Aircraft Hangar Needs Smartthings
Yes, in an earlier post I mentioned I had an old v2 hub from a condo I used to own, so I’m set there. The heaters are 300 watts (about 2.6 amps at 110 volts), so there shouldn’t be an issue with power draw. That is why it takes between 3-5 hours to adequately pre-heat the engine and why I wanted the ability to turn it on remotely the night before. Thanks for your input and information on Meross. I’m trying to avoid going back and forth 35 minutes each way just to successfully get the solution implemented, so I think I’ll stick with the technology I’m familiar with (SmartThings).
I’m a Cessna owner/flyer so I’m on Cessna Pilots Society primarily but here a couple other forums I frequent are Beechtalk and Pilots of America. If you fly a Beech check out Beechtalk for sure!
Keep the dirty side down :wink:
