexa recognizes and acknlwledges the “arm” and “disarm” commands - but then nothing happens!
For anyone wondering - login to the alarm.com url in the app (https://www.alarm.com/pda/) via the browser on your mobile device - You could say the interface changed. What used to be a “Links” type interface now appears to be a hybrid experience much more aligned to their desktop site and even mobile app.
Good in one sense, but bad in the sense of ST integration…
This should be back up now. See Below:
Ok - this should be working now. And maybe those that did not have silent work before will have it work now…
It seems that Arm Away / (Arm Away)Disarm works; however, Arm Stay / (Arm Stay)Disarm does not? I see it sends the command but it never happens, no feedback other than sending event on ARMSTAY.
Arm Stay:
2:47:53 PM: debug sending event off to DISARM
2:47:53 PM: debug sending event on to ARMSTAY
2:47:53 PM: debug trying to update status of child device ARMSTAY
2:47:53 PM: debug getCommand got command null with silent true and nodelay of false
2:47:53 PM: debug updating status to null on command ARMSTAY
2:47:53 PM: error something went wrong: java.net.URISyntaxException: Illegal character in path at index 50: https://www.alarm.com/web/api/devices/partitions/${dataunit}${extension}/armStay
2:47:53 PM: debug state variable extension set to null
2:47:53 PM: debug state variable afg set to bgsHDQDoN+nWHeW8f/IMMw==
2:47:52 PM: debug state variable dataunit set to null
2:47:52 PM: trace response status is 200 for idextract and uri:https://www.alarm.com/web/History/EventHistory.aspx
Arm Away (you see it passes the variables after /partitions/ as opposed to above Arm Stay command where they are empty):
2:50:02 PM: debug trying to update status of child device DISARM
2:50:02 PM: debug trying to update status of child device ARMAWAY
2:50:01 PM: debug trying to update status of child device ARMSTAY
2:49:57 PM: debug postbody:https://www.alarm.com/web/api/devices/partitions/92785379-127/armAway::{"forceBypass":false,"noEntryDelay":null,"silentArming":null,"statePollOnly":false}
2:49:57 PM: debug header:https://www.alarm.com/web/api/devices/partitions/92785379-127/armAway::Connection:close
2:49:57 PM: debug navigation:[name:ARMAWAY, requestContentType:application/json; charset=UTF-8, contentType:application/vnd.api+json, uri:https://www.alarm.com/web/api/devices/partitions/92785379-127/armAway, headers:[...REMOVED..], method:post, body:{"forceBypass":false,"noEntryDelay":null,"silentArming":null,"statePollOnly":false}, expect:[content:(?ms)extendedArmingOptions], referer:https://www.alarm.com/web/History/EventHistory.aspx, variables:[:]]
2:49:57 PM: debug header:https://www.alarm.com/web/api/devices/partitions/92785379-127/armAway::ajaxrequestuniquekey:REMOVED 2:49:57 PM: debug navigation::post https://www.alarm.com/web/api/devices/partitions/92785379-127/armAway
2:49:57 PM: debug processing recipe ARMAWAY
Do we need to do anything? We just teied it and it’s not working for us. It logs in as the ST user but does not pass the command through.
Mine is working (somewhat) - I use Echo voice commands - Alexa is responding to the Arm and Disarm commands by saying “Smartthings is not responding” but then the command executes anyway (that is, the alarm is arming/disarming from the command) Also, even though I have the “silent arming” option selected, it is not silent arming (that is, it arms but with the series of beeps) All that said, THANKS for the quick work!!
A few observations on the new version:
Delay between smartthings switch and registering with alarm.com - likely because of a lengthier login / UI parsing in the new alarm.com web interface vs. the previously simplistic pda interface. This requires putting some delays in automations (e.g. webcore) to ensure they occur after state change.
Refresh command doesn’t work - if you refresh any of the Arm Stay / Away / Disarm switches, either programmatically or by pulling the switch in the ST app, the code sends a disarm command to alarm.com instead of simply logging in and scraping the status to the switch. I posted this as an issue for Schwark on github.
Let’s hope he is able to address this before the weekend is over as it is key, at least to my integration.
Also a bunch of us posted on several occasions that we are willing to donate for his time and effort - does anyone have any coordinates as to how to actually send him money?
Still not working for me either with ST or Alexa.
@ryant80 did you go into the IDE and update the code from the app?
I had to do that before it worked right
No sorry will try it now
My sincere thanks to @schwark for fixing this app so quickly - after replacing the app’s code with your revised code today it is working perfectly again. This also is a great time to thank @schwark for writing this in the first place. Of all the home automation I’ve done this is hand’s down the most useful and life changing for our family. We don’t have to think about the security system any more - it is off when it should be and on when it should be. There is no more stress of worrying about arming or disarming and forgetting. I never would have anticipated how significant this automation is to our every day life. Thank you for writing this app and making our lives easier and better.
Mine is not working still. I removed all the switches, and also the smart
app from my iOS ST app. I then went in and completely removed the smart
app, and device handler and rebuilt everything. I’ve saw the new switches
come into ST but it’s still not executing the command at the panel.
Is there something I can do to troubleshoot?
Mine is working a bit better now - using Echo voice commands - Alexa is still responding to the Arm and Disarm commands by saying “Smartthings is not responding” but command executing anyway (that is, the alarm is arming/disarming from the command) so that is a minor incovenience - anyone know why that is? The “silent arming” option is now WORKING FINE. Thanks for the continued good work!
@schwark, just to give you a huge thanks, especially from the WAF perspective, for fixing this. Updated the code and all is functional again, albeit a wee bit slower, but as somebody else has already mentioned, must be because of the extra hoops you have to jump through!! Kudos to you for such a quick turnaround!
J
Hi! still nor working on my side even after update the code… any thoughts? many thanks!
Same here still not working. I’ve deleted everything from ST in the app and also in the IDE and then re installed everything and it’s a no go.
Update from previous post: it is working now!
There is a new/updated repository on github and reading the instructions to update from a previous version might help. Delete everything that has to do with your alarm, switches, smartapp, device handlers etc, including from webcore, alexa, google etc. Then reinstall from the new repo (create app and device from code), setup login and pass in ST app, wait ten minutes and set it back up with your automations. That did it for me!
Is anyone experiencing a time delay in how often the system will accept commands? Seems to be about 3 minutes is the number you have to wait between commands being accepted. I thought the problem was automating the switches at first, but then realized it wasn’t accepting the commands if sent back to back. However, it still shows in the activity log that it is logging in, but not issuing the command. I waited a few minutes and then it started working again, but I think I’ve narrowed it down to 3 minutes.
Also, I don’t believe the Arm Stay is working at all.
Are you guys renaming the devices in the App? In my situation after I rename the buttons it stoped to work.
I removed the apps connected to the switches then deleted the smartapp from smartthings. I then copied and pasted the new code for both the device type and smartapp. I reinstalled the smartapp. Then waited. Since others said it was going to be a few minutes I just closed the app on the phone and then came back to it some time later and then appeared and were switched on when I came to the ST app. Once I toggled them off it controlled and worked.
Thanks for getting this working again. I am super pleased.
